need little help iam trying format some chinis phone like n96 and 97 always iam gettng this problem COM6 [VCP4] selected module v2.84 Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:6E03:0003 status: FF Connecting at 19200, wait... warning: wrong packet cs Release Power button now ! Phone detected, wait... warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: can't read software version, probably unknown firmware detecting structure #2... 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18warning: wrong packet cs 19 20 21 22 23 24 25 26 27warning: wrong packet cs 28 29error: detection failed (30 tries), read flash and send to support connection lost error: operation failed ! Finished, time used: 16 sec Remove/Install battery now ! |
do you use pinfinder? you can do format FFS complete instead. it will work for sure |
yeah i do thanks for your reply and in complete mode its works |
do you use pinfinder? i am asking because you need to modify main infinity box to make it work better with Test mode (safe format) |
yes iam using with pin finder adapter |
hello! if you remove diode from Main infinity box- you will increase output voltage and this will make boexs work better with test mode. diode removing and shortcutting is described in Pinfinder User Manual |
nice sharing.............. |
