05-21-2020, 08:44 | #1 (permalink) |
Freak Poster Join Date: Jan 2005 Location: Turkey Age: 42
Member: 103342 Status: Offline Thanks Meter: 6 | MTK/Mediatek v2.10 smart card misconfiguration contact to support plz help me Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Gemalto e-gate Smart Card 0 HWID: 00045E81FF021982 Box/Dongle found: Infinity-Box/Dongle Reading... Serial No (S/N): 43B45E81 Firmware version: 0143.02 === Process started: 21.05.2020 01:08:24 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0031] Dongle identification data damaged. Contact to http://www.infinity-box.com/support/?r=2 smart card misconfiguration contact to support plz help me after update MTK/Mediatek v2.10 and update dongle whit dongle manager 1.80 to 143 |
05-21-2020, 13:54 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | There is a software conflict with this application: \program files\renesas electronics\usb 3.0 host controller driver\application\nusb3mon.exe - Disable this process - delete fault.bn file - update dongle firmware with DongleManager now and then run Infinity software. Team is working to fix this compatibility issue. |
05-21-2020, 21:39 | #5 (permalink) | |
Member: 103342 Status: Offline Thanks Meter: 6 | Quote:
After updating the Box, this error started to appear | |
05-22-2020, 00:14 | #7 (permalink) | |
same error what i did i am using windows 10 Last edited by cecogsm; 05-22-2020 at 00:20. | |
05-22-2020, 09:00 | #8 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | You must find this file c:\program files (x86)\renesas electronics\usb 3.0 host controller driver\application\nusb3mon.exe and rename it to nusb3mon-1.exe and then reboot PC tell me, renamed and reboted now ? |
05-22-2020, 09:24 | #9 (permalink) | |
the result is the same | |
05-22-2020, 10:33 | #10 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | your result is "same" because you did not fixed PC as per instruction yet. Now update PC as per instruction - https://www.infinity-box.com/news/?r=3999 After that update dongle firmware with DongleManager to fix "misconfiguration" message |
05-22-2020, 12:01 | #11 (permalink) | |
InfinitySupport worked thank you | |
