10-09-2009, 21:00 | #1 (permalink) |
No Life Poster Join Date: Jul 2006 Location: INDIA,TAMILNADU,PATTUKKOTTAI
Member: 304090 Status: Offline Thanks Meter: 210 | Need unlock solution for LG NTLG600GB..NET10 infinity read this phone's firmware....(i selected kp235 model) but.....can't unlock..... here is the log COM5 [Serial2] selected module v1.36 Device: LG-KP235 Checking data, wait... advanced flash detection enabled Action: unlock unlock method: standard Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting, wait... Release Power button now ! flash: 89881600010001:89881600000000 flash: Intel Intel/Sharp ext [def 0004x008000 00FFx020000] 32Mb id: 00005258 Boot Done Set baud ... 115200 Set baud Done Check flash ... current eeprom imei: 011436002870841 file saved: C:\Program Files\InfinityBox\LgA\eeprom_011436002870841_LG-KP235_20091010-012940.B1E.bin .................................................. .............. Check flash Done Check space ... current eeprom imei: 011436002870841 .................................................. .............. finalization done Check space Done Check parameters ... Check parameters Done Erase ... Erase Done Write ... write: lock area-1 Write Done Finished, time used: 47 sec Remove/Install battery now ! any solution? |
10-09-2009, 21:18 | #2 (permalink) |
No Life Poster Join Date: Jul 2006 Location: DAVIE FLORIDA
Member: 309299 Status: Offline Thanks Meter: 259 | no solution on any box this phone got new security developed by net10 it is same tracfone company you need to change firmware to use the phone the problem is that any firmware you tried to use kill phones so dont try anything or you will end with a brick in your hand |
The Following User Says Thank You to denisirias For This Useful Post: |
i need unlock code for lg kp502 | hima010 | Phone Unlocking Codes & Maps | 4 | 03-31-2010 15:42 |
>> Need Unlock Solution for Lg ViewTV << | Faisal_Computer | VygisToolbox | 0 | 02-20-2008 07:30 |
i need repair solution for lg c2200 | patric | VygisToolbox | 2 | 10-25-2005 07:27 |
need cable solution for LG-510W | chavrotti | LG | 0 | 09-14-2004 16:47 |
i need urgent unlock solution for lg 7100 | Platijet | LG | 10 | 04-24-2004 23:02 |
