02-28-2008, 15:08 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: punjab india
Member: 330468 Status: Offline Sonork: 100.1587596 Thanks Meter: 121 | strange pin finder problem |
02-28-2008, 18:26 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,536 | hello! Main rule which you must follow: aftre pinout finder found pinout- do not disconnect phone from wires. do not disconnect USB cable or anything in circuit PC>box>pinout finer> phone. close pinout finder application and go to chinese miracle soft. make sure that correct com port is set and make any needed operation. Please post if this advice was helful or we need to search for other problems |
02-28-2008, 19:59 | #5 (permalink) |
Freak Poster Join Date: Jan 2005 Location: Chandigarh ,UT ,India Age: 48
Member: 107258 Status: Offline Thanks Meter: 15 | Sir , In My Case i Could Have a Hardware Damaged Phone ,Can You Suggest Me Any thread Were They Have Talked About Hardware Damaged china Phone .BTW i Have Posted My Problem .I Will Try My Autofinder Cable Tommorow On Working Mobile ,I Am Extreme Confidence In Infinity Box . Amarbir Singh Dhillon Chandigarh ,India |
02-29-2008, 08:08 | #7 (permalink) |
Member: 330468 Status: Offline Sonork: 100.1587596 Thanks Meter: 121 | strange problem sir i used the pin finder from last weak and done lot of phones with this i know th exact procedure for using the pin finder but cannot able to solve this phone problem i thing there is something wrong in pin finder |
02-29-2008, 10:46 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Hello, If you will be able to find pinout for other phones and use PinFinder with other phones this means thsat PinFinder works well. Possible problems: please, download and read latest PinFinder manual http://www.infinity-box.biz/download..._PinFinder.pdf page 18 |
02-29-2008, 11:19 | #9 (permalink) |
Member: 330468 Status: Offline Sonork: 100.1587596 Thanks Meter: 121 | strange problem i use the pin finder well before the update but after update i cannot use it i thing there may be something wrong with the update |
02-29-2008, 11:56 | #10 (permalink) | |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Quote:
What update you talk about ? If you talk about PinFinder software update v1.06 I can say that it was changes related with pin detection algorithms but now related with PinFinder hardware. Did you read manual according to my advice ? Also, please, explain step-by-step what you tried to do and what exactly not work. To be honest your problem description is not clear so you must post here problem description with step-by-step explanation ! | |
Infinity Pin Finder Problem....?? | srini.unique | Infinity-Box | 5 | 06-11-2008 22:08 |
Pin Finder problem | stargsm_ro | Infinity-Box | 3 | 06-05-2008 14:00 |
pin finder problem ... | BoOzer665 | Infinity-Box | 2 | 06-04-2008 21:14 |
Pin Finder Problem Installtion | Mansoor | Infinity-Box | 1 | 05-12-2008 09:44 |
pin finder problem | srini.unique | Infinity-Box | 1 | 03-17-2008 12:14 |
