08-30-2021, 17:09 | #1 (permalink) |
No Life Poster Join Date: Jul 1999 Location: Netherlands Age: 57
Member: 334 Status: Offline Thanks Meter: 120 | Motorola XT2097-13 frp problem I have here a Motorola XT2097-13 with FRP on but i can not wipe it with the software see log, Card found : XXXX483 , v0150 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.13 Load IDBase v8331 Ok! VER : BP_R2.0.1 LEN : 1061678E8 ( 4,10 GiB ) CPU : maltalsc VER : QOJ30.302-5_2104_20210401_user_SIGN Operation : Identify [ v2.13 ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : PAC : QOJ30.302-5_2104_20210401_user_SIGN_008.pac Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : True FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! - > INFO : Remove cable from device to switch it off! Done! Elapsed: 00:00:43 Operation : Format FS / Reset Settings [ v2.13 ] Mode : Reset FRP BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : PAC : QOJ30.302-5_2104_20210401_user_SIGN_008.pac Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : True FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:21 FRP is still on and software can not boot without the selected firmware. I tried the other 2 options in model/type software also but FRP remains on. What is wrong? |
The Following User Says Thank You to Remco For This Useful Post: |
04-29-2022, 14:16 | #3 (permalink) |
Freak Poster Join Date: Jan 2004
Member: 48492 Status: Offline Thanks Meter: 29 | Frp not done Card found : XXX , v0153 Infinity-Box Chinese Miracle II : SPD/USC Module [SP2] v2.14 Load IDBase v8331 Ok! VER : BP_R1.0.0 LEN : B3F7FA5F ( 2,81 GiB ) CPU : maltalsc VER : QOJS30.506-7-2_2204_20220401_user_SIGN Operation : Format FS / Reset Settings [ v2.14 ] Mode : Default [ Reset Settings + FRP ] BootMode : FLASH 1. Power off device, wait 10-15 seconds 2. Press and hold BooKey ( 1 : BOTH VOL , 2 : VOL+ , 3 : VOL- ) 3. Insert cable in device! Wait for device ... Device Connected! BootVersion : SPRD3 Boot : PAC : QOJS30.506-7-2_2204_20220401_user_SIGN_012.pac Sending Init Boot ... Boot sent! Kick FDL ... BootVersion : Spreadtrum Boot Block version 1.1 Protocol setup ... Port speed : 921600 Sending Flash Boot ... Boot sent! Kick FLASH FDL ... FDL : 0x0008 FDL : EMMC_RO : False ; EMMC_PART : True ; EMMC_RPMB_SET : True FDL : RAW : 0x0002 FDL : FLH : 0x400000 FDL : Control transfered! Boot Done! Wipe failed! Wipe Ok : FRP Reconnect Power/Cable! Done! Elapsed: 00:00:19 |
04-29-2022, 14:16 | #4 (permalink) |
09-11-2022, 20:19 | #5 (permalink) | |
No Life Poster Join Date: Aug 2004 Location: With old & new friends Age: 49
Member: 79640 Status: Offline Sonork: 1577251 Thanks Meter: 238 | Motorola E7i power (XT2097-13) Phone was soft bricked ( boot loop). Flash was not successful with CM2SPD2. I unbricked phone with Motorola rescue and smart assistant. Now phone is Ok but FRP On. Quote:
BR | |
11-14-2023, 22:43 | #6 (permalink) | |
No Life Poster Join Date: Oct 2004 Location: Madeira Island Age: 47
Member: 85718 Status: Offline Thanks Meter: 449 | Quote:
Did you solved with infinity ? | |
11-18-2023, 20:43 | #7 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | All new motorola SPD phones are using auth. boot. Without auth, flashing (and diag) is restricted/disabled. you can try manual bypass after flashing, or wait for CM2 spd update, with universal (TP) loaders. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! |
The Following 2 Users Say Thank You to Brka For This Useful Post: |
