03-22-2007, 16:15 | #1 (permalink) |
No Life Poster Join Date: Dec 2005 Location: India Age: 34
Member: 205788 Status: Offline Sonork: 100.1573680 Thanks Meter: 370 | need s404 spice cable i am first time making any cable so plz can any give me solution for makig cable step by step and unlocking it by video....it would be great for me and for other infinity customers who are newbie like me... |
03-22-2007, 20:24 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | how to make cable step by step hello! take any cable with RJ45 connector. make sure that pins 2,3, 8 is present. In my case this is colurs white, red, orange. Infinity box pinout is: 2 -TX 3 -RX 8- GND in our case this means that: TX is RED RX is WHITE GND is ORANGE now take Spice 404 pinout picture from our support area and connect wires according they colurs and should get this: as you can see at the point where wires goes under battery i used thin wires, so they let battery to fit in. I am sure that select program from Shell manager set phone model and comport you will be able without Video. Then just push "Unlock" if anything needs explaned more- please ask, i will edit my posting Last edited by InfinityHelp; 03-22-2007 at 20:39. |
The Following 17 Users Say Thank You to InfinityHelp For This Useful Post: |
03-23-2007, 09:00 | #4 (permalink) |
Member: 205788 Status: Offline Sonork: 100.1573680 Thanks Meter: 370 | good work thnx sir for this useful post and great help ,sir u are giving way to new ones also with this they can also do better in unlocking bussiness.... Best regards. |
04-14-2007, 18:08 | #8 (permalink) |
Banned Join Date: Jul 2006 Location: dword ptr [ebp-1C], edx
Member: 322417 Status: Offline Thanks Meter: 940 | Infinity.............. can you redirect me how can i recognize what cable is rx and what tx becouse in some cases rx is red in this case rx is white how can i recognize them thks in advice Br Formingus |
04-15-2007, 10:28 | #11 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! put multimeter in resistance measuring mode. set one pin of multimeter to pin 2 of RJ45 connector. with other multimeter pin you check one by one all wires which comes out of cable. All pins will have no connection and only one will show 0 Ohm. This wire will be number 2 of RJ45. which means box TX wire. Same way you can find RX. |
04-15-2007, 11:05 | #13 (permalink) | |
Member: 322417 Status: Offline Thanks Meter: 940 | Quote:
resistance measuring mode (See picture of Multimeter-where is?) and the other two are Rj45 and out wires of rj45 connector does i try to found in right way and about groud how can i find.. don't bore my friend i ask beacouse i don't have knowledge about those wires but with you help i think that i will learn. Then i will help others to learn and alleviate to you thks in Advice Br Formingus | |
04-15-2007, 11:19 | #15 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! photo is not clear enought, but i will try. as i can see you need to put multimeter on black mark (8 o'clock if we compare with regular clock ring). it is marked with Diode symbol. Ground is pin 7 of RJ45. As i can on picture you count pins from a right side. From left to right. |
need solution spice c5300 [cdma] | ranagaurav | Various CDMA/TDMA Cell Phones | 9 | 07-01-2012 09:24 |
need help spice s-710 | ali_imran | Infinity-Box | 3 | 09-12-2009 12:32 |
Full flash backup need for spice s8-Urgent Plz help someone. | rk_grover77 | Infinity-Box | 0 | 03-03-2008 06:33 |
Spice Cable S 500 Not Working. Cable Connection Is Wrong | shahi | Infinity-Box | 4 | 01-19-2007 09:38 |
s 600 spice cable not working | nilan | Infinity-Box | 1 | 12-27-2006 13:12 |
