06-17-2008, 17:53 | #1 (permalink) |
Junior Member Join Date: Apr 2008
Member: 755725 Status: Offline Thanks Meter: 0 | n99i faild in format i have n99i i Try format it but i can Because the Mobile Power on When I click the button operation What can I do so I format this Mobile thanks for help ------------------------------------- COM7 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: reset Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6205:8B00]... CPU: MT6205 high speed boot enabled boot step size: 0400 error: bootcode load error: 0010E28D029FEB001010E28D000DE1A0000BEB002010E3A000 0DE1A00000E59D0ACCEB000004E59D0ACAEB000008E59D0AC8 EB00000CE59D0AC6EB00D068E28D8070E8BD403EE92D5000E1 A04001E1A01010E2810004E28D2008E3A00011EB000010E594 1AC8E59F0B80E1A00D20E1A00038E350207822602038326000 04E1A00280EB002008E3A01004E28D0004E1A0027CEB002010 E3A01004E1A00005E1A00000EB00803EE8BD4010E92D3000E3 A0C000E3A0000FEA00E103E791E00CE7C0E103E791E80EE1A0 4C2EE1A0E00CE0804001E5CE4103E791C004E28C4404E1A04C 24E1A04002E5CE4103E7913001E2834C24E1A04003E5CE0002 E15CFFED3AFF8010E8BD1000E3A01014E5801010E5801A20E5 9F1000E5801A1CE59F1004E5801A18E59F1008E5801A14E59F 100CE580FF1EE12F41F0E92D0098E9908000E590D040E24DC0 00E3A02000E3A0E002E0816001E5DE5002E7D12004E2820040 E3525406E1856002E5DEE003E5DE5806E185EC0EE185E10CE7 8DC001E28CFFF23AFF1004E0032003E1C71002E1812000E59D 1002E08129ACE59F1008E0811002E0811CE1E0832003E001C0 01E1C4200CE182C004E59D200CE082C98CE59F2007E082200C E0822A62E081C001E002E002E1C3C00EE18CE008E59DC00EE0 8CE96CE59FC004E08CC00EE000 Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" box. Boot Fail Finished, time used: 7 sec Remove/Install battery now ! |
06-17-2008, 20:21 | #2 (permalink) |
No Life Poster Join Date: May 2008 Location: COME & MADE GREEN WORLD
Member: 771937 Status: Offline Sonork: 100.1605717 Thanks Meter: 1,052 | CHINA SET FORMAT PROSIDURE:-http://www.turboimagehost.com/p/424400/china_set_format.jpg.html Last edited by debmobile; 06-17-2008 at 20:26. |
06-17-2008, 20:26 | #4 (permalink) | |
No Life Poster Join Date: Jan 2007 Location: udaipur, I N D I A Age: 37
Member: 422762 Status: Offline Sonork: 100.1593904 Thanks Meter: 973 | Quote:
readthis again and u hav mt6205 cpu.... format it with complete method | |
06-17-2008, 21:07 | #5 (permalink) | |
Member: 755725 Status: Offline Thanks Meter: 0 | Quote:
in case of initial connection problem: on/off "Boot baudrate autoselect" box but What can I do to get rid of this problem i tray format complete but The same problem | |
06-18-2008, 17:46 | #10 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! run pinout search after it will find second MCU pinout- go to advanced settings and disable this pins. Run pinout search again. now pinfinder will find first CPU pinout., format it and you will get your phone repaired |
06-18-2008, 19:30 | #11 (permalink) | |
thanks Infinity team | |
07-30-2008, 18:55 | #12 (permalink) | |
No Life Poster Join Date: Jun 2003 Location: egypt,alexandria,(nassimgroup team) Age: 48
Member: 31018 Status: Offline Thanks Meter: 3 | me too Quote:
software version: 1.11 cable type: 1x12 (L12C) platform: MT62xx (autodetect) searching adapter at COM7... adapter found, version: 2000 pins: 12, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... 19200 fixed CPU: MT6205 result: Rx:8 Tx:7 time required: 44 sec Power On ! and here iswith infinity COM7 [VCP0] selected Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6205:8B00]... CPU: MT6205 high speed boot enabled Connecting, wait... warning: wrong packet cs error: can't finalize test mode repeat operation and HOLD phone "Power" button long time ! error: operation failed ! Finished, time used: 117 sec Remove/Install battery now ! same probleme with me the phone keep on off on off with infinity what to do thnx any way br | |
11-02-2009, 00:37 | #15 (permalink) |
Junior Member Join Date: Mar 2005 Age: 47
Member: 123533 Status: Offline Thanks Meter: 0 | module v2.96 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active write: Firmware CM_Nokia-N99-2sim_E553_KT3F8C_E553_GPRS_MT6226_S01.01_1_16m_En_ Fr_Es_De_Vn_Tr_Ru_Ar_Th.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ffs/eeprom backup enabled, it may takes several minutes ! enhanced security fix enabled Boot ... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing [6205:8B00]... CPU: MT6205 high speed boot On boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #01 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #02 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #03 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #04 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #05 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #06 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #07 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #08 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #09 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #0A in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #0B in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #0C in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #0D in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #0E in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #0F in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb number of flash chip/regions detected: 10/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb detecting chip #01 in region #00... flash: 01227E221A2201:18E59F00000000 flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 00400000 searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished rom info protocol ver: 04 ver. sw 1: DAYO_NEP_06B_PMJ_PCB01_GSM_MT6205B_DN.MAUI_06B_W07 _20_MP_V7.BIN ver. sw 2: MAUI.06B.W07.20.MP.V7, 00000000 address offset: 00000000 ffs offset/size: 003C0000/00040000 detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 003C0000 flash: 01227E221A2201:18E59F00000000 checking area [00000000]: 00000000-003FFFFF... ffs/eeprom found near: 003C0000 detecting ffs/eeprom size... ffs/eeprom size: 00040000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:003C0000-003FFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: DAYO_NEP_06B_PMJ_PCB01_GSM_MT6205B_DN.MAUI_06B_W07 _20_MP_V7__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\DAYO_NEP_06B_PMJ_ PCB01_GSM_MT6205B_DN.MAUI_06B_W07_20_MP_V7__ffs_20 091101-233445.B0E.bin flash: 01227E221A2201:18E59F00000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished startup code area #1 check... startup code area #1 calculation... error: startup code area #1 communication fault error: startup code area #1 can't be fixed detecting startup code area #2... startup code area #2 is absent You can flash phone now but can not finalize it. In most cases phone CAN NOT power-on. Do you want to continue anyway ? Area: Firmware flash: 01227E221A2201:18E59F00000000 Write: Firmware |
n99i hang after format..flash file needed | carlluvjo | Infinity-Box | 12 | 11-22-2008 19:10 |
need help v3r faild in unlocking... | berks | Smart-Clip | 5 | 07-11-2008 13:08 |
Camera faild in ZV10 ?? | WAHID2 | Samsung Hardware Repair | 0 | 11-21-2006 23:37 |
