04-25-2011, 20:46 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: ! Age: 39
Member: 414755 Status: Offline Sonork: quickgsm Thanks Meter: 389 | plz infinity team Need Flash file N97 MINI Code: ==== [19/04/2011 17:26:16] ==== COM16 [VCP0] selected module v3.28 Device: Autodetect 6253 NOR Checking data, wait... Action: read firmware NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0017]: 00AD:007600AD0076 [HYNIX] HY27XS08121M chip size: 64Mb page/spare size: 0200/0010 pages per block: 0020 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (921600)... done ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/02000000 firmware size: 32Mb ffs size: 32Mb detect sec ro... detect custom parameters... detect project-id... project-id: BR35_V02.62 detect NAND info... number of areas/bytes to read: 1:00034000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... bootloader version: BENRUI35_09A_BOOTLOADER_V005_MT6235B_BR35_V02_62.bin nfi area detection (3 cores) finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... number of areas/bytes to read: 1:00004000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... number of areas/bytes to read: 1:00004000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... startup code area #1 is valid startup code area #1 detection done rom info ver: 07 sw version: BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_62.BIN project-id: BR35_V02.62, 5C38614D code offset: 00000000 ffs offset/size [01]: 02000000/02000000 rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent ===> done ==================== New firmware found (v.3.28, database date: 19.03.2011): BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_62.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== area size: 32Mb number of areas/bytes to read: 1:02000000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... file saved: C:\Documents and Settings\Administrateur\Bureau\racid\BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_62__firmware_20110319-173836.B4M.bin Disconnect... done file saved: c:\InfinityBox\ChineseMiracle\backup_security\BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_62__system_log_20110319-174033.B0X.bin Finished, time used: 14 min 17 sec Remove/Install battery now ! I Need Flash file : BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_62__f irmware_20110319-173836.B4M.bin |
04-25-2011, 21:21 | #2 (permalink) |
Member: 414755 Status: Offline Sonork: quickgsm Thanks Meter: 389 | phone CAN NOT power-on !!!! Code: COM16 [VCP0] selected module v3.30 Device: Autodetect 6253 NOR Checking data, wait... Action: write flash write: Firmware BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_62__firmware_20110319-173836.B4M.bin skip: Customization/Language Pack skip: Customization write: Eeprom/ffs BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_62__ffs_20110319-175413.B4M.bin No licensed to produce fix... warning: firmware do not have this kind of fault nor area detection... "format ffs" active interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0017]: 00AD:007600AD0076 [HYNIX] HY27XS08121M chip size: 64Mb page/spare size: 0200/0010 pages per block: 0020 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (921600)... done ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... detect sec ro... detect custom parameters... detect project-id... detect NAND info... number of areas/bytes to read: 1:00034000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... warning: header is empty: probably flash chip completely erased warning: can not detect header nfi area detection (0 cores) finished: failed warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done code offset: 00000000 ===> done startup code area #1 check... rpl file not found: C:\InfinityBox\ChineseMiracle\id.00006235.[BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_62.BIN_4D61385C].rpl rpl file not found: C:\InfinityBox\ChineseMiracle\id.00006235._BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_62.BIN_4D61385C_.rpl rpl file not found: C:\InfinityBox\ChineseMiracle\backup_security\id.00006235.[BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_62.BIN_4D61385C].rpl rpl file not found: C:\InfinityBox\ChineseMiracle\backup_security\id.00006235._BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_62.BIN_4D61385C_.rpl ==================== warning: unknown firmware: BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_62.BIN_4D61385C Unknown firmware found (v.3.30, database date: 17.04.2011), user action required: 1. download latest software from support area and try again 2. if no still luck follow the next procedure: - find good working phone with the same firmware: BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_62.BIN - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) - be little bit patient and wait update ==================== error: startup code area #1 can't be fixed You can flash phone now but can not finalize it, in most cases phone CAN NOT power-on. Do you want to continue anyway ? number of cores: 2 loading files... number of areas: 2 done write... error: can not write flash (0): 0C3A:S_DA_NFB_TARGET_IS_SINGLE_BL_BUT_PC_NOT error: last error: 0C3A:S_DA_NFB_TARGET_IS_SINGLE_BL_BUT_PC_NOT Disconnect... done Finished, time used: 1 min 12 sec Remove/Install battery now ! |
04-25-2011, 21:30 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Download files from Infinity-Box support area: \flashfiles\1MTK\_MT6235\BENRUI35_09A_PCB01_GPRS_M T6235B_S01.BR35_N90_T_V01_20__Nokia-N97_64m_En_Ru_Nl_Fr_Es_It_Ml_Id_Vn_Tr_Pt.B4M.bin \flashfiles\1MTK\_MT6235\BENRUI35_09A_PCB01_GPRS_M T6235B_S01.BR35_V00_32__N97_2010-01-15_64m_En_Ru_Nl_Fr_Es_It_Ml_Id_Th_Vn_Tr_Farsi_Pt_A r.B4M.bin \flashfiles\1MTK\_MT6235\BENRUI35_09A_PCB01_GPRS_M T6235B_S01.BR35_V02_07_2010-05-12_09A_BENRUI35_09A_128m_En_Cn.B4M.bin \flashfiles\1MTK\_MT6235\BENRUI35_09A_PCB01_GPRS_M T6235B_S01.BR35_V02_21__NOKIA-N97_2010-05-21_64m_En_Ru_Nl_Fr_Es_It_Ml_Id_Th_Vn_Tr_Farsi_Pt_C z_Cn_Ar.B4M.bin \flashfiles\1MTK\_MT6235\BENRUI35_09A_PCB01_GPRS_M T6235B_S01.BR35_V02_65_2010-12-10_64m_En_Cn.B4M.bin \flashfiles\1MTK\_MT6235\BENRUI35_09A_PCB01_GPRS_M T6235B_S01.BR35_V06_69__NOKIA-N8_2010-11-18_64m_En_Cn.B4M.bin \flashfiles\1MTK\_MT6235\BENRUI35_09A_PCB01_GPRS_M T6235B_S01.BR35_V06_75__NOKIA-N8_2010-12-01_64m_En_Ru_Nl_Fr_Es_It_Ml_Id_Th_Vn_Tr_Farsi_Pt_C z_Cn_Ar.B4M.bin \flashfiles\1MTK\_MT6235\BENRUI35_09A_PCB01_GPRS_M T6235B_S01.BR35_V07_02__NOKIA-N8_2010-12-24_64m_En_Ru_Nl_Fr_Es_It_Ml_Id_Th_Vn_Tr_Farsi_Pt_C z_Cn_Ar.B4M.bin |
04-25-2011, 21:47 | #4 (permalink) | |
Member: 414755 Status: Offline Sonork: quickgsm Thanks Meter: 389 | Quote:
You can flash phone now but can not finalize it, in most cases phone CAN NOT power-on. Do you want to continue anyway ? number of cores: 2 loading files... number of areas: 2 done write... error: can not write flash (0): 0C3A:S_DA_NFB_TARGET_IS_SINGLE_BL_BUT_PC_NOT error: last error: 0C3A:S_DA_NFB_TARGET_IS_SINGLE_BL_BUT_PC_NOT Disconnect... done Finished, time used: 1 min 12 sec Remove/Install battery now ! | |
04-27-2011, 11:06 | #6 (permalink) | |
yes im sure is working bifor 1000/100 his dead after flashing for change language , i set flash 100% but do not power on any solution??? all operation log : [CODE] ==== C:\InfinityBox\ChineseMiracle\ChineseMiracle.exe [19/03/2011 16:41:32] ==== http://www.infinity-box.com Loading data, wait... [Infinity Box] Chinese Miracle v3.28 smart-card: connected S/N: 9EF1:0116 Wait... Device: Autodetect 6205-6239 NOR Done ==== c:\InfinityBox\ChineseMiracle\ChineseMiracle.exe [19/03/2011 16:42:50] ==== http://www.infinity-box.com Loading data, wait... [Infinity Box] Chinese Miracle v3.28 smart-card: connected S/N: 9EF1:0116 Wait... Device: Autodetect 6205-6239 NOR Done Action: read/check information Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... error: connection failed ! If you are sure that cable is good - select another baudrate (f.e. set baudrate to "autodetect") operation failed ! Finished, time used: 37 sec Remove/Install battery now ! Action: read/check information Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... error: connection failed ! If you are sure that cable is good - select another baudrate (f.e. set baudrate to "autodetect") operation failed ! Finished, time used: 12 min 49 sec Remove/Install battery now ! ==== c:\InfinityBox\ChineseMiracle\ChineseMiracle.exe [19/03/2011 17:20:45] ==== http://www.infinity-box.com Loading data, wait... [Infinity Box] Chinese Miracle v3.28 smart-card: connected S/N: 9EF1:0116 Wait... Device: Autodetect 6205-6239 NOR Done Action: read/check information Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... error: connection failed ! If you are sure that cable is good - select another baudrate (f.e. set baudrate to "autodetect") operation failed ! Finished, time used: 1 min 8 sec Remove/Install battery now ! Action: read/check information Model: Autodetect 6205-6239 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6235, E04 Hardware version: BR35_09A_HW Software version: BR35_V02.62" Software date: 2000.00.00 Barcode: 111701MTk1111111111_183008 imei-1: 358666166125339 imei-2: 354601020318751 imei-3: 358666166125339 Finished, time used: 13 sec Remove/Install battery now ! ==== [19/03/2011 17:22:45] ==== COM16 [VCP0] selected module v3.28 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: read flash ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6235:8A04:8A01]... CPU: MT6235 high speed boot On chip: 0000:0000:0003 status: FF boot packet size: 0400 Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 21 sec Remove/Install battery now ! ==== [19/03/2011 17:23:30] ==== COM16 [VCP0] selected module v3.28 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: read flash ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6235:8A04:8A01]... CPU: MT6235 high speed boot On chip: 0000:0000:0003 status: FF boot packet size: 0400 Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 13 sec Remove/Install battery now ! ==== [19/03/2011 17:24:12] ==== COM16 [VCP0] selected module v3.28 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: read firmware ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6235:8A04:8A01]... CPU: MT6235 high speed boot Off chip: 0000:0000:0003 status: FF high speed boot Off boot packet size: 0400 Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 20 sec Remove/Install battery now ! ==== [19/03/2011 17:24:43] ==== COM16 [VCP0] selected module v3.28 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: read firmware ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6235:8A04:8A01]... CPU: MT6235 high speed boot Off chip: 0000:0000:0003 status: FF high speed boot Off boot packet size: 0400 Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 18 sec Remove/Install battery now ! ==== [19/03/2011 17:25:21] ==== COM16 [VCP0] selected module v3.28 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: read flash ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6235:8A04:8A01]... CPU: MT6235 high speed boot Off chip: 0000:0000:0003 status: FF high speed boot Off boot packet size: 0400 Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 22 sec Remove/Install battery now ! Device: Autodetect 6253 NOR ==== [19/03/2011 17:26:16] ==== COM16 [VCP0] selected module v3.28 Device: Autodetect 6253 NOR Checking data, wait... Action: read firmware NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0017]: 00AD:007600AD0076 [HYNIX] HY27XS08121M chip size: 64Mb page/spare size: 0200/0010 pages per block: 0020 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (921600)... done ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/02000000 firmware size: 32Mb ffs size: 32Mb detect sec ro... detect custom parameters... detect project-id... project-id: BR35_V02.62 detect NAND info... number of areas/bytes to read: 1:00034000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... bootloader version: BENRUI35_09A_BOOTLOADER_V005_MT6235B_BR35_V02_62.b in nfi area detection (3 cores) finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... number of areas/bytes to read: 1:00004000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... number of areas/bytes to read: 1:00004000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... startup code area #1 is valid startup code area #1 detection done rom info ver: 07 sw version: BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_62.BI N project-id: BR35_V02.62, 5C38614D code offset: 00000000 ffs offset/size [01]: 02000000/02000000 rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent ===> done ==================== New firmware found (v.3.28, database date: 19.03.2011): BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_62.BI N This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== area size: 32Mb number of areas/bytes to read: 1:02000000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... file saved: C:\Documents and Settings\Administrateur\Bureau\racid\BENRUI35_09A_ PCB01_GPRS_MT6235B_S01.BR35_V02_62__firmware_20110 319-173836.B4M.bin Disconnect... done file saved: c:\InfinityBox\ChineseMiracle\backup_security\BENR UI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_62__syste m_log_20110319-174033.B0X.bin Finished, time used: 14 min 17 sec Remove/Install battery now ! ==== [19/03/2011 17:41:31] ==== COM16 [VCP0] selected module v3.28 Device: Autodetect 6253 NOR Checking data, wait... Action: read ffs/eeprom NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0017]: 00AD:007600AD0076 [HYNIX] HY27XS08121M chip size: 64Mb page/spare size: 0200/0010 pages per block: 0020 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (921600)... done ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/02000000 firmware size: 32Mb ffs size: 32Mb detect sec ro... detect custom parameters... detect project-id... project-id: BR35_V02.62 detect NAND info... number of areas/bytes to read: 1:00034000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... bootloader version: BENRUI35_09A_BOOTLOADER_V005_MT6235B_BR35_V02_62.b in nfi area detection (3 cores) finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... number of areas/bytes to read: 1:00004000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... number of areas/bytes to read: 1:00004000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... startup code area #1 is valid startup code area #1 detection done rom info ver: 07 sw version: BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_62.BI N project-id: BR35_V02.62, 5C38614D code offset: 00000000 ffs offset/size [01]: 02000000/02000000 rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent ===> done ==================== New firmware found (v.3.28, database date: 19.03.2011): BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_62.BI N This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== area size: 32Mb number of areas/bytes to read: 1:02000000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... file saved: C:\Documents and Settings\Administrateur\Bureau\racid\BENRUI35_09A_ PCB01_GPRS_MT6235B_S01.BR35_V02_62__ffs_20110319-175413.B4M.bin Disconnect... done file saved: c:\InfinityBox\ChineseMiracle\backup_security\BENR UI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_62__syste m_log_20110319-175428.B0X.bin Finished, time used: 12 min 57 sec Remove/Install battery now ! ==== c:\InfinityBox\ChineseMiracle\ChineseMiracle.exe [19/03/2011 18:07:41] ==== http://www.infinity-box.com Loading data, wait... [Infinity Box] Chinese Miracle v3.28 smart-card: connected S/N: 9EF1:0116 Wait... Device: Autodetect 6205-6239 NOR Done Device: Autodetect 6253 NOR Loading file v.05... E320M00_PCB01_GPRS_MT6235B_S01.M_RE3215107_M00201_ V1_0_0_0M0818_2010-08-31_Memory-NAND512+DDR256__Hang-Jiang-N97-Mini_128m_En_Ru_Gr_Fr_Es_It_De_Ml_Id_Th_Vn_Tr_Fars i_Pt_Ar.B4M.bin loaded usb bootloader (file) is absent rom info ver: 07 sw version: E320M00_PCB01_GPRS_MT6235B_S01.M_RE3215107_M00201_ V1_0_0_0M0818.BIN project-id: M.RE3215107.M00201.V1.1.0.0M0831, 00000000 code offset: 00000000 ffs offset/size [01]: 02800000/05800000 rom info structure: [standard] type (07) TCL-ID is absent firmware date/time: 2010-08-31 13-22 hw1: REBOUND35_08B_HW hw2: Memory-NAND512+DDR256 ==== [19/03/2011 18:09:12] ==== COM16 [VCP0] selected module v3.28 Device: Autodetect 6253 NOR Checking data, wait... Action: write flash write: Firmware E320M00_PCB01_GPRS_MT6235B_S01.M_RE3215107_M00201_ V1_0_0_0M0818_2010-08-31_Memory-NAND512+DDR256__Hang-Jiang-N97-Mini_128m_En_Ru_Gr_Fr_Es_It_De_Ml_Id_Th_Vn_Tr_Fars i_Pt_Ar.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nor area detection... interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0017]: 00AD:007600AD0076 [HYNIX] HY27XS08121M chip size: 64Mb page/spare size: 0200/0010 pages per block: 0020 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (921600)... done ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/02000000 firmware size: 32Mb ffs size: 32Mb detect sec ro... detect custom parameters... detect project-id... project-id: BR35_V02.62 detect NAND info... number of areas/bytes to read: 1:00034000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... bootloader version: BENRUI35_09A_BOOTLOADER_V005_MT6235B_BR35_V02_62.b in nfi area detection (3 cores) finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... number of areas/bytes to read: 1:00004000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... number of areas/bytes to read: 1:00004000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... startup code area #1 is valid startup code area #1 detection done rom info ver: 07 sw version: BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_62.BI N project-id: BR35_V02.62, 5C38614D code offset: 00000000 ffs offset/size [01]: 02000000/02000000 rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent ===> done ==================== New firmware found (v.3.28, database date: 19.03.2011): BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_62.BI N This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== startup code area #1 check... done number of cores: 1 loading files... number of areas: 1 done write... write core... Disconnect... done file saved: c:\InfinityBox\ChineseMiracle\backup_security\BENR UI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_62__syste m_log_20110319-182211.B0X.bin Finished, time used: 13 min 0 sec Remove/Install battery now ! Loading file v.02... BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_62__f irmware_20110319-173836.B4M.bin loaded usb bootloader (file) is absent rom info ver: 07 sw version: BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_62.BI N project-id: BR35_V02.62, 5C38614D code offset: 00000000 ffs offset/size [01]: 02000000/02000000 rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent file w/protection: startup code area #1 firmware date/time: 2010-11-08 19-01 hw1: BR35_09A_HW hw2: 09A_60_BENRUI35_09A Loading file v.02... BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_62__f fs_20110319-175413.B4M.bin loaded ==== [19/03/2011 19:25:31] ==== COM16 [VCP0] selected module v3.28 Device: Autodetect 6253 NOR Checking data, wait... Action: write flash write: Firmware BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_62__f irmware_20110319-173836.B4M.bin skip: Customization/Language Pack skip: Customization write: Eeprom/ffs BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_62__f fs_20110319-175413.B4M.bin nor area detection... "format ffs" active interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0017]: 00AD:007600AD0076 [HYNIX] HY27XS08121M chip size: 64Mb page/spare size: 0200/0010 pages per block: 0020 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (921600)... done ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02800000/05800000 firmware size: 40Mb ffs size: 88Mb detect sec ro... detect custom parameters... detect project-id... project-id: M.RE3215107.M00201.V1.1.0.0M0831 detect NAND info... number of areas/bytes to read: 1:00034000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... warning: core offset is not detected nfi area detection (0 cores) finished: failed TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: E320M00_PCB01_GPRS_MT6235B_S01.M_RE3215107_M00201_ V1_0_0_0M0818.BIN project-id: M.RE3215107.M00201.V1.1.0.0M0831, 00000000 code offset: 00000000 ffs offset/size [01]: 02800000/05800000 rom info structure: [standard] type (07) TCL-ID is absent ===> done startup code area #1 check... rpl file not found: c:\InfinityBox\ChineseMiracle\id.00006235.[BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_62.BI N_4D61385C].rpl rpl file not found: c:\InfinityBox\ChineseMiracle\id.00006235._BENRUI3 5_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_62.BIN_4D613 85C_.rpl rpl file not found: c:\InfinityBox\ChineseMiracle\backup_security\id.0 0006235.[BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_62.BI N_4D61385C].rpl rpl file not found: c:\InfinityBox\ChineseMiracle\backup_security\id.0 0006235._BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_ V02_62.BIN_4D61385C_.rpl ==================== warning: unknown firmware: BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_62.BI N_4D61385C Unknown firmware found (v.3.28, database date: 19.03.2011), user action required: 1. download latest software from support area and try again 2. if no still luck follow the next procedure: - find good working phone with the same firmware: BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_62.BI N - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) - be little bit patient and wait update ==================== error: startup code area #1 can't be fixed You can flash phone now but can not finalize it, in most cases phone CAN NOT power-on. Do you want to continue anyway ? number of cores: 2 loading files... number of areas: 2 done write... write core... error: can not write flash (57): 0FAF:S_FT_NFB_DOWNLOAD_CODE_FAIL error: last error: 0FAF:S_FT_NFB_DOWNLOAD_CODE_FAIL Disconnect... done Finished, time used: 14 min 19 sec Remove/Install battery now ! ==== [19/03/2011 19:40:21] ==== COM16 [VCP0] selected module v3.28 Device: Autodetect 6253 NOR Checking data, wait... Action: write flash write: Firmware BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_62__f irmware_20110319-173836.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nor area detection... interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0017]: 00AD:007600AD0076 [HYNIX] HY27XS08121M chip size: 64Mb page/spare size: 0200/0010 pages per block: 0020 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (921600)... done ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/02000000 firmware size: 32Mb ffs size: 32Mb detect sec ro... detect custom parameters... detect project-id... project-id: BR35_V02.62 detect NAND info... number of areas/bytes to read: 1:00034000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... warning: core offset is not detected nfi area detection (0 cores) finished: failed ffs offset/size assigned: 02000000/02000000 TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done code offset: 00000000 ffs offset/size [02]: 02000000/02000000 ===> done ==================== New firmware found (v.3.28, database date: 19.03.2011): This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== area size: 32Mb number of areas/bytes to read: 1:02000000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... file saved: C:\InfinityBox\ChineseMiracle\_firmware_20110319-195242.B4M.bin startup code area #1 check... rpl file not found: c:\InfinityBox\ChineseMiracle\id.00006235.[BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_62.BI N_4D61385C].rpl rpl file not found: c:\InfinityBox\ChineseMiracle\id.00006235._BENRUI3 5_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_62.BIN_4D613 85C_.rpl rpl file not found: c:\InfinityBox\ChineseMiracle\backup_security\id.0 0006235.[BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_62.BI N_4D61385C].rpl rpl file not found: c:\InfinityBox\ChineseMiracle\backup_security\id.0 0006235._BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_ V02_62.BIN_4D61385C_.rpl ==================== warning: unknown firmware: BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_62.BI N_4D61385C Unknown firmware found (v.3.28, database date: 19.03.2011), user action required: 1. download latest software from support area and try again 2. if no still luck follow the next procedure: - find good working phone with the same firmware: BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_62.BI N - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) - be little bit patient and wait update ==================== error: startup code area #1 can't be fixed You can flash phone now but can not finalize it, in most cases phone CAN NOT power-on. Do you want to continue anyway ? number of cores: 1 loading files... number of areas: 1 done write... write core... Disconnect... done Finished, time used: 22 min 32 sec Remove/Install battery now ! ==== c:\InfinityBox\ChineseMiracle\ChineseMiracle.exe [19/03/2011 20:50:37] ==== http://www.infinity-box.com Loading data, wait... [Infinity Box] Chinese Miracle v3.28 smart-card: connected S/N: 9EF1:0116 Wait... Device: Autodetect 6205-6239 NOR Done Loading file v.05... BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_21__N OKIA-N97_2010-05-21_64m_En_Ru_Nl_Fr_Es_It_Ml_Id_Th_Vn_Tr_Farsi_Pt_C z_Cn_Ar.B4M.bin loaded usb bootloader (file) is absent rom info ver: 07 sw version: BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_21.BI N project-id: BR35_V02.21, A9E80E6C code offset: 00000000 ffs offset/size [01]: 02000000/02000000 rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent file w/protection: startup code area #1 firmware date/time: 2010-05-21 14-03 hw1: BR35_09A_HW hw2: 09A_5_BENRUI35_09A ==== [19/03/2011 20:51:27] ==== COM16 [VCP0] selected module v3.28 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_21__N OKIA-N97_2010-05-21_64m_En_Ru_Nl_Fr_Es_It_Ml_Id_Th_Vn_Tr_Farsi_Pt_C z_Cn_Ar.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6235:8A04:8A01]... CPU: MT6235 high speed boot On chip: 0000:0000:0003 status: FF boot packet size: 0400 Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 15 sec Remove/Install battery now ! ==== [19/03/2011 20:52:16] ==== COM16 [VCP0] selected module v3.28 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_21__N OKIA-N97_2010-05-21_64m_En_Ru_Nl_Fr_Es_It_Ml_Id_Th_Vn_Tr_Farsi_Pt_C z_Cn_Ar.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6235:8A04:8A01]... CPU: MT6235 high speed boot On chip: 0000:0000:0003 status: FF boot packet size: 0400 Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 15 sec Remove/Install battery now ! ==== c:\InfinityBox\ChineseMiracle\ChineseMiracle.exe [19/03/2011 20:53:08] ==== http://www.infinity-box.com Loading data, wait... [Infinity Box] Chinese Miracle v3.28 smart-card: connected S/N: 9EF1:0116 Wait... Device: Autodetect 6205-6239 NOR Done Device: Autodetect 6253 NOR Loading file v.05... BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_21__N OKIA-N97_2010-05-21_64m_En_Ru_Nl_Fr_Es_It_Ml_Id_Th_Vn_Tr_Farsi_Pt_C z_Cn_Ar.B4M.bin loaded usb bootloader (file) is absent rom info ver: 07 sw version: BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_21.BI N project-id: BR35_V02.21, A9E80E6C code offset: 00000000 ffs offset/size [01]: 02000000/02000000 rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent file w/protection: startup code area #1 firmware date/time: 2010-05-21 14-03 hw1: BR35_09A_HW hw2: 09A_5_BENRUI35_09A ==== [19/03/2011 20:53:48] ==== COM16 [VCP0] selected module v3.28 Device: Autodetect 6253 NOR Checking data, wait... Action: write flash write: Firmware BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_21__N OKIA-N97_2010-05-21_64m_En_Ru_Nl_Fr_Es_It_Ml_Id_Th_Vn_Tr_Farsi_Pt_C z_Cn_Ar.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nor area detection... interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0017]: 00AD:007600AD0076 [HYNIX] HY27XS08121M chip size: 64Mb page/spare size: 0200/0010 pages per block: 0020 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (921600)... done ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/02000000 firmware size: 32Mb ffs size: 32Mb detect sec ro... detect custom parameters... detect project-id... project-id: BR35_V02.62 detect NAND info... number of areas/bytes to read: 1:00034000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... warning: core offset is not detected nfi area detection (0 cores) finished: failed TCL-ID detection... TCL-ID detection done startup code area #1 detection... number of areas/bytes to read: 1:00004000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... number of areas/bytes to read: 1:00004000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... startup code area #1 is invalid startup code area #1 detection done rom info ver: 07 sw version: BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_62.BI N project-id: BR35_V02.62, 5C38614D code offset: 00000000 ffs offset/size [01]: 02000000/02000000 rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent ===> done startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed number of cores: 1 loading files... number of areas: 1 done write... write core... Disconnect... done Finished, time used: 10 min 18 sec Remove/Install battery now ! ==== c:\InfinityBox\ChineseMiracle\ChineseMiracle.exe [19/03/2011 21:06:53] ==== http://www.infinity-box.com Loading data, wait... [Infinity Box] Chinese Miracle v3.28 smart-card: connected S/N: 9EF1:0116 Wait... Device: Autodetect 6205-6239 NOR Done Device: Autodetect 6253 NOR WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? ==== [19/03/2011 21:07:12] ==== COM16 [VCP0] selected module v3.28 Device: Autodetect 6253 NOR Checking data, wait... Action: reset settings ("format ffs") NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0017]: 00AD:007600AD0076 [HYNIX] HY27XS08121M chip size: 64Mb page/spare size: 0200/0010 pages per block: 0020 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (921600)... done ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/02000000 firmware size: 32Mb ffs size: 32Mb detect sec ro... detect custom parameters... detect project-id... project-id: BR35_V02.21 detect NAND info... number of areas/bytes to read: 1:00034000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... warning: core offset is not detected nfi area detection (0 cores) finished: failed TCL-ID detection... TCL-ID detection done startup code area #1 detection... number of areas/bytes to read: 1:00004000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... number of areas/bytes to read: 1:00004000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... startup code area #1 is invalid startup code area #1 detection done rom info ver: 07 sw version: BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_21.BI N project-id: BR35_V02.21, A9E80E6C code offset: 00000000 ffs offset/size [01]: 02000000/02000000 rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent ===> done warning: can not format: HW_STORAGE_NOR is not present Format... Disconnect... done Finished, time used: 42 sec Remove/Install battery now ! Loading file v.05... ==== c:\InfinityBox\ChineseMiracle\ChineseMiracle.exe [19/03/2011 21:10:43] ==== http://www.infinity-box.com Loading data, wait... [Infinity Box] Chinese Miracle v3.28 smart-card: can not be found/connected error: Dongle is not found Dongle is not found ! Connect Dongle and restart software. ==== c:\InfinityBox\ChineseMiracle\ChineseMiracle.exe [19/03/2011 21:10:58] ==== http://www.infinity-box.com Loading data, wait... [Infinity Box] Chinese Miracle v3.28 smart-card: connected S/N: 9EF1:0116 Wait... Device: Autodetect 6205-6239 NOR Done Device: Autodetect 6253 NOR Loading file v.05... BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_65_20 10-12-10_64m_En_Cn.B4M.bin loaded usb bootloader (file) is absent rom info ver: 07 sw version: BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_65.BI N project-id: BR35_V02.65, 90B9F97C code offset: 00000000 ffs offset/size [01]: 02000000/02000000 rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent file w/protection: startup code area #1 firmware date/time: 2010-12-10 16-33 hw1: BR35_09A_HW hw2: 09A_65_BENRUI35_09A ==== [19/03/2011 21:11:28] ==== COM19 [VCP2] selected module v3.28 Device: Autodetect 6253 NOR Checking data, wait... Action: write flash write: Firmware BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_65_20 10-12-10_64m_En_Cn.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nor area detection... interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! error: can not boot device: 03E8:S_STOP error: last error: 03E8:S_STOP Disconnect... done Finished, time used: 43 sec Remove/Install battery now ! ==== c:\InfinityBox\ChineseMiracle\ChineseMiracle.exe [19/03/2011 21:12:30] ==== http://www.infinity-box.com Loading data, wait... [Infinity Box] Chinese Miracle v3.28 smart-card: connected S/N: 9EF1:0116 Wait... Device: Autodetect 6205-6239 NOR Done Device: Autodetect 6253 NOR COM16 ready Loading file v.05... BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_65_20 10-12-10_64m_En_Cn.B4M.bin loaded usb bootloader (file) is absent rom info ver: 07 sw version: BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_65.BI N project-id: BR35_V02.65, 90B9F97C code offset: 00000000 ffs offset/size [01]: 02000000/02000000 rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent file w/protection: startup code area #1 firmware date/time: 2010-12-10 16-33 hw1: BR35_09A_HW hw2: 09A_65_BENRUI35_09A ==== [19/03/2011 21:13:16] ==== COM16 [VCP4] selected module v3.28 Device: Autodetect 6253 NOR Checking data, wait... Action: write flash write: Firmware BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_65_20 10-12-10_64m_En_Cn.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nor area detection... "format ffs" active interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! error: can not boot device: 03E8:S_STOP error: last error: 03E8:S_STOP Disconnect... done Finished, time used: 32 sec Remove/Install battery now ! COM19 ready COM19 ready ==== [19/03/2011 21:14:08] ==== COM19 [VCP2] selected module v3.28 Device: Autodetect 6253 NOR Checking data, wait... Action: write flash write: Firmware BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_65_20 10-12-10_64m_En_Cn.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nor area detection... "format ffs" active interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! ==== c:\InfinityBox\ChineseMiracle\ChineseMiracle.exe [19/03/2011 21:24:07] ==== http://www.infinity-box.com Loading data, wait... [Infinity Box] Chinese Miracle v3.28 smart-card: connected S/N: 9EF1:0116 Wait... Device: Autodetect 6205-6239 NOR Done Device: Autodetect 6253 NOR COM16 ready Loading file v.05... BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_65_20 10-12-10_64m_En_Cn.B4M.bin loaded usb bootloader (file) is absent rom info ver: 07 sw version: BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_65.BI N project-id: BR35_V02.65, 90B9F97C code offset: 00000000 ffs offset/size [01]: 02000000/02000000 rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent file w/protection: startup code area #1 firmware date/time: 2010-12-10 16-33 hw1: BR35_09A_HW hw2: 09A_65_BENRUI35_09A ==== [19/03/2011 21:26:28] ==== COM16 [VCP0] selected module v3.28 Device: Autodetect 6253 NOR Checking data, wait... Action: write flash write: Firmware BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_65_20 10-12-10_64m_En_Cn.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nor area detection... "format ffs" active interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0017]: 00AD:007600AD0076 [HYNIX] HY27XS08121M chip size: 64Mb page/spare size: 0200/0010 pages per block: 0020 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (921600)... done ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/02000000 firmware size: 32Mb ffs size: 32Mb detect sec ro... detect custom parameters... detect project-id... project-id: BR35_V02.21 detect NAND info... number of areas/bytes to read: 1:00034000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... warning: core offset is not detected nfi area detection (0 cores) finished: failed TCL-ID detection... TCL-ID detection done startup code area #1 detection... number of areas/bytes to read: 1:00004000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... number of areas/bytes to read: 1:00004000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... startup code area #1 is invalid startup code area #1 detection done rom info ver: 07 sw version: BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_21.BI N project-id: BR35_V02.21, A9E80E6C code offset: 00000000 ffs offset/size [01]: 02000000/02000000 rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent ===> done startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed number of cores: 1 loading files... number of areas: 1 done write... write core... warning: can not format: HW_STORAGE_NOR is not present Format... Disconnect... done Finished, time used: 10 min 7 sec Remove/Install battery now ! ==== c:\InfinityBox\ChineseMiracle\ChineseMiracle.exe [20/03/2011 01:48:06] ==== http://www.infinity-box.com Loading data, wait... [Infinity Box] Chinese Miracle v3.28 smart-card: connected S/N: 0343:0116 Wait... Device: Autodetect 6205-6239 NOR Done Loading file v.02... BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_62__f irmware_20110319-173836.B4M.bin loaded usb bootloader (file) is absent rom info ver: 07 sw version: BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_62.BI N project-id: BR35_V02.62, 5C38614D code offset: 00000000 ffs offset/size [01]: 02000000/02000000 rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent file w/protection: startup code area #1 firmware date/time: 2010-11-08 19-01 hw1: BR35_09A_HW hw2: 09A_60_BENRUI35_09A COM16 ready ==== [20/03/2011 01:55:19] ==== COM16 [VCP0] selected module v3.28 Device: Autodetect 6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: read/check information ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6235:8A04:8A01]... CPU: MT6235 high speed boot On chip: 0000:0000:0003 status: FF boot packet size: 0400 Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 14 sec Remove/Install battery now ! Device: Autodetect 6253 NOR ==== [20/03/2011 01:56:05] ==== COM16 [VCP0] selected module v3.28 Device: Autodetect 6253 NOR Checking data, wait... advanced flash detection disabled Action: read/check information ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6235:8A04:8A01]... CPU: MT6235 high speed boot On chip: 0000:0000:0003 status: FF boot packet size: 0400 Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 20 sec Remove/Install battery now ! ==== [20/03/2011 01:56:38] ==== COM16 [VCP0] selected module v3.28 Device: Autodetect 6253 NOR Checking data, wait... advanced flash detection disabled Action: read/check information ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6235:8A04:8A01]... CPU: MT6235 high speed boot On chip: 0000:0000:0003 status: FF boot packet size: 0400 Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 11 sec Remove/Install battery now ! Device: Autodetect 6253 NOR ==== [20/03/2011 01:57:21] ==== COM16 [VCP0] selected module v3.28 Device: Autodetect 6253 NOR Checking data, wait... Action: write flash write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs error: no data loaded for Firmware Finished, time used: 1 sec Remove/Install battery now ! Loading file v.02... BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_62__f irmware_20110319-173836.B4M.bin loaded usb bootloader (file) is absent rom info ver: 07 sw version: BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_62.BI N project-id: BR35_V02.62, 5C38614D code offset: 00000000 ffs offset/size [01]: 02000000/02000000 rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent file w/protection: startup code area #1 firmware date/time: 2010-11-08 19-01 hw1: BR35_09A_HW hw2: 09A_60_BENRUI35_09A ==== [20/03/2011 01:57:55] ==== COM16 [VCP0] selected module v3.28 Device: Autodetect 6253 NOR Checking data, wait... Action: write flash write: Firmware BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_62__f irmware_20110319-173836.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nor area detection... "format ffs" active interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0017]: 00AD:007600AD0076 [HYNIX] HY27XS08121M chip size: 64Mb page/spare size: 0200/0010 pages per block: 0020 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (921600)... done ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/02000000 firmware size: 32Mb ffs size: 32Mb detect sec ro... detect custom parameters... detect project-id... project-id: BR35_V02.65 detect NAND info... number of areas/bytes to read: 1:00034000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... warning: core offset is not detected nfi area detection (0 cores) finished: failed TCL-ID detection... TCL-ID detection done startup code area #1 detection... number of areas/bytes to read: 1:00004000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... number of areas/bytes to read: 1:00004000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... startup code area #1 is invalid startup code area #1 detection done rom info ver: 07 sw version: BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_65.BI N project-id: BR35_V02.65, 90B9F97C code offset: 00000000 ffs offset/size [01]: 02000000/02000000 rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent ===> done startup code area #1 check... rpl file not found: c:\InfinityBox\ChineseMiracle\id.00006235.[BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_62.BI N_4D61385C].rpl rpl file not found: c:\InfinityBox\ChineseMiracle\id.00006235._BENRUI3 5_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_62.BIN_4D613 85C_.rpl rpl file not found: c:\InfinityBox\ChineseMiracle\backup_security\id.0 0006235.[BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_62.BI N_4D61385C].rpl rpl file not found: c:\InfinityBox\ChineseMiracle\backup_security\id.0 0006235._BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_ V02_62.BIN_4D61385C_.rpl ==================== warning: unknown firmware: BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_62.BI N_4D61385C Unknown firmware found (v.3.28, database date: 19.03.2011), user action required: 1. download latest software from support area and try again 2. if no still luck follow the next procedure: - find good working phone with the same firmware: BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_62.BI N - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) - be little bit patient and wait update ==================== error: startup code area #1 can't be fixed You can flash phone now but can not finalize it, in most cases phone CAN NOT power-on. Do you want to continue anyway ? number of cores: 1 loading files... number of areas: 1 done write... write core... warning: can not format: HW_STORAGE_NOR is not present Format... Disconnect... done Finished, time used: 11 min 10 sec Remove/Install battery now ! Loading file v.02... RATECH35_08B_PCB01_GPRS_MT6235B_S01.M97_HT_FM_KEY2 _091209__fullflash_20110112-112645.B4M.bin loaded usb bootloader (file) is absent rom info ver: 07 sw version: RATECH35_08B_PCB01_GPRS_MT6235B_S01.M97_HT_FM_KEY2 _091209.BIN project-id: M97_HT_FM_KEY2_091209, 00000000 code offset: 00000000 ffs offset/size [01]: 02620000/059E0000 rom info structure: [standard] type (07) TCL-ID is absent firmware date/time: 2009-12-09 20-45 hw1: RATECH35_08B_HW hw2: 08B_RATECH35_08B ==== [20/03/2011 02:48:01] ==== COM16 [VCP0] selected module v3.28 Device: Autodetect 6253 NOR Checking data, wait... Action: write flash write: Firmware RATECH35_08B_PCB01_GPRS_MT6235B_S01.M97_HT_FM_KEY2 _091209__fullflash_20110112-112645.B4M.bin ==== c:\InfinityBox\ChineseMiracle\ChineseMiracle.exe [20/03/2011 02:49:48] ==== http://www.infinity-box.com Loading data, wait... [Infinity Box] Chinese Miracle v3.28 smart-card: connected S/N: 0343:0116 Wait... Device: Autodetect 6205-6239 NOR Done Device: Autodetect 6253 NOR Loading file v.02... RATECH35_08B_PCB01_GPRS_MT6235B_S01.M97_HT_FM_KEY2 _091209__fullflash_20110112-112645.B4M.bin loaded usb bootloader (file) is absent rom info ver: 07 sw version: RATECH35_08B_PCB01_GPRS_MT6235B_S01.M97_HT_FM_KEY2 _091209.BIN project-id: M97_HT_FM_KEY2_091209, 00000000 code offset: 00000000 ffs offset/size [01]: 02620000/059E0000 rom info structure: [standard] type (07) TCL-ID is absent firmware date/time: 2009-12-09 20-45 hw1: RATECH35_08B_HW hw2: 08B_RATECH35_08B ==== [20/03/2011 02:52:06] ==== COM16 [VCP0] selected module v3.28 Device: Autodetect 6253 NOR Checking data, wait... Action: write flash write: Firmware RATECH35_08B_PCB01_GPRS_MT6235B_S01.M97_HT_FM_KEY2 _091209__fullflash_20110112-112645.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nor area detection... "format ffs" active interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0017]: 00AD:007600AD0076 [HYNIX] HY27XS08121M chip size: 64Mb page/spare size: 0200/0010 pages per block: 0020 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (921600)... done ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/02000000 firmware size: 32Mb ffs size: 32Mb detect sec ro... detect custom parameters... detect project-id... project-id: BR35_V02.62 detect NAND info... number of areas/bytes to read: 1:00034000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... warning: core offset is not detected nfi area detection (0 cores) finished: failed TCL-ID detection... TCL-ID detection done startup code area #1 detection... number of areas/bytes to read: 1:00004000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... number of areas/bytes to read: 1:00004000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... startup code area #1 is invalid startup code area #1 detection done rom info ver: 07 sw version: BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_62.BI N project-id: BR35_V02.62, 5C38614D code offset: 00000000 ffs offset/size [01]: 02000000/02000000 rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent ===> done startup code area #1 check... done number of cores: 1 loading files... number of areas: 1 done write... write core... error: can not write flash (87): 0FAF:S_FT_NFB_DOWNLOAD_CODE_FAIL error: last error: 0FAF:S_FT_NFB_DOWNLOAD_CODE_FAIL Disconnect... done Finished, time used: 33 min 39 sec Remove/Install battery now ! ==== c:\InfinityBox\ChineseMiracle\ChineseMiracle.exe [20/03/2011 11:06:22] ==== http://www.infinity-box.com Loading data, wait... [Infinity Box] Chinese Miracle v3.28 smart-card: connected S/N: 0343:0116 Wait... Device: Autodetect 6205-6239 NOR Done Device: Autodetect 6253 NOR Loading file v.01... Loading failed, probably damaged data file Device: Autodetect 6205-6239 NOR Loading file v.01... Loading failed, probably damaged data file Device: Autodetect 6228-6268 NAND Loading file v.01... Loading failed, probably damaged data file ==== c:\InfinityBox\ChineseMiracle\ChineseMiracle.exe [20/03/2011 11:12:17] ==== http://www.infinity-box.com Loading data, wait... [Infinity Box] Chinese Miracle v3.28 smart-card: connected S/N: 0343:0116 Wait... Device: Autodetect 6205-6239 NOR Done Device: Autodetect 6253 NOR Loading file v.05... BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_65_20 10-12-10_64m_En_Cn.B4M.bin loaded usb bootloader (file) is absent rom info ver: 07 sw version: BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_65.BI N project-id: BR35_V02.65, 90B9F97C code offset: 00000000 ffs offset/size [01]: 02000000/02000000 rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent file w/protection: startup code area #1 firmware date/time: 2010-12-10 16-33 hw1: BR35_09A_HW hw2: 09A_65_BENRUI35_09A ==== [20/03/2011 11:13:32] ==== COM16 [VCP0] selected module v3.28 Device: Autodetect 6253 NOR Checking data, wait... Action: write flash write: Firmware BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_65_20 10-12-10_64m_En_Cn.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs No licensed to produce fix... warning: firmware do not have this kind of fault nor area detection... "format ffs" active interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0017]: 00AD:007600AD0076 [HYNIX] HY27XS08121M chip size: 64Mb page/spare size: 0200/0010 pages per block: 0020 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (921600)... done ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... detect sec ro... detect custom parameters... detect project-id... detect NAND info... number of areas/bytes to read: 1:00034000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... warning: header is empty: probably flash chip completely erased warning: can not detect header nfi area detection (0 cores) finished: failed warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done code offset: 00000000 ===> done startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed number of cores: 1 loading files... number of areas: 1 done write... error: can not write flash (0): 0C3A:S_DA_NFB_TARGET_IS_SINGLE_BL_BUT_PC_NOT error: last error: 0C3A:S_DA_NFB_TARGET_IS_SINGLE_BL_BUT_PC_NOT Disconnect... done Finished, time used: 1 min 1 sec Remove/Install battery now ! ==== [20/03/2011 11:14:50] ==== COM16 [VCP0] selected module v3.28 Device: Autodetect 6253 NOR Checking data, wait... Action: write flash write: Firmware BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_65_20 10-12-10_64m_En_Cn.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs No licensed to produce fix... warning: firmware do not have this kind of fault nor area detection... interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0017]: 00AD:007600AD0076 [HYNIX] HY27XS08121M chip size: 64Mb page/spare size: 0200/0010 pages per block: 0020 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (460800)... done ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... detect sec ro... detect custom parameters... detect project-id... detect NAND info... number of areas/bytes to read: 1:00034000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... warning: header is empty: probably flash chip completely erased warning: can not detect header nfi area detection (0 cores) finished: failed warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done code offset: 00000000 ===> done startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed number of cores: 1 loading files... number of areas: 1 done write... error: can not write flash (0): 0C3A:S_DA_NFB_TARGET_IS_SINGLE_BL_BUT_PC_NOT error: last error: 0C3A:S_DA_NFB_TARGET_IS_SINGLE_BL_BUT_PC_NOT Disconnect... done Finished, time used: 54 sec Remove/Install battery now ! ==== [20/03/2011 11:15:52] ==== COM16 [VCP0] selected module v3.28 Device: Autodetect 6253 NOR Checking data, wait... Action: write flash write: Firmware BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_65_20 10-12-10_64m_En_Cn.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nor area detection... "format ffs" active interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0017]: 00AD:007600AD0076 [HYNIX] HY27XS08121M chip size: 64Mb page/spare size: 0200/0010 pages per block: 0020 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (460800)... done ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... detect sec ro... detect custom parameters... detect project-id... detect NAND info... number of areas/bytes to read: 1:00034000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... warning: header is empty: probably flash chip completely erased warning: can not detect header nfi area detection (0 cores) finished: failed warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done code offset: 00000000 ===> done startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed number of cores: 1 loading files... number of areas: 1 done write... error: can not write flash (0): 0C3A:S_DA_NFB_TARGET_IS_SINGLE_BL_BUT_PC_NOT error: last error: 0C3A:S_DA_NFB_TARGET_IS_SINGLE_BL_BUT_PC_NOT Disconnect... done Finished, time used: 48 sec Remove/Install battery now ! Loading file v.05... BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_21__N OKIA-N97_2010-05-21_64m_En_Ru_Nl_Fr_Es_It_Ml_Id_Th_Vn_Tr_Farsi_Pt_C z_Cn_Ar.B4M.bin loaded usb bootloader (file) is absent rom info ver: 07 sw version: BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_21.BI N project-id: BR35_V02.21, A9E80E6C code offset: 00000000 ffs offset/size [01]: 02000000/02000000 rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent file w/protection: startup code area #1 firmware date/time: 2010-05-21 14-03 hw1: BR35_09A_HW hw2: 09A_5_BENRUI35_09A ==== [20/03/2011 11:17:36] ==== COM16 [VCP0] selected module v3.28 Device: Autodetect 6253 NOR Checking data, wait... Action: write flash write: Firmware BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_21__N OKIA-N97_2010-05-21_64m_En_Ru_Nl_Fr_Es_It_Ml_Id_Th_Vn_Tr_Farsi_Pt_C z_Cn_Ar.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs No licensed to produce fix... warning: firmware do not have this kind of fault nor area detection... "format ffs" active interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0017]: 00AD:007600AD0076 [HYNIX] HY27XS08121M chip size: 64Mb page/spare size: 0200/0010 pages per block: 0020 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (921600)... done ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... detect sec ro... detect custom parameters... detect project-id... detect NAND info... number of areas/bytes to read: 1:00034000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... warning: header is empty: probably flash chip completely erased warning: can not detect header nfi area detection (0 cores) finished: failed warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done code offset: 00000000 ===> done startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed number of cores: 1 loading files... number of areas: 1 done write... error: can not write flash (0): 0C3A:S_DA_NFB_TARGET_IS_SINGLE_BL_BUT_PC_NOT error: last error: 0C3A:S_DA_NFB_TARGET_IS_SINGLE_BL_BUT_PC_NOT Disconnect... done Finished, time used: 48 sec Remove/Install battery now ! ==== c:\InfinityBox\ChineseMiracle\ChineseMiracle.exe [20/03/2011 11:20:44] ==== http://www.infinity-box.com Loading data, wait... [Infinity Box] Chinese Miracle v3.28 smart-card: connected S/N: 0343:0116 Wait... Device: Autodetect 6205-6239 NOR Done Device: Autodetect 6253 NOR Loading file v.05... BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_21__N OKIA-N97_2010-05-21_64m_En_Ru_Nl_Fr_Es_It_Ml_Id_Th_Vn_Tr_Farsi_Pt_C z_Cn_Ar.B4M.bin loaded usb bootloader (file) is absent rom info ver: 07 sw version: BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_21.BI N project-id: BR35_V02.21, A9E80E6C code offset: 00000000 ffs offset/size [01]: 02000000/02000000 rom info structure: [protected] type (07), 1 record(s) TCL-ID is absent file w/protection: startup code area #1 firmware date/time: 2010-05-21 14-03 hw1: BR35_09A_HW hw2: 09A_5_BENRUI35_09A ==== [20/03/2011 11:21:21] ==== COM16 [VCP0] selected module v3.28 Device: Autodetect 6253 NOR Checking data, wait... Action: write flash write: Firmware BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_21__N OKIA-N97_2010-05-21_64m_En_Ru_Nl_Fr_Es_It_Ml_Id_Th_Vn_Tr_Farsi_Pt_C z_Cn_Ar.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs No licensed to produce fix... warning: firmware do not have this kind of fault nor area detection... interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0017]: 00AD:007600AD0076 [HYNIX] HY27XS08121M chip size: 64Mb page/spare size: 0200/0010 pages per block: 0020 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (921600)... done ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... detect sec ro... detect custom parameters... detect project-id... detect NAND info... number of areas/bytes to read: 1:00034000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... warning: header is empty: probably flash chip completely erased warning: can not detect header nfi area detection (0 cores) finished: failed warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done code offset: 00000000 ===> done startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed number of cores: 1 loading files... number of areas: 1 done write... error: can not write flash (0): 0C3A:S_DA_NFB_T Last edited by InfinityHelp; 06-27-2020 at 10:11. Reason: legacy links removed | |
04-29-2011, 20:48 | #7 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
please post original firmware before editing by Language editor | |
06-07-2011, 12:11 | #9 (permalink) |
No Life Poster Join Date: Dec 2006 Location: ! Age: 39
Member: 414755 Status: Offline Sonork: quickgsm Thanks Meter: 389 | error: startup code area #1 can't be fixed You can flash phone now but can not finalize it, in most cases phone CAN NOT power-on. Do you want to continue anyway ? aborted by user error: last error: 03E8:S_STOP |
06-08-2011, 09:34 | #10 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! for making this firmware BENRUI35_09A_PCB01_GPRS_MT6235B_S01.BR35_V02_21 completely supported i need to get full working backup. I will process it and next china miracle software will be able to finalize it |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
needed pinout for carkit(N61xx) | mobileinfo | Nokia Hardware & Hardware Repair | 2 | 07-23-2013 02:41 |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
