06-30-2009, 08:30 | #1 (permalink) |
No Life Poster Join Date: Sep 2004
Member: 82423 Status: Offline Thanks Meter: 1,203 | NKTel A700 Boot Problem. I have NKTel A700 I want to formate with using chinese miracle latest and old version but not succes pin finder get pin out perfect 5 & 8 but not formate any idea here is logs: ==== log opened: [6/30/2009 12:27:26 PM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] Chinese Miracle v2.84 S/N: xxxx:xxxx Wait... Device: Autodetect 6205-6227 NOR Done WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== log: [6/30/2009 12:27:40 PM] ==== COM11 [VCP0] selected module v2.84 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" Boot ... Press and HOLD Power button now ! error: can't detect device Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 83 sec Remove/Install battery now ! ==== log opened: [6/30/2009 12:31:02 PM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.ex e Loading data, wait... [Infinity Box] v2.79 S/N: xxxx:xxxx Wait... Device: Autodetect 6205-6227 NOR Done WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== log: [6/30/2009 12:31:15 PM] ==== COM11 [VCP0] selected module v2.79 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" Boot ... Press and HOLD Power button now ! error: can't detect device Release Power button now ! |
06-30-2009, 08:55 | #3 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Bulgaria/China Age: 58
Member: 391664 Status: Offline Sonork: Python Thanks Meter: 1,063 | try first in case of initial connection problem: on/off "Boot baudrate autoselect" and resold the Flash and Main than try if not success so set is useless this is Quality of Chinese sets BR UMER |
06-30-2009, 13:20 | #5 (permalink) |
Member: 82423 Status: Offline Thanks Meter: 1,203 | Mate! I resold usb jack now succes here is log COM7 [VCP0] selected module v2.84 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "format ffs" Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:1F03:000B status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 98000300000000:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000000:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #02 in region #00... flash: 98000300000000:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #03 in region #00... flash: 98000300000000:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 98000300000000:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb detecting chip #01 in region #00... flash: 98000300000000:18E59F00000000 flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.9C41258C.[5800_ABROAD_PCB01_GPRS_MT6225_S00.5800_ABROAD_SPAN S_S5LCD_V1_1_4.BIN_C2955600].rpl ==================== New firmware detected (v.2.84, database date: unknown): 5800_ABROAD_PCB01_GPRS_MT6225_S00.5800_ABROAD_SPAN S_S5LCD_V1_1_4.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send "system_log_..." file to support: [email protected] - send flash backup files to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished device-id: 9C41258C identification#1 protocol ver: 04 ver. sw 1: 5800_ABROAD_PCB01_GPRS_MT6225_S00.5800_ABROAD_SPAN S_S5LCD_V1_1_4.BIN ver. sw 2: 5800_ABROAD_SPANS_S5LCD_V1.1.4, FFA96A3D ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: 98000300000000:18E59F00000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: 98000300000000:18E59F00000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: 98000300000000:18E59F00000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\5 800_ABROAD_PCB01_GPRS_MT6225_S00.5800_ABROAD_SPANS _S5LCD_V1_1_4__system_log_9C41258C_C2955600_200906 30-181140.B0X.bin Finished, time used: 66 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
The Following User Says Thank You to irfanamin2 For This Useful Post: |
NKTel C6000 charging Problem | tigerpanwar | Infinity-Box | 1 | 05-17-2010 11:37 |
E71x boot problems | emil1104 | Nokia Hardware & Hardware Repair | 0 | 03-29-2010 22:09 |
NKTel C6000 charging Problem | tigerpanwar | Chinese Models & Cloned Phones | 1 | 07-24-2009 18:35 |
NKTEL C5000 Cable Problem | irfanamin2 | Infinity-Box | 3 | 11-27-2008 10:56 |
NKTEL invaid charger problem | sigamani | Chinese Models & Cloned Phones | 2 | 09-14-2008 08:28 |
