09-27-2007, 15:58 | #38 (permalink) |
Freak Poster Join Date: Jan 2007 Location: usa Age: 39
Member: 438379 Status: Offline Thanks Meter: 0 | quick question: pin 2 of infinity-box is Tx (phone Rx) pin 3 of infinity-box is Rx (phone Tx) so i was a little confused...when making cable we need to connect pin 2 of infinity-box (Tx) to Rx pin on phone connector? and pin 3 of infinity-box (Rx) to Tx pin on phone connector? when using pinout diagram of any phone connector. im asking because on diagrams posted in this thread, Tx goes to Tx and Rx goes to Rx. |
09-27-2007, 17:03 | #39 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! the right way to mark pins is: tx goes to rx, rx to tx. but in our database some pinouts are recieved from our usres, who think and mark another way: tx to tx, rx to rx. so always if cable is not working- swap tx and rx with places to avoid this mistake of dubble way marking |
09-27-2007, 17:05 | #40 (permalink) | |
Freak Poster Join Date: May 2006
Member: 281925 Status: Offline Sonork: 100.113915 Thanks Meter: 63 | i with u Quote:
09-27-2007, 17:18 | #41 (permalink) |
Member: 438379 Status: Offline Thanks Meter: 0 | thanks for answer. another reason i asked because pinout for LG C2500 connector is different from Vygis box info and i know that rj45 for both infinity and vygis are the same: so just to confirm, the comments below in green are incorrect ? keyboard up /12345\ _______ 1- GND 3- TX (data from phone) 4- RX (data to phone) |
09-28-2007, 08:11 | #43 (permalink) |
Major Poster Join Date: Mar 2007
Member: 475309 Status: Offline Thanks Meter: 7 | Sir, this pinouts are of 7310 but i want to know what is connect to "+5v via 10 k resistor", can you show me in picture so i can understand easily and can make cable for this model. Cable name: ZTE-7310 connector_usb_mini-5.gif keyboard top _____ /12345\ _______ 1: Gnd 3: phone Rx (RJ45 pin-2, connect to +5v via 10k resistor) 4: phone Tx (RJ45 pin-3, connect to +5v via 10k resistor) |
09-28-2007, 09:39 | #44 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | This means: take 10 kOm resistor, connect one resistor side to phone pin and connect other resistor side to box +5v (RJ-45 pin-1) I hope it's enough detailed description. If it's not enough I think it will be very hard for you to build cable and unlock phone and you must ask help from any technical person near you (who can get required resistors and who can solder wires). |
10-03-2007, 18:08 | #45 (permalink) |
Member: 438379 Status: Offline Thanks Meter: 0 | noobie question: what does keyboard top mean in pinout info? example: mini-usb below or 18-pin connectors keyboard top _____ /12345\ _______ 1: Gnd 3: Tx 4: Rx |
need solution spice c5300 [cdma] | ranagaurav | Various CDMA/TDMA Cell Phones | 9 | 07-01-2012 09:24 |
need help spice s-710 | ali_imran | Infinity-Box | 3 | 09-12-2009 12:32 |
Full flash backup need for spice s8-Urgent Plz help someone. | rk_grover77 | Infinity-Box | 0 | 03-03-2008 06:33 |
Spice Cable S 500 Not Working. Cable Connection Is Wrong | shahi | Infinity-Box | 4 | 01-19-2007 09:38 |
s 600 spice cable not working | nilan | Infinity-Box | 1 | 12-27-2006 13:12 |
