11-02-2007, 22:29 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Ok, it's not a problem. I have prepared special instruction how to find pinout especially for your phone: Due to a lot of different models with the same name but absolutely different hardware, bottom connectors and different pinouts we recommend you to include the next info: 1. detailed description of model 2. phone CPU chip name 3. phone PCB photo (Rx/Tx/Gnd test-points may exist on phone PCB) 4. attach phone photo 5. attach phone bottom connector photo 6. include information about Gnd and Charge pins on phone bottom connector After you have this information prepared, check the next detailed description how to get pinout for your model: use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297 if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle\ if not helps, please read: http:///vbb/showpo...36&postcount=7 if not helps, please read: http:///vbb/showthread.php?t=433447 |
11-03-2007, 12:25 | #4 (permalink) | |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Quote:
Hello, Here is solution for you: http:///vbb/showpo...62&postcount=2 | |
n73 and n73music | deepaksawdia | Nokia Hardware & Hardware Repair | 5 | 09-06-2009 08:03 |
Can normal edition N73 support music edition N73 firmware? | my toh | HWK | 8 | 07-15-2009 17:33 |
1. Menu -> Settings -> Network Setup -> APN -> APN 3 -> Edit -> Enter 0000 -> EDIT "A | lukasartsDon | NEC | 1 | 03-28-2005 13:14 |
PPM edit? ok What about mcu editing? | excespeace | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 09-17-2002 23:14 |
LogoManager Business Edition and other special editions... | GeeZuZz | Nokia Multimedia | 15 | 08-09-2002 22:19 |
