12-11-2007, 16:15 | #1 (permalink) |
Freak Poster Join Date: Jun 2006
Member: 300690 Status: Offline Thanks Meter: 12 | Need Help For Spice S5 Unlcoking COM3 [VCP0] selected Device: Spice S5 Checking data, wait... advanced flash detection active Action: unlock unlock method: standard Boot... Press and HOLD Power button now ! Connecting, wait... Initializing[6205:8B00]... boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22022201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 115200 Set baud Done Identification... detect device identification#1... detection phase #1... . detection phase #2... ................................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found detect device identification#2 finished reading [eeprom]... file saved: C:\Program Files\InfinityBox\MModule\backup_eeprom_20071211-204813.B0E.bin flash: 01227E22022201:18E59F00000000 Identification Done Manipulation... detection procedure, wait... detection procedure completed Manipulation Done Finalization... ................................ Finalization Done Write... flash: 01227E22022201:18E59F00000000 Write: eeprom Write Done Finished, time used: 160 sec Remove/Install battery now ! |
12-12-2007, 07:48 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Use latest MModule v1.71 (but not very old 1.17 as you used) and use different unlock methods, f.e. "read codes" or "smart safe" unlock methods. |
12-12-2007, 09:12 | #3 (permalink) |
Member: 300690 Status: Offline Thanks Meter: 12 | sorry i have mistaken i used 1.71.and i changed defferent unlock methods. COM3 [VCP0] selected Action: unlock unlock method: smart fast Model: Spice S5 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 Initializing[6205:8B00]... Connecting, wait... error: can't finalize test mide repeat operation and HOLD phone "Power" button long time ! Operation failed ! Finished, time used: 21 sec Remove/Install battery now ! COM3 [VCP0] selected Action: read codes unlock method: read codes Model: Spice S5 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 Initializing[6205:8B00]... Connecting, wait... error: can't finalize test mide repeat operation and HOLD phone "Power" button long time ! Operation failed ! Finished, time used: 21 sec Remove/Install battery now ! COM3 [VCP0] selected Action: read codes unlock method: read codes Model: Spice S5 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 Initializing[6205:8B00]... Connecting, wait... error: can't finalize test mide repeat operation and HOLD phone "Power" button long time ! Operation failed ! Finished, time used: 22 sec Remove/Install battery now ! COM3 [VCP0] selected Device: Spice S5 Checking data, wait... advanced flash detection active Action: unlock unlock method: standard Boot... Press and HOLD Power button now ! Connecting, wait... Initializing[6205:8B00]... boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22022201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 115200 Set baud Done Identification... detect device identification#1... detection phase #1... . detection phase #2... ................................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found detect device identification#2 finished reading [eeprom]... file saved: C:\Program Files\InfinityBox\MModule\backup_eeprom_20071212-134526.B0E.bin flash: 01227E22022201:18E59F00000000 Identification Done Manipulation... detection procedure, wait... detection procedure completed Manipulation Done Finalization... ................................ Finalization Done Write... flash: 01227E22022201:18E59F00000000 Write: eeprom Write Done Finished, time used: 142 sec Remove/Install battery now ! when i select standerd method all the process is ok.but lock is not opened. |
12-12-2007, 10:51 | #5 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @sartaj if still no luck with unlock, please, read flash from this phone and send to [email protected] We will check what is the problem and fix it ASAP. |
12-13-2007, 06:02 | #6 (permalink) |
Member: 300690 Status: Offline Thanks Meter: 12 | i send full flash of its.plese givem me any reply. [email protected] |
12-13-2007, 11:46 | #9 (permalink) | |
Please, use this new software for your Spice-S5 unlock. Select model "Spice-S5 2007-Aug" and try to make unlock. Waiting for your results ! www.infinity-box.biz/download/public/MModule.rar | |
12-13-2007, 13:05 | #10 (permalink) |
Member: 300690 Status: Offline Thanks Meter: 12 | hello infinity team thanks for u r quick reply.but i have no luck with 1.72v. also. COM3 [VCP0] selected Device: Spice S5 2007-Aug Checking data, wait... advanced flash detection active Action: unlock unlock method: standard fast Unlock procedure can be faster if you skip eeprom area backup procedure. Do you want to disable eeprom backup ? eeprom backup disabled Boot... Press and HOLD Power button now ! Connecting, wait... Initializing[6205:8B00]... boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22022201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 115200 Set baud Done Identification... detect device identification#1... detection phase #1... . detection phase #2... ................................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found detect device identification#2 finished flash: 01227E22022201:18E59F00000000 Identification Done Manipulation... .................... lock area found Manipulation Done Finalization... ................................ Finalization Done Write... flash: 01227E22022201:18E59F00000000 flash: 01227E22022201:18E59F00000000 Write: lock-area-1 Write Done Finished, time used: 40 sec Remove/Install battery now ! COM3 [VCP0] selected Action: read codes unlock method: read codes Model: Spice S5 2007-Aug Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 Initializing[6205:8B00]... Connecting, wait... error: can't finalize test mide repeat operation and HOLD phone "Power" button long time ! Operation failed ! Finished, time used: 24 sec Remove/Install battery now ! COM3 [VCP0] selected Device: Spice S5 2007-Aug Checking data, wait... advanced flash detection active Action: unlock unlock method: standard Boot... Press and HOLD Power button now ! Connecting, wait... Initializing[6205:8B00]... boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22022201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 115200 Set baud Done Identification... detect device identification#1... detection phase #1... . detection phase #2... ................................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found detect device identification#2 finished reading [eeprom]... file saved: C:\Documents and Settings\APPLE\Desktop\backup_eeprom_20071213-173910.B0E.bin flash: 01227E22022201:18E59F00000000 Identification Done Manipulation... detection procedure, wait... detection procedure completed Manipulation Done Finalization... ................................ Finalization Done Write... flash: 01227E22022201:18E59F00000000 Write: eeprom Write Done Finished, time used: 142 sec Remove/Install battery now ! COM3 [VCP0] selected Action: read codes unlock method: read codes Model: Spice S5 2007-Aug Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 Initializing[6205:8B00]... Connecting, wait... error: can't finalize test mide repeat operation and HOLD phone "Power" button long time ! Operation failed ! Finished, time used: 22 sec Remove/Install battery now ! COM3 [VCP0] selected Action: unlock unlock method: smart fast Model: Spice S5 2007-Aug Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 Initializing[6205:8B00]... Connecting, wait... error: can't finalize test mide repeat operation and HOLD phone "Power" button long time ! Operation failed ! Finished, time used: 24 sec Remove/Install battery now ! and i formatt also.......... COM3 [VCP0] selected Device: Spice S5 2007-Aug Checking data, wait... advanced flash detection active Action: reset Boot... Press and HOLD Power button now ! Connecting, wait... Initializing[6205:8B00]... boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22022201:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 115200 Set baud Done Identification... detect device identification#1... detection phase #1... . detection phase #2... ................................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found detect device identification#2 finished reading [eeprom]... file saved: C:\Documents and Settings\APPLE\Desktop\backup_eeprom_20071213-172839.B0E.bin flash: 01227E22022201:18E59F00000000 Identification Done Manipulation... Manipulation Done Finalization... Finalization Done Write... formatting... flash: 01227E22022201:18E59F00000000 Write Done Finished, time used: 150 sec Remove/Install battery now |
12-13-2007, 14:26 | #11 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Please, read flash again after unlock try and send to me: [email protected] I'll check it again. |
12-13-2007, 14:36 | #12 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Also please, downlaod this firmware and flash phone: http://www.infinity-box.biz/download...i_ver2.B0M.bin make format after flashing. |
12-13-2007, 16:12 | #13 (permalink) |
Member: 300690 Status: Offline Thanks Meter: 12 | please dont mind infinity team if i flash with this firmware which u given here or downloade from supporting area ,after flashing if phone will not able to on.than what should i do.can i make phone as it is or not.i mean can i flash with its own backup?if can than only i will ready to flash it. |
12-13-2007, 16:28 | #14 (permalink) |
Member: 300690 Status: Offline Thanks Meter: 12 | infinity team once again i have no luck,because i flashed the phone with this firmware and formatt ffs and also same""plese insert originaAIRTEL GID-A SIM" i cant beleve this situation for" HERO OF INDIA" another thing is this software could not change even its starup logo that is "AIRTEL" |
12-13-2007, 16:46 | #15 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, please, try to flash phone with other Spice-S5 firmare from support are and see results. It looks like that firmware that was installed in your phone is very new and customized especially for Airtel, so let's try to use other firmware. Waiting for your results. |
Cable Compatible For Spice S5 For ET Box / Infinity Box / Vygis Box / Blue Box | IPMART | ipmart WebShop | 0 | 05-15-2009 11:40 |
i-Pmart BX Series RJ45 Cable For Spice S5 For ET Box / Infinity Box / Vygis Box / Blu | IPMART | ipmart WebShop | 0 | 05-15-2009 07:30 |
i need it for lg S5 2200 | hitibiti | Multi-Box | 1 | 05-01-2008 10:29 |
Need Help For Spice S545 Unlocking | sartaj | Infinity-Box | 1 | 03-12-2008 10:46 |
Need help for the MC922 S5-D2 unlock... | Mike Ho | Infineon C16X M51 & ARM7 M52 BASED | 5 | 09-26-2001 21:27 |
