08-22-2016, 07:27
#1 (permalink)
Member: 1728736
Sonork: 100.1615042 Thanks Meter: 1,098 | need iball slide 3g Q45(1 + 8 gb) firmware need iball slide 3g Q45(1 + 8 gb) firmware
read Info Quote:
Card found : S/N : B4682B40 , v0132
Chinese Miracle II [MTK module] v 1.54
Operation : Check / Read Info [ v1.54 ]
Wait for phone...
Phone found! [ 6 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6583
BB_CPU_NME : [MediaTek] MT6583|6589_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
Sending and initialize DA ...
Running DA ver.3.2 on BBID : 0x86
NAND Flash : NOT INSTALLED
eMMC Flash : 4E030188647261433F3A4220AF925639
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x88 , OEM : 0103
[eMMC] : FLASH_INF : [FORESEE] , draC
[eMMC] : FLASH_CID : 8801034E4361726420423A3F395692AF
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00020000
[eMMC] : FLASH_LEN : 0x00000001CE100000
[eMMC] : FLASH_UCP : 7393 MiB [eMMC 8 GiB]
DEV RID : 0xCC3E1F52C2F60A4E35D1A9B52BEA91C1
INT RAM : 0x00020000
EXT RAM : 0x40000000 [1 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand : iBall
ProdName : 3G Q45(1+8GB)
ProdModel : 3G Q45(1+8GB)
Device : iball89_6833b
AndroidVer: 4.4.2
MTKxCPU : MT6589
MTKxPRJ : ALPS.KK1.MP5.V1.25
SECURITY :
IMEI_SW [1] : 911436451883551
IMEI_SW [2] : 911436452083557
BTMAC Addr : 000CE72E30FC
WiFi MAC : 000A002E30FC
MODEM :
BaseBand : MT6589_S00_MOLY_WR8_W1248_MD_WG_MP_V50_P1_1_3g_n
EXTRA :
LCD [0] : KR070IG1T
LCD Res : 600x1024
TOUCH [0] : GT9XX
CAM [0] : gc2155_yuv
CAM [1] : gc0312_yuv
MODEM : miki89_tb_kk_md1_hspa_850_1900_2100_vanchip
LOCALE : en_US hi_IN mr_IN pa_IN bn_IN gu_IN ta_IN te_IN kn_IN ml_IN zh_CN zh_TW en_IN fr_FR it_IT es_ES et_EE de_DE nl_NL cs_CZ pl_PL ja_JP zh_HK ru_RU ko_KR nb_NO es_US da_DK el_GR tr_TR pt_PT pt_BR rm_CH sv_SE bg_BG ca_ES en_GB fi_FI hr_HR hu_HU iw_IL lt_LT lv_LV ro_RO sk_SK sl_SI sr_RS uk_UA vi_VN tl_PH ar_EG fa_IR th_TH sw_TZ ms_MY af_ZA zu_ZA am_ET en_XA ar_XB fr_CA km_KH lo_LA ne_NP mn_MN hy_AM az_AZ ka_GE in_ID
Done!
Elapsed: 00:00:18
Reconnect Power/Cable! | test log Quote:
Operation : HW Test [ v1.54 ]
Wait for phone...
Phone found! [ 6 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6583
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
[Processing] FlashMemory Read-Write test
[eMMC] : [FORESEE] , draC , 0x1CE100000 , 7393 MiB
[eMMC] : CID : 8801034E4361726420423A3F395692AF
[eMMC] : MODE : SQ-WR
[PASSED] : eMMC RW Check #1 Ok!
[eMMC] : MODE : RA-WR
[PASSED] : eMMC RW Check #2 Ok!
[eMMC RO CHECK] : eMMC Ok! READ-WRITE Passed!
[Processing] RAM Read-Write test
[DRAM] : 0x40000000 , 1024 MiB
[DRAM] : ADDRESS BUS test
[PASSED] : Bus Count : 0x1D
[DRAM] : DATA BUS test
[PASSED] : Bus Count : 0x1F
[DRAM] : PATTERN test
[PASSED] : PATTERN Ok
[DRAM] : INCDEC test
[PASSED] : INCDEC Ok
All Done!
Done!
Elapsed: 00:02:52
Reconnect Power/Cable! | please share tested file
condition hang on logo http://forum.gsmhosting.com/vbb/f296.../#post11989468 |
