11-11-2018, 06:04 | #1 (permalink) |
No Life Poster Join Date: Jul 2008 Location: Sharja UAE
Member: 820592 Status: Offline Sonork: 100.1590378 Thanks Meter: 327 | Need Repair IMEI Of Infinix-X552-B1 Need Repair IMEI Of Infinix X552-LTE phone Received for repair WIFI+BaseBand+IMEI. I flash this file for Repair.. Now WIFI & Baseband is OK But IMEI is UNKNOWN. i try to to repair imei but No Luck... All Logs are attached.. please check and help ........ Here is Info Code: Start at : [11/10/2018 / 1:35:56 PM] Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital Boot Ok! BB_CPU_PID : 6795 BB_CPU_NME : [MediaTek] Helio[X10]|MT6795_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x92 NAND Flash : NOT INSTALLED eMMC Flash : 15010041575044335200936A4C6EB381 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , R3DPW [eMMC] : FLASH_CID : 15010041575044335200936A4C6EB381 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xD1011772B6AF57202398CE9435FED6BF INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Infinix ProdName : Infinix-X552-B1 ProdModel : Infinix Zero 3 Device : INFINIX-X552 AndroidVer: 6.0 MTKxCPU : MT6795 MTKxPRJ : X552-H952B1-M-170426V87 MODEM : BaseBand : MT6795_S00_MOLY_LR9_W1444_MD_LWTG_MP_V67_4_P10_1_lwg_n EXTRA : LCD : Not info available :( LCD Res : 1920x1080 TOUCH [0] : GT9XX CAM [0] : imx230_mipi_raw_h951_ofilm CAM [1] : ov5648_mipi_raw MODEM : rlk6795_lwt_m_lwg_4g_x552_b LOCALE : en_US zh_CN zh_TW es_ES pt_BR ru_RU fr_FR de_DE tr_TR vi_VN ms_MY in_ID th_TH it_IT ar_EG hi_IN bn_IN ur_PK fa_IR pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ ko_KR km_KH iw_IL my_MM pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB hy_AM zh_HK et_EE ja_JP kk_KZ sr_RS sl_SI ca_ES Done! Elapsed: 00:00:11 Reconnect Power/Cable! Code: Start at : [11/10/2018 / 1:37:01 PM] Operation : Repair Security [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital Boot Ok! BB_CPU_PID : 6795 BB_CPU_NME : [MediaTek] Helio[X10]|MT6795_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x92 NAND Flash : NOT INSTALLED eMMC Flash : 15010041575044335200936A4C6EB381 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , R3DPW [eMMC] : FLASH_CID : 15010041575044335200936A4C6EB381 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xD1011772B6AF57202398CE9435FED6BF INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Error on Security Repair , Code : 0x1 Make sure about mobile is working and alive! Check BaseBand state also, fix if need! Operation Failed Elapsed: 00:00:06 Reconnect Power/Cable! Finish at : [11/10/2018 / 1:37:10 PM] here is log Code: Chinese Miracle II [MTK module] v 1.58 Start at : [11/10/2018 / 1:35:00 PM] Operation : Fix Unknown BaseBand [ v1.58 ] User accepted FixBB operation! 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital Boot Ok! BB_CPU_PID : 6795 BB_CPU_NME : [MediaTek] Helio[X10]|MT6795_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x92 NAND Flash : NOT INSTALLED eMMC Flash : 15010041575044335200936A4C6EB381 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , R3DPW [eMMC] : FLASH_CID : 15010041575044335200936A4C6EB381 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 0xD1011772B6AF57202398CE9435FED6BF INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Step #1 Step #1 ... Ok Step #2 Step #2 ... Ok Step #3 Step #3 ... Ok Reset Done! Done! Elapsed: 00:00:42 Reconnect Power/Cable! Finish at : [11/10/2018 / 1:35:42 PM] |
11-19-2018, 07:37 | #2 (permalink) |
Member: 820592 Status: Offline Sonork: 100.1590378 Thanks Meter: 327 | No Reply from TEAM till Today........ today i try to repair imei with Other Box and here is log IMEI Done. Code: Definition Applied 1. Power Off Phone , Remove Battery, Insert Battery Back 2. Insert USB cable. In some cases Required Hold BootKey 3. Use Miracle Boot Key In cases Boot key not Find 4. Battery Should be Charged more then 50% Waiting for USB Port... Set Connecting to Phone,Wait.. Waiting for USB Port... Set Connecting AT Mode Meta Mode, Reading Information From the Phone... W IMEI1 OK: 8693070********* W IMEI2 OK: 8693070********* R IMEI3 OK: FFFFFFFFFFFFFF-F R IMEI4 OK: FFFFFFFFFFFFFF-F |
