12-13-2017, 22:55 | #1 (permalink) |
Banned Join Date: Jul 2006 Location: dword ptr [ebp-1C], edx
Member: 322417 Status: Offline Thanks Meter: 940 | MTK 6755 Problem, support need help Code: Card found : S/N : CB822A50 , v0136 Chinese Miracle II [MTK module] v 1.58 Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 68 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : BROM [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2122 EMICFG_NOT_ACCEPTED_CONFIG Boot Error! Operation Failed Elapsed: 00:00:33 Reconnect Power/Cable! Unsupported Yet( or bad??? ) file selected! Operation : HW Test [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 68 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : BROM [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2122 EMICFG_NOT_ACCEPTED_CONFIG Boot Error! Operation Failed Elapsed: 00:00:19 Reconnect Power/Cable! UMIDIGI Crystal 2GB and 4GB ROM 2GB is MT6737T 4GB is MT6750T Strange is that SW will recognize as MT6755. Any Way is there way to Flash this set ? I try with Vol Button Combination Same thing Holding Power Same Thing FlashTool Same Thing Any Idea ? BTW This is scatter file from their genuine support that CM2 Recognize as invalid.. |
12-17-2017, 19:33 | #3 (permalink) |
Freak Poster Join Date: Jan 2007
Member: 427167 Status: Offline Sonork: 100.1670875 Thanks Meter: 48 | You are out of the deep forest? How much time will you cry here. There are many ways to get support, read this https://www.infinity-box.com/contact/ |
12-17-2017, 19:57 | #5 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | If you not got answer in 24 hours - then just bump thread. I just a human and can sometimes skip threads and forget after, or get internet problems ( much last few month ) and post will go to void. According problem, if you get same error with both firmwares, there is achance about eMCP problems ( it ram ). since Raphael line not show debug data - can't say exactly. But it inside HW. If chinese guys not made new revision, or forget add in latest releases support for old ones. |
The Following 2 Users Say Thank You to JayDi For This Useful Post: |
12-18-2017, 13:14 | #7 (permalink) | |||
Member: 322417 Status: Offline Thanks Meter: 940 | Quote:
Wonder should i call them on phone ? Get out of mine thread Quote:
There are 2 Models present 2GB is MT6737T 4GB is MT6750T Problem is that SW will recognize as MT6755 But on official site there is no MT6755 Firmware - only MT6570T. This Part confuse me ? Quote:
But honestly , 11 years Infinity Customer and only best words for Team. Now back to subject : According to Official site Phone is MT6570T but CM2 will recognize as MT6755 IS Possible flashing wrong firmware to change that info ? I Dont think that customer have CM2 or any other tool to skip hardware Check. So according to your thought , is possible ? Thanks I try mine friend , i am getting BROM ERROR : STATUS_EXT_RAM_EXCEPTION_(0XC0050005) Thanks friend for replaying , br Formingus | |||
12-18-2017, 13:34 | #8 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | MT6570 and 6755 in fact same by hw, differs just marketing names and internal features. Scatter inside fw must be 6755 ( should ) According errors, as explained before. Since 6737 and 6750/6755 incompatible by fw level - that mean you should use 6750 one. Device state now? No any reaction at power on try? Power consumption? 10-20 mA or 90-200? |
12-18-2017, 18:29 | #9 (permalink) | |
Pressing Power Button does not change amp at all so no reaction. About power Consumption hope this is answer When i plug usb cable i am getting 0.33 A or 330 mA.. If there is other way to check power consumption tell me , i will On CM2 says preloader erased , PreLoader : NOT Active [ Erased ] And Error Message is [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2122 EMICFG_NOT_ACCEPTED_CONFIG Boot Error! Operation Failed On Loading Scatter file i got bad scatter - attached on 1st post On initialize preloader will not work because it cant boot. Thanks | |
