pradeep_kus | 09-28-2014 13:53 | MT6261 test with Infinity CM2MTK World 1st :) Check/Info Code:
Card found: S/N *******
Chinese Miracle II [MTK module] v 1.01b
Operation : Check / Read Info [ v1.01b ]
2. Insert USB cable. In some cases require hold BootKey ( '*' )
Wait for phone...
Phone found! [ 4 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6261_S0000
BB_CPU_SN : EFC1B4618B995BC946E9710B8E80CCBC
BROM Protocol Version : 05
Setting...
Setting done , result code 0x000E
BROM stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8E
DA_CSTAT : 0x5A
SOC_VERIFY : 0xC1
BOOT_STYLE : SF_FLASH_BOOT
NOR Flash IC initialized
[0] : FLASH_VEN : 0x0112 ,
[0] : FLASH_DIE : 00C2 0020 0016 0000
[0] : FLASH_LEN : 0x00400000
SDS : 0x003FE000 , 0x00002000
Done!
Elapsed: 00:00:06
Reconnect Power/Cable! Read Flash Only In 14 Sec ;) Code:
Operation : Read Flash [ v1.01b ]
Wait for phone...
Phone found! [ 4 ]
Sync...
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
Setting...
BROM stage done
DA_CSTAT : 0x5A
SOC_VERIFY : 0xC1
Reading Flash Conent now ...
Read Flash now
Read Ok , 4194304 bytes read
Check and collect compile info
File_Info : FLYCOM61D_11C_M872_PCB01_gprs_MT6261_S01.MAUI_11C_W13_52_MP_V2_F1.bin
FileVersion : MAUI.11C.W13.52.MP.V2.F1
Saved to : C:\Documents and Settings\Administrator\Desktop\mtk\Read_out\FLYCOM61D_11C_M872_PCB01_gprs_MT6261_S01.MAUI_11C_W13_52_MP_V2_F1.bin
Done!
Elapsed: 00:00:14
Reconnect Power/Cable! Format FFS Code:
Operation : Format FileSystem [ v1.01b ]
Wait for phone...
Phone found! [ 4 ]
Sync...
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
Setting...
BROM stage done
DA_CSTAT : 0x5A
SOC_VERIFY : 0xC1
Backup done
Executing FFS FORMAT now...
FAT_RANGE : 0x003B7000-0x003FDFFF , LEN : 0x00047000
DA_RET : DA_IN_PROGRESS
DA_RET : FORMAT_DONE
Done!
Elapsed: 00:00:16
Reconnect Power/Cable! Write Flash Code:
Load File
Load File Ok
Operation : Flash [ v1.01b ]
======= Flash
Files set for flashing :
[ MCU ] : FLYCOM61D_11C_M872_PCB01_gprs_MT6261_S01.MAUI_11C_W13_52_MP_V2_F1.bin
Wait for phone...
Phone found! [ 4 ]
Sync...
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
Setting...
BROM stage done
DA_CSTAT : 0x5A
SOC_VERIFY : 0xC1
Flash now
Erase region , wait ...
Write data , wait ...
Write : FLYCOM61D_11C_M872_PCB01_gprs_MT6261_S01.MAUI_11C_W13_52_MP_V2_F1.bin
Done!
Elapsed: 00:00:42
Reconnect Power/Cable! Repair Security (Imei) Code:
Operation : Repair Security [ v1.01b ]
Wait for phone...
Phone found! [ 4 ]
Sync...
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
[ERROR] : DONE
BB_CPU_SN : UNKNOW [ READ ERROR ]
Setting Service Mode ...
Init Ok, waiting for phone ...
Phone Initial Info :
BB : MT6261
SW : MAUI.11C.W13.52.MP.V2.F1
HW : Spice M-5408
IMEI[1] : 000000000000000
IMEI[2] : 000000000000000
Update IMEI[1] to : 911347506087165
Update IMEI[2] to : 911347506087173
Done!
Done!
Elapsed: 00:00:32
Reset User Code Code:
Operation : Reset UserCode [ v1.01b ]
Wait for phone...
Phone found! [ 4 ]
Sync...
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
Setting...
BROM stage done
DA_CSTAT : 0x5A
SOC_VERIFY : 0xC1
Backup exists , skip
Read ExtData
Sorting ExtData
Sort Ok, Rebuild Ok
Restore ExtData
All done
UserCode request removed
UserCode set to default ( 0000 or 1122 )
Done!
Elapsed: 00:00:13
Reconnect Power/Cable! ;) |
