11-26-2009, 13:38 | #1 (permalink) |
No Life Poster Join Date: Nov 2005
Member: 203352 Status: Offline Sonork: 100.1609650 Thanks Meter: 244 | need little help COM6 [VCP4] selected module v2.84 Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:6E03:0003 status: FF Connecting at 19200, wait... warning: wrong packet cs Release Power button now ! Phone detected, wait... warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs warning: can't read software version, probably unknown firmware detecting structure #2... 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18warning: wrong packet cs 19 20 21 22 23 24 25 26 27warning: wrong packet cs 28 29error: detection failed (30 tries), read flash and send to support connection lost error: operation failed ! Finished, time used: 16 sec Remove/Install battery now ! |
11-26-2009, 19:06 | #2 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,536 | Quote:
do you use pinfinder? you can do format FFS complete instead. it will work for sure | |
11-27-2009, 18:57 | #6 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,536 | hello! if you remove diode from Main infinity box- you will increase output voltage and this will make boexs work better with test mode. diode removing and shortcutting is described in Pinfinder User Manual |
need little help | the_laser | LG | 3 | 03-17-2005 23:08 |
Need little help with 7600 and 3G Network | GSMWorld | Twisterflasher | 6 | 09-11-2004 12:20 |
How to save and write back tech in BG3-need little help | SVH | BF, BG, TH, BHx Series | 3 | 12-20-2003 11:29 |
Need little help with A36 | SVH | x1x to x45/x50 | 0 | 08-10-2003 18:09 |
Need little help | questman | Sony Ericsson | 0 | 05-01-2003 14:00 |
