09-14-2007, 22:42 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Dear Friend, I suggest you to check this "sticky" thread: http:///vbb/showthread.php?t=398297 After you will check it you will be able to start reallt great software with name "Infinity-Box Shell" (that is not only software but also is greatest pinout/information database), select model UTStarcom-779 and see there pinout and list of compatible cables. Yes, yes, I know that everybody around so busy, so product supporter (who always has a lot of time for talks instead of programming) can make it for you. Here is information that product supporter got from great software with name "Infinity-Box Shell" especially for you: Cable name: Lobster-575 keyboard top pinout information deleted in here Similar cables: Aiko 52G Gradiente GC300 Gradiente GF760 UTstarcom GPRS758 UTstarcom GPRS778 UTstarcom GPRS779 UTstarcom GSM708 UTstarcom GSM718 Virgin_Lobster Lobster-575 Voxtel 3iD Voxtel RX11 Voxtel V350 Voxtel V500 Greetings from lazy product supporter who always has a lot of free time ! |
03-07-2008, 18:49 | #5 (permalink) |
No Life Poster Join Date: Jul 2006 Location: DAVIE FLORIDA
Member: 309299 Status: Offline Thanks Meter: 259 | i got same problem as a lot of people i see in forum, when are you going to release solution, here is log COM8 [VCP0] selected Device: UTstarcom GPRS779 Checking data, wait... Action: unlock Boot... Phone should be Switched OFF ! Press Power button now ! boot version: 00020602 connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... Check Flash Done Check Parameters... Check Parameters Done Check Space... error: unknown flash chip: 048A:EA00:3FFD:EA00 error: unknown flash chip: B510:48EF:2280:5014 error: unknown flash chip: 6646:2373:FFFF:FFFF Check Space Fail Finished, time used: 13 sec Remove/Install battery now ! |
03-07-2008, 21:32 | #6 (permalink) |
No Life Poster Join Date: Nov 2002
Member: 17362 Status: Offline Thanks Meter: 242 | UTStarcom 779 Unlock Good luck unlocking them. I have been waiting since November of 2007. This box will not unlock any of the new versions. I bought 5 boxes, was only able to do the old models. There are more newer models than old versions. You will be 1000% screwed until they make a solution for this phone. I see that there are more people in many forums with the same situation . |
03-23-2008, 23:27 | #7 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | http://www.infinity-box.biz/download...dule_v1.10.rar 1. run software 2. go to "Settings" page 3. make "Complete models list" box checked 4. try to read flash and make unlock for your UTStarcom |
03-23-2008, 23:28 | #8 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | waiting for your results: [email protected] |
03-24-2008, 01:13 | #9 (permalink) |
Freak Poster Join Date: Jan 2006 Location: peru Age: 57
Member: 215758 Status: Offline Thanks Meter: 33 | not unlock please unlock COM5 [VCP0] selected Device: UTstarcom GPRS779 "advanced chip detection" active Action: unlock Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! boot version: 00020602 connecting... Boot fail Finished, time used: 19 sec Remove/Install battery now ! ……………………………………….. COM5 [VCP0] selected Device: UTstarcom GPRS779 "advanced chip detection" active Action: read flash Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! boot version: 00020602 connecting... Boot fail Finished, time used: 19 sec Remove/Install battery now ! |
03-24-2008, 02:30 | #11 (permalink) |
Member: 215758 Status: Offline Thanks Meter: 33 | COM5 [VCP0] selected Device: UTstarcom GPRS779 Checking data, wait... Action: unlock Boot... Phone should be Switched OFF ! Press Power button now ! boot version: 00020602 connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0001:227E22212200 flash: Amd S29PL129J,S71PL129JC0,S71PL129JB0,S71PL129JA0 T 8Mb Check Space Done Check Data... error: rx block checksum mismatch error: rx block checksum mismatch error: rx block checksum mismatch error: rx block checksum mismatch error: rx block checksum mismatch error: rx block checksum mismatch error: rx block checksum mismatch error: rx block checksum mismatch error: rx block checksum mismatch error: rx block checksum mismatch error: rx block checksum mismatch error: rx block checksum mismatch error: rx block checksum mismatch error: rx block checksum mismatch error: rx block checksum mismatch error: rx block checksum mismatch error: rx block checksum mismatch error: rx block checksum mismatch error: rx block checksum mismatch error: rx block checksum mismatch error: rx block checksum mismatch error: rx block checksum mismatch error: unexpected rx block size: 001FD1/002000 error: unexpected rx block size: 0012D6/002000 it is modulo 1.10 COM5 [VCP0] selected Device: UTstarcom GPRS779 "advanced chip detection" active Action: unlock Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! boot version: 00020602 connecting... Boot fail Finished, time used: 19 sec Remove/Install battery now ! COM5 [VCP0] selected Device: UTstarcom GPRS779 "advanced chip detection" active Action: unlock Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! boot version: 00020602 connecting... Boot fail Finished, time used: 20 sec Remove/Install battery now ! |
03-24-2008, 03:23 | #13 (permalink) |
Member: 215758 Status: Offline Thanks Meter: 33 | it is paint pant COM5 [VCP0] selected Device: UTstarcom GPRS779 "advanced chip detection" active Action: unlock Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! boot version: 00020602 connecting... Boot fail Finished, time used: 21 sec Remove/Install battery now ! |
03-24-2008, 14:45 | #14 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @cmagavilano Are you sure that you have downloaded and installed latest HModule (that was just uploaded again at the same link) ? Please, download software again and try it: http://www.infinity-box.biz/download...dule_v1.10.rar |
22-03-2010: UTStarcom-GLP138GTN, UTStarcom-GPPE1238cw models supported | Pamirec | Infinity-Box | 0 | 03-22-2010 07:18 |
Utstarcom 779 digitel dont unlock | pulian | Infinity-Box | 7 | 02-07-2010 13:05 |
utstarcom gprs 779 logo | andres restrepo | Infinity-Box | 5 | 02-03-2009 20:23 |
UTstarcom 779 reset code | clerigo | Various | 0 | 08-12-2008 18:10 |
please help problem unlock utstarcom model gprs 779 | treo29 | Infinity-Box | 2 | 08-24-2007 02:25 |
