Same problem with my phone A200, and incoming call is ok. when i dial out its just restart instant and go to searching for while... than again show operator name!
i have changed firmwares etc.. but still same issue! kindly help regarding this! matter
COM4 [VCP0] selected
module v3.10
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: reset settings ("format ffs")
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A05:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:A503:0009
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 98000300000000:18E59F00000000
flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb
otp offset: 00FE0000
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
921600
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: 2nd [enhanced] generation
TCL-ID is absent
startup code area #1 is Ok
startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.FA35E864.[N66_ABROAD_PCB01_GPRS_MT6225_S00.N66_ABROAD_2CDGB_ TAINMA_V1_6_9.BIN_BE374061].rpl
rom info detection finished
device-id: FA35E864
rom info ver: 04
sw version: N66_ABROAD_PCB01_GPRS_MT6225_S00.N66_ABROAD_2CDGB_ TAINMA_V1_6_9.BIN
project-id: N66_ABROAD_2CDGB_TAINMA_V1.6.9, 614037BE
code offset: 00000000
ffs offset/size [01]: 00E00000/00200000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
standard ffs/eeprom offset confirmed: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
reading: N66_ABROAD_PCB01_GPRS_MT6225_S00.N66_ABROAD_2CDGB_ TAINMA_V1_6_9__ffs...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\N66_ABROAD_PCB01_ GPRS_MT6225_S00.N66_ABROAD_2CDGB_TAINMA_V1_6_9__ff s_20100312-203138.B0E.bin
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\N 66_ABROAD_PCB01_GPRS_MT6225_S00.N66_ABROAD_2CDGB_T AINMA_V1_6_9__system_log_FA35E864_BE374061_2010031 2-203159.B0X.bin
Finished, time used: 2 min 9 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
