Utstarcom 779 Hi, what are the cable for Starcom 779 ???, i search in IPmart and cant find any, what model fits?? are new china model compatible??? Thanks. |
Dear Friend, I suggest you to check this "sticky" thread: http:///vbb/showthread.php?t=398297 After you will check it you will be able to start reallt great software with name "Infinity-Box Shell" (that is not only software but also is greatest pinout/information database), select model UTStarcom-779 and see there pinout and list of compatible cables. Yes, yes, I know that everybody around so busy, so product supporter (who always has a lot of time for talks instead of programming) can make it for you. Here is information that product supporter got from great software with name "Infinity-Box Shell" especially for you: Cable name: Lobster-575 keyboard top pinout information deleted in here Similar cables: Aiko 52G Gradiente GC300 Gradiente GF760 UTstarcom GPRS758 UTstarcom GPRS778 UTstarcom GPRS779 UTstarcom GSM708 UTstarcom GSM718 Virgin_Lobster Lobster-575 Voxtel 3iD Voxtel RX11 Voxtel V350 Voxtel V500 Greetings from lazy product supporter who always has a lot of free time ! |
779 Chip error Hey did you get any you cant unlock? |
Hello, We are remember about some problems with some 779, we are working about it. |
i got same problem as a lot of people i see in forum, when are you going to release solution, here is log COM8 [VCP0] selected Device: UTstarcom GPRS779 Checking data, wait... Action: unlock Boot... Phone should be Switched OFF ! Press Power button now ! boot version: 00020602 connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... Check Flash Done Check Parameters... Check Parameters Done Check Space... error: unknown flash chip: 048A:EA00:3FFD:EA00 error: unknown flash chip: B510:48EF:2280:5014 error: unknown flash chip: 6646:2373:FFFF:FFFF Check Space Fail Finished, time used: 13 sec Remove/Install battery now ! |
UTStarcom 779 Unlock Good luck unlocking them. I have been waiting since November of 2007. This box will not unlock any of the new versions. I bought 5 boxes, was only able to do the old models. There are more newer models than old versions. You will be 1000% screwed until they make a solution for this phone. I see that there are more people in many forums with the same situation . |
http://www.infinity-box.biz/download...dule_v1.10.rar 1. run software 2. go to "Settings" page 3. make "Complete models list" box checked 4. try to read flash and make unlock for your UTStarcom |
waiting for your results: [email protected] |
not unlock please unlock COM5 [VCP0] selected Device: UTstarcom GPRS779 "advanced chip detection" active Action: unlock Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! boot version: 00020602 connecting... Boot fail Finished, time used: 19 sec Remove/Install battery now ! ……………………………………….. COM5 [VCP0] selected Device: UTstarcom GPRS779 "advanced chip detection" active Action: read flash Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! boot version: 00020602 connecting... Boot fail Finished, time used: 19 sec Remove/Install battery now ! |
hello! i reuploaded one more version , download it from same link. test it and report |
COM5 [VCP0] selected Device: UTstarcom GPRS779 Checking data, wait... Action: unlock Boot... Phone should be Switched OFF ! Press Power button now ! boot version: 00020602 connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... Check Flash Done Check Parameters... Check Parameters Done Check Space... Flash: 0001:227E22212200 flash: Amd S29PL129J,S71PL129JC0,S71PL129JB0,S71PL129JA0 T 8Mb Check Space Done Check Data... error: rx block checksum mismatch error: rx block checksum mismatch error: rx block checksum mismatch error: rx block checksum mismatch error: rx block checksum mismatch error: rx block checksum mismatch error: rx block checksum mismatch error: rx block checksum mismatch error: rx block checksum mismatch error: rx block checksum mismatch error: rx block checksum mismatch error: rx block checksum mismatch error: rx block checksum mismatch error: rx block checksum mismatch error: rx block checksum mismatch error: rx block checksum mismatch error: rx block checksum mismatch error: rx block checksum mismatch error: rx block checksum mismatch error: rx block checksum mismatch error: rx block checksum mismatch error: rx block checksum mismatch error: unexpected rx block size: 001FD1/002000 error: unexpected rx block size: 0012D6/002000 it is modulo 1.10 COM5 [VCP0] selected Device: UTstarcom GPRS779 "advanced chip detection" active Action: unlock Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! boot version: 00020602 connecting... Boot fail Finished, time used: 19 sec Remove/Install battery now ! COM5 [VCP0] selected Device: UTstarcom GPRS779 "advanced chip detection" active Action: unlock Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! boot version: 00020602 connecting... Boot fail Finished, time used: 20 sec Remove/Install battery now ! |
@cmagavilano Are you sure that you have downloaded and installed latest HModule (that was just uploaded again at the same link) ? |
1 Attachment(s) it is paint pant COM5 [VCP0] selected Device: UTstarcom GPRS779 "advanced chip detection" active Action: unlock Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! boot version: 00020602 connecting... Boot fail Finished, time used: 21 sec Remove/Install battery now ! |
@cmagavilano Are you sure that you have downloaded and installed latest HModule (that was just uploaded again at the same link) ? Please, download software again and try it: http://www.infinity-box.biz/download...dule_v1.10.rar |
Problem Solved :):) Thanks Infinity Team:):) |
