05-21-2009, 20:27 | #5 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! 1. set multimeter to voltage measuring. 2. check bettery voltage, it should be more than 3,7volts 3. set one multimeter probe to some grounded phone part (if you cant find grounded part outside phone- you need to take out small thin wire from negative battery terminal) 4. with second probe touch one by one all phone pins (phone battery attached) (to get better result i would advice to set needle on the end of second probe) memorise pins with voltage between 2,7-2,9volts. those are tx/rx |
Need pinout,ZTC 528,china clone????? | JHUN PANABO | Infinity-Box | 5 | 08-31-2008 06:40 |
need pinout ZTC-ZT608 | shuric | Chinese Cocktail | 2 | 08-30-2008 00:50 |
need pinout ZTC-ZT608 | shuric | Infinity-Box | 2 | 08-27-2008 17:37 |
Need Pinout Ztc 1100 | xpresson | Infinity-Box | 1 | 06-28-2008 11:57 |
need pinout ztc | ahmed14 | Multi-Box | 1 | 05-04-2008 19:15 |
