08-01-2015, 16:38 | #1 (permalink) |
No Life Poster Join Date: Sep 2006 Location: ---> Hope
Member: 355782 Status: Offline Thanks Meter: 1,265 | My 1st operation with infinity dongle and phone dead dead dead. Model ZTE S518M phone was network locked only. Code: Chinese Miracle II [SPD module] v 1.02 FastCheck : SPD65xx Load file... Platform : PK_CMPAK_P153A10V1.0.0B03 Project : SC6530_BAR HWInfo : SC6530_BAR Compile : 12-18-2012 15:07:48 Load Ok Start at : [01-08-2015 / 8:14:57 PM] Operation : Flash [ v1.02 ] ======= Flash Files set for flashing : [ MCU ] : PK_CMPAK_P153A10V1.0.0B03_20140508_111149_FullFlash.bin 1. Remove battery. Insert USB cable 2. Press and hold BootKey ( Skip, if use BootCable ) 3. Insert battery ==== Wait for phone... Phone found! [ 9 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 sh ]Sync... Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 ¼B Boot Ok Flash CAP : 02000000 ======= Flashing MCU Mapping file ... Mapping done Processing file : PK_CMPAK_P153A10V1.0.0B03_20140508_111149_FullFlash.bin Init ok, send data Error while sending blocks! Elapsed: 00:00:23 Reconnect Power/Cable! |
08-01-2015, 17:11 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Congrats! You are really first. BTW - phone can't die fully. Check by "Format FS", for example, what structure detect will say. Connect can be done by pressing bootkey ( center joy/star/left soft/call - some from those ) |
08-01-2015, 18:21 | #4 (permalink) | |||
Member: 355782 Status: Offline Thanks Meter: 1,265 | really ? Quote:
PS: buying your product just now does not mean I am newbie in mobile repairing I know how to connect and make detectable phones and etc. | |||
08-01-2015, 18:24 | #5 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Then charge battery and connect it. It will work. No need tell me some stories about own expirience and e.t.c. - I know exactly what and how happening inside. |
08-01-2015, 18:25 | #6 (permalink) |
Member: 355782 Status: Offline Thanks Meter: 1,265 | because my tools not supported direct unlocking. and this is unlocked firmware after writing this firmware phone will be unlocked, but now I can say maybe dead. there are many success reports you can search in forum. |
08-01-2015, 19:02 | #7 (permalink) | |
Member: 355782 Status: Offline Thanks Meter: 1,265 | Quote:
confidence is good thing but sometime miracles happens. phone is really dead and battery is fully charged and connector is also well. leave upper part of this post and see below. If you really want to help me. I opened the phone soldered rx tx and now phone is detected by CM2SPD with comport. BUT... Code: Port Opened Wait for phone ... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sending boot ... Boot Sent , starting... Boot Ver : Spreadtrum Boot Block version 1.2 Boot Ok Flash CAP : 02000000 ======= Flashing MCU Mapping file ... Mapping done Processing file : PK_CMPAK_P153A10V1.0.0B03_20140508_111149_FullFlash.bin Init ok, send data Error while sending blocks! Elapsed: 00:00:30 Reconnect Power/Cable! | |
08-01-2015, 19:22 | #8 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | But it change nothing. Yeah, I've checked search over forum and find about that sample : http://forum.gsmhosting.com/vbb/f425...l#post10887273 I still not found such sample. Normally - CM2 check state before format and repair operation, For flash writing it check nothing due some reasons. So , that is result, why it dead. Repair possible, but I need have phone on hands. Exactly such. Not matter alive or dead. So , if someone ( or you ) can sell me that sample - I will make it for hour or so. There was already mentioned 5-6 times about near 0.5% os SPD6530/6531 phones, which not work with CM2 due their HW difference , and for 1.5 years no one sell me such sample. |
08-01-2015, 20:54 | #11 (permalink) |
Freak Poster Join Date: Mar 2005 Location: where dreams become reality Age: 45
Member: 124371 Status: Offline Thanks Meter: 51 | try with new ver Infinity Chinese Miracle-2 SPD v1.03 - Android Dream #2: SC8830, safe eMMC Format etc. Some bugfixes for SC66x0 phones Some bugfixes at all |
08-01-2015, 21:21 | #12 (permalink) | |
could someone tell me plz how to write 32mb dump ?? http://forum.gsmhosting.com/vbb/f425...l#post10887273 CM2SPD says; Code: FastCheck : Non-SPD file!!! Select Correct file! | |
08-01-2015, 21:33 | #13 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | @Nasir Mobiles If you are new in this field you should read something before flash phones ! Lets hope you do not start to learn "what is electricity" with tests like "put fingers in 220v wall socket". Right ? Why you think that you may start to repair phones with "put fingers into wall socket" test ? Now my questions: 1. Why you have flashed your phone instead of ask questions first ? 2. What is the file that you have used for flashing ? 3. Do you have original backup from your phone ? And yes, for sure you will get no any answers here if I do not see answers to my questions 1. and 2. and 3. first Btw, small info for "professional unlockers" (he-he) - flashing and unlock are different procedures. Example: flashing - its like a change your body Unlocking - its like a change your brain You can change your body so much as you want but if barin has zero size this operation is useless (but yes for some people who has their brain f.e. in their *** - this operation may be helpful). The same situation is with phones in most cases - flashing can not helps to unlock phone in most cases, but in some cases flashing may helps (f.e. if firmware is patched or if firmware has no lock inside at all). @Dirt Please never try to buy phones and paay for samples if you do not know phone history and what user tried to do with phone. If we start to buy every phone that was flashed with wrong firmware and without backup - we will lost a lot of time and money for nothing. Of course, if you really need this phone - there is a reason to buy it. But I strongly suggest you check once again what is the problem with phone and why it become dead before aks for that sample. Last edited by YellowBoss; 08-01-2015 at 21:46. |
The Following 2 Users Say Thank You to YellowBoss For This Useful Post: |
08-01-2015, 21:56 | #14 (permalink) | |
1, wash your face with cold water and rub your eyes gently and read whole thread again. 2, same 3, same if there is no answers in thread, I'll apologize and will answers your questions. dont take advantage of you PS power and dont delete my posts and lets see who right here. I never understand why you infinity team always treating us as like a servant. never hear our voice and loud yours. we always writing here Infinity is good team , great team ,we love infinity etc, and you.... what we did wrong that we buy your product and you know your tool is above than others thats why you ...you ... leave leave just tell me if you did not get the answers from my previous post i'll make new post with all answers required. | |
08-01-2015, 22:58 | #15 (permalink) | |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Dear Smart Friend ! I have seen a lot of "smart people" like you who can write ten pages of useless words instead of explain problem well once. I am very sad to see that you do not want to provide exact answers to my questions about your problem. Anyway when you will be ready to provide that answers we can continue this nice discussion. More required questions: 4. where you have got that file ? 5. why are you sure that this file is good for your phone ? Good luck ! P.S. After your last "smart answer" we have no reason to continue this discussion without words like "big sorry" from your side. And dont forget to follow your own advice first: Quote:
Yes, you have another way - continue to make your "smart messages" with zero information. Lets hope this way is shortest way to repair your phone after YOU have damaged it. Last edited by YellowBoss; 08-01-2015 at 23:38. | |
The Following 3 Users Say Thank You to YellowBoss For This Useful Post: |
