06-26-2018, 16:30 | #1 (permalink) |
No Life Poster Join Date: Jan 2009 Location: Chuadanga Bangladesh Age: 35
Member: 957066 Status: Offline Sonork: 100.1658197 Thanks Meter: 642 | My mistake Plz help Team Note: before flash i have make flash ic test it was ok. 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 33 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... [DA_ERROR] : 00007017 Boot Error! Operation Failed Elapsed: 00:00:05 Reconnect Power/Cable! |
06-28-2018, 15:22 | #3 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Select nokia. Select firmware. Untick preloader flashing. Open DeviceManager. connect phone. When MTK USB PORT in COM port section appears - press FLASH button. You should catch moment of reboot-Bootrom - preloader Tested firmware on support. Br. Infinity Box Team. |
