Old 03-16-2008, 10:48   #16 (permalink)
patric's Avatar
Member: 8228
Sonork: 12399830
Thanks Meter: 136
and u don't understand that i have repaired at least 200 phones rebooting and freezing with sim-card
and this one can't be repaired !!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 03-16-2008, 11:02   #17 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
are you using original USB cable from phone package for this?
Old 03-16-2008, 11:10   #18 (permalink)
patric's Avatar
Member: 8228
Sonork: 12399830
Thanks Meter: 136
i'm using pinout like picture
1 2 3 4
gnd RX TX
phone can be readed by the software but can't be formatted
Old 03-16-2008, 11:20   #19 (permalink)
Member: 148515
hello!
try both formats safe and complete
Old 03-17-2008, 08:36   #20 (permalink)
patric's Avatar
Member: 8228
Sonork: 12399830
Thanks Meter: 136
hello!
here the log file ; i'm trying safe format !
COM1 [Serial0] selected
Action: reset settings
Model: Autodetect 6205-6227 NOR
Checking data, wait...
19200 autodetect
error: boot phase#2/1 failed
Can't initialize test mode !
Possible reasons:
1. communication fault, repeat required operation
2. eeprom/ffs serious damaged, use repair eeprom/ffs files or use other unlock/format method
error: operation failed !
Finished, time used: 5 sec
Remove/Install battery now !
Old 03-17-2008, 10:21   #21 (permalink)
Member: 148515
hello!
please check if this phone have skyworks module installed, might be it prevent normal communication
Old 03-24-2009, 11:22   #22 (permalink)
Member: 184703
Thanks Meter: 5
error boot phase #1 ,
1. check tx ,rx, points and make sure that gnd is ok
2.remove the RF( NETWORK ) section board frm the main pcb and make format
100% OK on dubao 758 china phone
The Following User Says Thank You to baswaraj For This Useful Post:
Old 03-26-2009, 11:13   #23 (permalink)
Chandreshswami's Avatar
Member: 370998
Sonork: 100.1582579
Thanks Meter: 219
Originally Posted by patric View Post
i don't understand anything
why i can't format the phone if it can be connected o software and i can read information
Remove skyworks module located below keyboard and then do formatt
Old 07-05-2010, 09:02   #24 (permalink)
murtaza_nns's Avatar
Member: 247987
Sonork: 100.1609015
Thanks Meter: 542
100% True. It worked for me 100%
Old 05-22-2012, 07:23   #25 (permalink)
Member: 1715011
Dubao 758
Please help. Where is the charging and USB input on 20 pin connector.
2gsm dubao 758 need help strange error' jcjibz Infinity-Box 0 11-20-2008 05:34
nokia n100 tv mobile cpu2 pinout please cepclub Infinity-Box 3 08-08-2008 22:01
i need dubao set model 758 pinouts jalalmz Infinity-Box 1 01-02-2008 23:04
DuBao 758 higherzman Infinity-Box 2 11-03-2007 01:06
Need NBA DUBAO 758 CHINA PHONE pinout 5mobile Infinity-Box 2 10-31-2007 05:12
Page generated in 0.22145 seconds with 9 queries
