12-04-2009, 08:11 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: Tamilnadu Age: 46
Member: 740523 Status: Offline Thanks Meter: 93 | need help Mobile function correctly...but i select pinfinder its not show rx and tx, at same time i tried without pinfiner...not show rx and tx. help me ...... how to flash with usb |
12-04-2009, 23:12 | #4 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
before searching pinout you must do 3 easy steps: 1. Make sure that this is mt62xx MCU based phone. tip: you can check this by typing *#0044# and pressing green (send) button. if you will see "language set: english"- you can be sure, that this phone is MT62xx. Now activate Silent mode in phone by pressing and holding "#". 2. Count number of pins in system connector. After this is done- pick correspondent cable. For example if you counted 2x6 pins- it is in total 12 so no point to put L14D cable instead of correct one, L12B. 3. Select cable type, connect power crocodiles in the place of battery. push "Power On!" in software. Now phone is powered with pinfinder power. Try to switch it On. This is main rule for success pinout search. (Phone must turn ON) if it does not turn On- no point to search for pinouts. you will not find it. Start from modifying your main infinity box to deliver more power to pinfinder. There is one diode which must be removed and shortcutted. Open Pinfinder User Manual on Trubleshooting section and see in pictures how this must be done. after you get phone powered- you are ready to find phone pinout. press and Hold phone power button and start search. | |
FuriousGold & NEW CABLES SET 2010 (UPDATED 30 MARS 2010) NEED HELP | FuriouS TeaM | FuriousGold | 66 | 08-27-2010 13:20 |
samsung T429 T MOBILE FLASH I NEED HELP | who_i | UST Pro II | 1 | 08-17-2010 14:30 |
need help master manole n95-8gb write screen restart | haslyn | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 15 | 03-30-2010 10:56 |
2700 flashing need help | ngaia | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 03-29-2010 11:48 |
nokia masters need help.............. | ANILMPLY | Nokia Hardware & Hardware Repair | 0 | 03-29-2010 10:48 |
