01-31-2010, 09:08 | #1 (permalink) |
No Life Poster Join Date: Dec 2006
Member: 405696 Status: Offline Thanks Meter: 148 | NKTEL A200 blinking???? module v3.08 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware KCM25_GEMINI_PCB01_GPRS_MT6225_S00.K7_PBLCD_PBCAME RA_T3_V3_1__NKTEL-A200_16m_En_Ru_El_Fr_Ml_Id_Vn_Tr_Farsi_Pt_Ar.B0M.b in skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:4803:0001 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #02 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #03 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 460800 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 detecting chip #01 in region #00... flash: 98000300000001:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb otp offset: 00FE0000 it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished rom info ver: 04 sw version: KCM25_GEMINI_PCB01_GPRS_MT6225_S00.K7_PBLCD_PBCAME RA_T3_V3_1.BIN project-id: k7_PbLCD_PbCamera_T3_V3.1, 00000000 code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [standard] generation TCL-ID is absent detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: 98000300000001:18E59F00000000 checking area [00000000]: 00080000-00FFFFFF... Can't detect ffs/eeprom area Do you want to use standard ffs/eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs/eeprom address selected by user detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: KCM25_GEMINI_PCB01_GPRS_MT6225_S00.K7_PBLCD_PBCAME RA_T3_V3_1__ffs... file saved: C:\Program Files\InfinityBox\ChineseMiracle\KCM25_GEMINI_PCB0 1_GPRS_MT6225_S00.K7_PBLCD_PBCAMERA_T3_V3_1__ffs_2 0100131-124629.B0E.bin flash: 98000300000001:18E59F00000000 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... startup code area #1 fixed detecting startup code area #2... startup code area #2 is absent Area: Firmware flash: 98000300000001:18E59F00000000 Write: Firmware sec info (fast) detection... searching sec info#1... . search sec info#1 finished Write Done ====> Finalization ... Finalization Done Finished, time used: 10 min 6 sec Remove/Install battery now ! after flash still blinking???format also but same.... KCM25_GEMINI_PCB01_GPRS_MT6225_S00.K7_PBLCD_PBCAME RA_T3_V3_1__ffs_20100131-114344.B0E.bin this s software version. |
The Following User Says Thank You to Ramzan khan For This Useful Post: |
Nktel a200 | tom313rd | Infinity-Box | 64 | 01-13-2011 18:09 |
Nktel a200 pinout plzzz | tom313rd | Infinity-Box | 11 | 03-04-2010 08:17 |
nktel a200 show nktel only when flash | aukonline | Infinity-Box | 12 | 03-04-2010 05:53 |
nktel a200 firmware & eeprom | RATHNAMOBILESS | Infinity-Box | 18 | 09-15-2009 18:17 |
help me plzz nktel a200 prob | gagan_o5 | Infinity-Box | 0 | 12-13-2008 09:23 |
