Old 08-21-2008, 11:43   #1 (permalink)
unlock & flash's Avatar
Member: 745728
Sonork: 100.1579942
Thanks Meter: 338
need sprint s60 flash file
need sprint s60 infinity formate tested flash file
pls any one share with me
Old 08-21-2008, 15:03   #2 (permalink)
Member: 771937
Sonork: 100.1605717
Thanks Meter: 1,052
post your infinity ditels log, or read C:\Program Files\InfinityBox\ChineseMiracle
then read your phone log & post it.
Old 08-21-2008, 22:32   #3 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
yes, please post your phone software version readed in "read detailed information" mode
Old 08-22-2008, 02:51   #4 (permalink)
Member: 621121
Thanks Meter: 366
Don't detect fimware ver. I,m try with brand new sprint s60. Read full flash & eeprom no problem. Pinout same sprint 7700.
Old 08-22-2008, 21:39   #5 (permalink)
Member: 148515
hello!
try in "read general information" on powered On phone
Old 08-23-2008, 05:02   #6 (permalink)
Member: 621121
Thanks Meter: 366
cm ver 2.59
Action: read/check detailed information
Boot...
19200 fixed
Connecting, wait...
Initializing[6217:8A00]...
CPU: MT6217
high speed boot enabled
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: 01227E22212200:29EA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
460800
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detection phase #2...
warning: identification#1 information not found, possible reasons:
.old firmware type w/o identification#1 data
.damaged firmware
.damaged hardware
if phone works fine just ignore this warning
detect device identification#1 finished
detect device identification#2...
warning: optional information is not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset assigned: 00E00000
checking area[00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00800000
Detected eeprom/ffs address is non-standard: 00800000
Posible reasons:
1. eeprom is Ok but address is non-standard
2. eeprom damaged and can't be detected
3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure)
If you are not sure that detected address is correct:
1. press "NO" (and select standard address or terminate current operation)
2. make flash backup for emergency case
3. repeat required operation
Are you sure that detected eeprom address is correct ?
autodetected eeprom/ffs address[00800000] confirmed by user
detecting eeprom/ffs size...
eeprom/ffs size: 00800000
ffs chip: 00
eeprom/ffs area: 00000000:00800000-00FFFFFF
detecting ffs structure pass 1...
detect standard fat location pass #1...
detect extended fat location pass #1...
detect standard fat offset pass #1...
detect standard fat data...
fat layout detection complete
ffs element #1 detected ok
detecting ffs structure pass 2...
ffs element #2 detected ok
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
Finished, time used: 62 sec
Remove/Install battery now !
Action: read information
Model: Autodetect 6205-6227 NOR
Checking data, wait...
Phone should be Switched ON !
Connecting, wait...
baud set to: 19200
error: connection failed !
Operation failed !
Finished, time used: 78 sec
Power off phone now !
Old 08-23-2008, 13:59   #7 (permalink)
SHOEB AHMED's Avatar
Member: 161115
Sonork: Here you can find it...
Thanks Meter: 3,039
tested flash file Download Link
http://rapidshare.com/files/119233238/Sprint_S60.rar
The Following User Says Thank You to SHOEB AHMED For This Useful Post:
Old 08-23-2008, 16:40   #8 (permalink)
Member: 621121
Thanks Meter: 366
Originally Posted by SHOEB AHMED View Post
my phone is ok, but my question why don,t detect firmware version?
Old 08-23-2008, 16:49   #9 (permalink)
Member: 161115
Thanks Meter: 3,039
see....................
[COLOR="Red"]warning: identification#1 information not found, possible reasons:
.damaged firmware
.damaged hardware
if phone works fine just ignore this warning[/COLOR]
Old 08-23-2008, 21:14   #10 (permalink)
Member: 148515
hello guys!
very few phone models do not show firmware version in boot mode.
in this case "read general information" must be used
Old 11-09-2008, 13:32   #11 (permalink)
bashir telecom's Avatar
Member: 541511
Sonork: 1583582
Thanks Meter: 51
thanksssssssssssssssssssssssssssss
Old 11-17-2008, 08:54   #12 (permalink)
UNLOCK PARK ® SUPPORT's Avatar
Member: 562024
Sonork: +971506319003
Thanks Meter: 135
All time says damage file whats this???
Mahadi
Old 11-17-2008, 08:58   #13 (permalink)
Member: 745728
Sonork: 100.1579942
Thanks Meter: 338
i have infinity formate sprint s60 flash file
if need contact with me
Old 11-18-2008, 09:46   #14 (permalink)
Member: 541511
Sonork: 1583582
Thanks Meter: 51
flash unlock s60
flash file
http://rapidshare.com/files/164911784/file_S60.rar.html
loader
http://rapidshare.com/files/16491281...lodar.rar.html
Old 12-07-2008, 14:11   #15 (permalink)
Member: 445578
Thanks Meter: 440
phone is ok nice share!!!
need sprint s80 flash file sharif_tell Chinese Models & Cloned Phones 6 03-21-2010 15:05
need sprint s60 flash file pls help gsm_bds SpiderMan 1 08-15-2009 10:51
sprint s60 flash file .:ISMAIL_BD:. SpiderMan 0 08-15-2009 10:49
i need sprint s60 flash file mithon Chinese Models & Cloned Phones 3 04-24-2009 18:40
need sprint p50 flash file unlock & flash Infinity-Box 9 04-22-2009 08:36
Page generated in 0.26650 seconds with 9 queries
