04-12-2016, 06:58 | #1 (permalink) |
No Life Poster Join Date: Sep 2009
Member: 1128573 Status: Offline Thanks Meter: 242 | need help pls. about NAND MTK6571 i have 2 samsung clone S6 G920G phone. one is bad and others good. CPU : MTK6571, NAND IC. i want to read firmware from good phone. but i can't. also i check read info but problem. read info log : Operation : Check / Read Info [ v1.45 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital Boot Ok! BB_CPU_PID : 6571 BB_CPU_NME : [MediaTek] MT6571_S00 BB_CPU_EXT : 0xCA00 , 0x8D00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x8B NAND Flash : 00EC00BC00000055005400EC00BC0000 eMMC Flash : NOT INSTALLED Initialize Memory ... DRAM already initialized by Preloader NAND FlashIC initialized [NAND] : FLASH_VEN : 0x008C , [SAMSUNG] KA100O015B_BJTT [NAND] : FLASH_DIE : 00EC 00BC 0000 0055 0054 00EC 00BC [NAND] : FLASH_LEN : 0x20000000 [NAND] : FLASH_EXT : 0800/0040/00/NIM_Px-2 DEV RID : 0411F99508C254FEDDDB41F05B659CD7 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Info read not done Erased phone or unsupported FlashIc? You can change settings : Settings -> Other -> NAND init Mode Done! Elapsed: 00:00:11 Reconnect Power/Cable! FOR YOUR KIND INFORMATION THAT I CHANGE SETTING\OTHERS\NAND INI MODE. but not done. how can i read NAND IC MTK6571 ? pls reply. thanks with best regards, mahir ashab |
The Following User Says Thank You to mahir ashab For This Useful Post: |
04-12-2016, 13:10 | #9 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Read update logs. There is clearly explained - NAND flashing not supported. FW can be flashed with SPFT well for now. |
04-12-2016, 13:50 | #10 (permalink) |
Member: 1128573 Status: Offline Thanks Meter: 242 | thanks master for reply. i have good same phone. same version 5.0.2. same cpu mtk6571. i read file by cm2. and flash by sp tools . phone flash 100 % ok . but phone is hang on logo. i make factory format by cm2. but not done. i found and download others file and flash but lcd problem. have any idea master ? can i solve ? pls reply. thanks, with best regards, mahir |
