Old 02-16-2011, 12:29   #1 (permalink)
Registered User
Member: 1359163
Thanks Meter: 37
n95 gemini fullflash read problem
Try to read full flash but have error , here is log :
COM5 [VCP0] selected
module v3.26
Device: Autodetect 6205-6239 NOR
Checking data, wait...
Action: read flash
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001303:0005
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 98004900000001:18E59F00000000
flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb
otp offset: 00FF0000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
115200
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: [standard] type (04)
TCL-ID is absent
rom info detection finished
rom info ver: 04
sw version: N95_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_W08_1 2.BIN
project-id: MAUI.GEMINI.W08.12, 00000000
code offset: 00000000
ffs offset/size [01]: 00E00000/00200000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
standard ffs/eeprom offset confirmed: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
firmware area: 00000000-00DFFFFF
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
reading: N95_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_W08_1 2__fullflash...
error: unexpected data: 1500000039
error: unexpected data: 150000003B1500000036
error: unexpected data: 1500000030
error: unexpected data: 15000000301500000015
error: unexpected data: 150000003A
error: unexpected data: 1500000038
error: unexpected data: 150000003C15000000FD15000000E9
error: unexpected data: 1500000039150000001A150000002F150000002D
error: unexpected data: 15000000B41500000038
error: unexpected data: 15000000A215000000341500000002150000001E
error: unexpected data: 0000000B21150000002D15000000A61500000060150000003C
error: unexpected data: 150000000115000000EE15000000AC15000000BB15000000AB 1500000030
error: unexpected data: 15000000AD150000000715000000BC150000002615000000B8 1500000062
error: unexpected data: 15000000FE15000000D0FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0051005200590002 00000040000000000000000000000027003600000000000400 00000A00000005000600040000001800010000000400000002 000700000020000000FE000000000001FFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFF005000520049003100310000 0002000100010007000100000001008500C600030001FFFFFF FFFFFFFFFFFFFFFFFF00080020002000200020002000200020 0027FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFF
warning: wrong data size at 0x00051800, retry...
read error recovered
error: unexpected data: 2115000000E315000000BAF7DB3B
warning: wrong data size at 0x00051C00, retry...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\N95_GEMINI_PCB01_ GPRS_MT6225_S00.MAUI_GEMINI_W08_12__fullflash_2011 0216-121856.B0M.bin
operation aborted
Finished, time used: 1 min 47 sec
Remove/Install battery now !
any solution to correctly read fullflash ?
Old 02-17-2011, 20:28   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
is this full working phone or it has some problems?
what cable/box d you use as interface?
Old 02-17-2011, 20:30   #3 (permalink)
Registered User
Member: 1359163
Thanks Meter: 37
hello!
I always read full flash to backup
I read firmware to change language
I use rj to PCB RX TX signal
Old 02-17-2011, 21:27   #4 (permalink)
Member: 148515
hello!
try to make reading keeping power button pressed all the time
Old 02-18-2011, 15:37   #5 (permalink)
Registered User
Member: 1359163
Thanks Meter: 37
hello!
Now I change speed reading to 115200 and now when I read and keeping power button i have
phone power on or this log:
module v3.26
Action: read flash
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
chip: 0001303:0005
status: FF
Boot Done
error: wrong answer: 80
error: error# 00000080
error: error# 000000FC: wrong answer after chip id request
error: wrong answer: FC
error: no any expected answer : wrong answer after chip cfi request
error: no any expected answer : wrong answer after chip id request
Initialize Done
====> Set baud ...
460800
error: no any expected answer : set baud_request_not_confirmed
error: can't work at this speed, use lower baudrate
Set baud Fail
Finished, time used: 26 sec
Old 02-19-2011, 21:38   #6 (permalink)
Member: 148515
hello!
sorry, i have no idea what is wrong with this phone
Eeprom reading KLImax Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 09-22-2011 15:55
GId1 problem old_man Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 10-18-2006 15:21
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-16-1999 00:44
Page generated in 0.20814 seconds with 9 queries
