06-09-2020, 09:31 | #1 (permalink) |
Freak Poster Join Date: Oct 2003 Location: Oslo Age: 41
Member: 41299 Status: Offline Thanks Meter: 16 | Nokia 130 TA-1017 V30.00.11 Flashing failed Battery was fully charged, Cable is perfect, drivers are okay. What could be the problem? Thanks! Operation : Write FirmWare [ v1.20 ] Setting : UserData erase : True Setting : LangPack Only : False 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM14) MODE : NOKIA USB SERIAL PORT : 14 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000005 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 55AA4B8F23CB667916191D19B2A25BBC BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : KESA61A.30.00.11.p1 BOOT : SWR : 30.00.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : KESA61A.30.00.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8E NOR: 00C2 : 0025 : 0037 : 0000 NOR: [MX] MX25U6435E NOR: TSIZE : 0x00800000 [ 8,00 MB ] PSIZE : 0x00800000 [ 8,00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! VPL SoftwareVersion : 30.00.11 [TA-1017] DEV SoftwareVersion : 30.00.11 SWInfo compare result : SAME Load FlashSet : MROM : TA-1017_ROM_eMP_30.00.11 LANG : TA-1017_LANG_PACK_ROM_EC_eMP_30.00.11_001 CUST : TA-1017_CUSTPACK_ROM_EC_eMP_30.00.11_001 JUMP : TA-1017_JUMP_TABLE_EC_eMP_30.00.11_001 VIVA : TA-1017_VIVA_eMP_30.00.11 Prepare FlashSet : DCR : TA-1017_ROM_eMP_30.00.11 DCR : TA-1017_LANG_PACK_ROM_EC_eMP_30.00.11_001 DCR : TA-1017_CUSTPACK_ROM_EC_eMP_30.00.11_001 DCR : TA-1017_JUMP_TABLE_EC_eMP_30.00.11_001 DCR : TA-1017_VIVA_eMP_30.00.11 Prepare Target SDS : OK : 0x007F8000 : 0x00008000 FFS Format Ok! Erase Target Flash Erase done! Write Target Flash Write : TA-1017_ROM_eMP_30.00.11 Write : TA-1017_LANG_PACK_ROM_EC_eMP_30.00.11_001 Write : TA-1017_CUSTPACK_ROM_EC_eMP_30.00.11_001 Write : TA-1017_JUMP_TABLE_EC_eMP_30.00.11_001 Write : TA-1017_VIVA_eMP_30.00.11 Flash_Write ERROR : DA_CBR_NOT_FOUND Error : Flashing failed! Make sure device HW is in normal condition, check battery and cable! Reconnect Power/Cable! |
