11-24-2008, 20:46 | #1 (permalink) |
No Life Poster Join Date: Mar 2002 Location: tunis,tunisia Age: 48
Member: 10396 Status: Offline Thanks Meter: 32 | N96+ hanging i have n96+ when i power on worked 100% after 5 second light power off that's normally but after 5 seconde i c white screen and lights power on with searching network and detect network full signal and he always repeat this procedure. i formated safe and complete mode always samme pb i flashed with this file T6226_05C_PCB01_GPRS_MT6226_S01.T1_SIMA_ALL_V08050 3C_Nokia-N96_16m_En_Ru_Fr_Es_It_De_Id_Th_Vn_Cn_Tr_Pt_Ar.B0M .bin and i formated changed imei to original but always same pb i formated whole flash and i flashed with his same version T6226_05C_PCB01_GPRS_MT6226_S01.T1_SIMA_ALL_V08051 0B__N96_16m_En_Ru_Fr_Es_It_De_Id_Th_Vn_Cn_Tr_Pt_Ar .B0M.bin and i added eprom file format with complete and repair imei and always the same pb. this is the original version ver. sw 1: T6226_05C_PCB01_GPRS_MT6226_S01.T1_SIMA_ALL_V08051 0B.BIN ver. sw 2: T1_SimA_ALL_V080510B, BC43961B plz any help to repair that phone ?? thx. |
11-24-2008, 21:12 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! as we can see: formating, flashing do not help. from my side i just can confirm that you did all needed software operation & picked flash files correctly. if phone still acts same- this is not software problem, must look for some hardware fault |
03-16-2009, 00:23 | #3 (permalink) |
Junior Member Join Date: Aug 2005 Location: Honduras
Member: 170463 Status: Offline Thanks Meter: 1 | hello infinity team please i need help with this nokia n96 i already unlock it but it doesnt pick network signal what can i do this is the log COM10 [VCP0] selected module v2.78 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:C9FC:4DDD status: FF high speed boot Off boot packet size: 0002 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #02 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #03 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Archivos de programa\InfinityBox\ChineseMiracle\backup_securit y\id.682440E7.[T6226_05C_PCB01_GPRS_MT6226_S01.T1_SIMA_ALL_V08051 0B.BIN_E469BC43].rpl identification#1 detection finished device-id: 682440E7 identification#1 protocol ver: 04 ver. sw 1: T6226_05C_PCB01_GPRS_MT6226_S01.T1_SIMA_ALL_V08051 0B.BIN ver. sw 2: T1_SimA_ALL_V080510B, BC43961B ffs offset/size: 00E00000/00200000 detecting security area (code #2)... .................................................. .................................................. .................................................. .................................................. .................................................. ...... security area (code #2) is absent detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: 01227E22202200:29EA0000000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF detecting ffs/eeprom structure pass 1... .................. detect standard fat location pass #1... .................................................. ...... detect extended fat location pass #1... .................................................. ..... detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs/eeprom detected ok: element #1 Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: eeprom[T6226_05C_PCB01_GPRS_MT6226_S01.T1_SIMA_ALL_V08051 0B.BIN]... file saved: C:\Archivos de programa\InfinityBox\ChineseMiracle\eeprom[T6226_05C_PCB01_GPRS_MT6226_S01.T1_SIMA_ALL_V08051 0B.BIN]_20090315-233156.B0E.bin flash: 01227E22202200:29EA0000000000 Backup required data Done Patch required data ... detection procedure, wait... detection procedure completed Patch required data Done Special operation ... Special operation Done Write ... flash: 01227E22202200:29EA0000000000 Write: eeprom Write Done Finalization ... Finalization Done file saved: C:\Archivos de programa\InfinityBox\ChineseMiracle\backup_securit y\system_log_682440E7_T6226_05C_PCB01_GPRS_MT6226_ S01.T1_SIMA_ALL_V080510B.BIN_E469BC43_20090315-233410.B0X.bin Finished, time used: 573 sec Remove/Install battery now ! |
03-17-2009, 07:06 | #5 (permalink) |
Member: 170463 Status: Offline Thanks Meter: 1 | nope i just do a standart unlock of the cellphone imei is good the question is that in my country we have 4 companys and the bands of the company are 850 900 1800 1900 but it doesnt get any signal what can i do please and thanks for your support infinity ps remember its a n96 chinese nokia for only one sim |
n96 hang and restarted when i open frount cam | neeraj1st | Nokia Hardware & Hardware Repair | 0 | 03-08-2010 14:32 |
N96 hang in call | nasro_nd | Nokia Base Band 5 ( BB-5 ) | 4 | 02-11-2010 11:40 |
n96 hang on white screen | emush | Nokia Hardware & Hardware Repair | 1 | 01-20-2010 16:25 |
N96 hangs on power on?!!!!!! | meisam | Nokia Base Band 5 ( BB-5 ) | 1 | 03-14-2009 18:02 |
Solution for N96 hanging... | jafsupport.com | J.A.F. By Jafsupport.com | 2 | 11-10-2008 06:54 |
