08-30-2007, 20:52 | #1 (permalink) |
Freak Poster Join Date: Jul 2005 Location: MX-KEY is the BEST NOKIA TOOL Age: 40
Member: 165120 Status: Offline Thanks Meter: 16 | n95s i have n95s always give me tht error i m useing ChineseMiracle 1.46 COM2 [Serial1] selected Device: Autodetect: 6205-6227, 6228 old Checking data, wait... advanced flash detection active Action: reset Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6226:8A02:8A01]... high speed disabled boot step size: 0002 Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 126 sec Remove/Install battery now ! thankx |
08-30-2007, 22:19 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | you must read: http:///vbb/showpo...17&postcount=6 |
09-04-2007, 11:10 | #8 (permalink) |
Freak Poster Join Date: Aug 2007 Location: www.GSM-IR.com
Member: 565354 Status: Offline Thanks Meter: 28 | COM13 [VCP2] selected Device: Autodetect: 6205-6227, 6228 Checking data, wait... advanced flash detection active Action: reset Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... error: boot phase#1 failed Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 15 sec Remove/Install battery now ! this error..why? B.R, TOPNET_GSM:. |
09-04-2007, 13:25 | #9 (permalink) | |
Please, use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297 if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle.txt if not helps, please read: http:///vbb/showpo...36&postcount=7 | |
n95 (rm-159) strang problem | Tayyab_raja777 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 04-21-2010 09:01 |
need help master manole n95-8gb write screen restart | haslyn | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 15 | 03-30-2010 10:56 |
please help cannot flash n95 8g | kadricom | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 03-30-2010 10:06 |
n95 (rm-159) strang problem | Tayyab_raja777 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 03-29-2010 14:45 |
N95 vibrate then cutoff after flash [SOLVED - Thanks Crazy Ratata] | jus_chillin | Cyclonebox | 19 | 03-29-2010 11:57 |
