10-25-2015, 15:17 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: Pakistan Age: 41
Member: 278548 Status: Offline Sonork: 100.1583183 Thanks Meter: 948 | NAND Flash not supported yet! Chinese Miracle II [MTK module] v 1.35 Operation : Remove Viruses [SmartAV] [ v1.35 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 12 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8C00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00AD00BC00900055005600AD00BC0000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x009A , [Hynix] H9TA4GH2GDMCPR [NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0056 00AD 00BC [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 0800/0040/01/NIM_Px-2 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! NAND Flash not supported yet! Done! Elapsed: 00:00:06 Reconnect Power/Cable! |
The Following User Says Thank You to Fune4u For This Useful Post: |
10-25-2015, 15:39 | #3 (permalink) |
Member: 278548 Status: Offline Sonork: 100.1583183 Thanks Meter: 948 | Definition Applied Waiting for USB Port... Set MediaTek PreLoader USB VCOM Port (COM12) Please Hold "ON" to connect with the phone... Connected to Phone. CPU: MT6572 SW:0000 Ver: CA01 Downloading Boot8 ... Nand Flash Type: Nand_NEW_0073 Nand Flash Code: 00AD00BC(00900055) Nand Flash Size: 0x20000000 Hex Bytes INT/EXT RAM Size: 0xC4800+0x0 Writing(Nand/eMMC)... Writing PRO_INFO Writing _PROTECT_F Writing _PROTECT_S Writing UBOOT Writing BOOTIMG Writing RECOVERY Writing SEC_RO Writing LOGO Writing ANDROID Writing USRDATA Write Done. >>Total time: 11 mins 30 s |
10-26-2015, 02:46 | #5 (permalink) |
No Life Poster Join Date: Nov 2008 Location: ĦĦInFiNiTy CM2 For EvER!!
Member: 901711 Status: Offline Sonork: 100.1606138 Thanks Meter: 427 | @Fune4u... Bro sorry for you!! CM2 have many, many, many, many... and more MANY other functions to work and make MONEY for OUR Business... Thinks!!! and after, please show only CM2 Logs.... Mr JayDi and the rest of INFINITY TEAM WORK for Us !!! |
The Following User Says Thank You to maomatrix For This Useful Post: |
10-26-2015, 05:00 | #6 (permalink) |
Freak Poster Join Date: Nov 2013 Location: Infinity Team
Member: 2072265 Status: Offline Thanks Meter: 46 | Card found : S/N : 7BD0661F , v0129 Chinese Miracle II [MTK module] v 1.35 Operation : Read Flash [ v1.35 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 94 ] Sync... Inital regs read done nand not support Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8C00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 009800BC009000660076001600080000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA start Failed at final stage! Check battery , cable , drivers and try try again Boot Error! Operation Failed Elapsed: 00:00:16 Reconnect Power/Cable! Operation : Read Flash [ v1.35 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 29 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8C00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 009800BC009000660076001600080000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0011 , [KINGSTON] KTN0403CS_TCR1 [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0016 0008 [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 1000/0040/00/NIM_Px-1 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Error while reading initial info! First make sure about "ReadInfo" passed fully! Operation Failed Elapsed: 00:00:11 Reconnect Power/Cable! Operation : Check / Read Info [ v1.35 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 29 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8C00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 009800BC009000660076001600080000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0011 , [KINGSTON] KTN0403CS_TCR1 [NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0016 0008 [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 1000/0040/00/NIM_Px-1 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Info read not done Erased phone or unsupported FlashIc? You can change settings : Settings -> Other -> NAND init Mode Done! Elapsed: 00:00:09 Reconnect Power/Cable! NAND not support |
The Following User Says Thank You to SAGAR NADEEM For This Useful Post: |
10-27-2015, 10:07 | #8 (permalink) |
Member: 278548 Status: Offline Sonork: 100.1583183 Thanks Meter: 948 | Wait for phone... Phone found! [ 12 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6583 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 4E0001154D5A5735F78201427B80D845 DA Stat : v3.2 on BBID : 0x86 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMZW5 [eMMC] : FLASH_CID : 1501004E35575A4D420182F745D8807B [eMMC] : FLASH_EXT : 00200000/00080000 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6589 , Project : MTK6589 , Storage : eMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC NOT supported by BootLoader! [BL_ERROR] : STORAGE : Break Flashing! This Firmware will kill phone! Done! Elapsed: 00:00:10 Reconnect Power/Cable! |
10-27-2015, 14:04 | #9 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
If you 146% sure about FW is Ok and for this phone - can flash it via SPFT. | |
11-18-2016, 14:44 | #12 (permalink) |
Junior Member Join Date: Aug 2013
Member: 1993758 Status: Offline Sonork: sudan Thanks Meter: 6 | CPU: MT6572 SW:0000 Ver: CA01 Downloading Boot8 ... Nand Flash Type: Nand_NEW_0072 Nand Flash Code: 009800BC(00900066) Nand Flash Size: 0x20000000 Hex Bytes INT/EXT RAM Size: 0xC4800+0x0 >>Formatting Nand Flash... |
The Following User Says Thank You to azma2012 For This Useful Post: |
