11-19-2010, 22:41 | #1 (permalink) |
Freak Poster Join Date: Jun 2004 Location: Indonesia
Member: 69608 Status: Offline Thanks Meter: 63 | D-One DG628 Cannot flash by infinity Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0053]: 00AD:00A100000015 [HYNIX] H8BCS0PG0MBP chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (921600)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02620000/059E0000 firmware size: 38Mb ffs size: 89Mb detect sec ro... detect custom parameters... detect project-id... project-id: X10_DG628TEK_1GFMGB16_02S0112 detect NAND info... number of areas/bytes to read: 1:001A0000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... error: can not read memory: 0FAA:S_FT_READBACK_FAIL can not read memory, errorcode: 0FAA it may be problem with current operation and/or future software functionality contact to support ! error: last error: 0FAA:S_FT_READBACK_FAIL Disconnect... done Finished, time used: 39 sec Remove/Install battery now ! phone read ok by other software.... |
11-19-2010, 23:03 | #2 (permalink) |
Member: 69608 Status: Offline Thanks Meter: 63 | problem solved by chinese miracle V3.24 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0053]: 00AD:00A100000015 [HYNIX] H8BCS0PG0MBP chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (460800)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/02000000 firmware size: 32Mb ffs size: 32Mb detect sec ro... detect custom parameters... detect project-id... project-id: X10_DG628TEK_FMGB16_02S0927 detect NAND info... number of areas/bytes to read: 1:001A0000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... bootloader version: RATECH35_08B_BOOTLOADER_V005_MT6235B_X10_SK_FMJ_ML A_08S0721.bin warning: id-page1 area is invalid nfi area detection (0 cores) finished: failed TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: RATECH35_08B_PCB01_GPRS_MT6235B_S01.X10_DG628TEK_F MGB16_02S0927.BIN project-id: X10_DG628TEK_FMGB16_02S0927, 00000000 code offset: 00000000 ffs offset/size [01]: 02000000/02000000 rom info structure: [standard] type (07) TCL-ID is absent ===> done nfi area detection... bootloader version: RATECH35_08B_BOOTLOADER_V005_MT6235B_X10_SK_FMJ_ML A_08S0721.bin nfi area detection (3 cores) finished: Ok startup code area #1 check... done number of cores: 3 loading files... number of areas: 3 done write... write bootloader... . . . . write core... Format (HW_STORAGE_NAND)... Disconnect... done Finished, time used: 9 min 57 sec Remove/Install battery now ! |
The Following User Says Thank You to virgix For This Useful Post: |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
