04-18-2019, 10:58 | #1 (permalink) |
No Life Poster Join Date: Feb 2011 Location: ( United States Of Islam ) Age: 35
Member: 1519396 Status: Offline Sonork: 100.1612702 Thanks Meter: 1,951 | Nokia 3 after formating only vebrate MT6737M__Unknown__Heart__Unknown__8.1.0__alps-mp-o1.mp1-V1.132.2_k37mv1.64.bsp_P6 Code: ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Card found : S/N : CE90936C , v0137 Chinese Miracle II [MTK module] v 1.58 Start at : [17/04/2019 / 14:54:36] Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 22 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x00FF BLVersion : 0x0002 PreLoader : Active [ Boot with PL ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x9B NAND Flash : NOT INSTALLED eMMC Flash : 514E011336394A32B205105241638C25 [WARNING] : MEMORY_eMMC_VALIDATE_FAILED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x13 , OEM : 014E [eMMC] : FLASH_INF : [NOT_IN_BASE] , R69J2 [eMMC] : FLASH_CID : 13014E51324A3936521005B2258C4441 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB400000 [eMMC] : FLASH_UCP : 15028 MiB [eMMC 16 GiB] DEV RID : 0xB6C6A77E263762507086F0345DC49E33 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... xGPT : Normalize settings Ok! Brand : Unknown ProdName : Unknown ProdModel : Heart Device : Unknown AndroidVer: 8.1.0 MTKxCPU : MT6737M MTKxPRJ : alps-mp-o1.mp1-V1.132.2_k37mv1.64.bsp_P6 [Read Ok] : preloader_ne1.bin [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : logo.bin [Read Ok] : secro.img [Read Ok] : tz1.img [Read Ok] : tz2.img [Read Ok] : box.img [Read Ok] : sys_info.img [Read Ok] : hidden.img [Read Ok] : cda.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6737M / V1.1.2 / ne1 / EMMC Android Info saved HWConfig Info saved FW Size : 4276 MiB Scatter saved to : C:\Users\Niaz muhammad\Desktop\MT6737M__Unknown__Heart__Unknown__8.1.0__alps-mp-o1.mp1-V1.132.2_k37mv1.64.bsp_P6\ All done! Done! Elapsed: 00:08:39 Reconnect Power/Cable! 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 22 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x05000000 BromVer : 0x00FF BLVersion : 0x0002 PreLoader : Active [ Boot with PL ] BootLdrSS : LOCKED with CERT Processing DA stage DA Select done, will use SecMode DA Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x9B NAND Flash : NOT INSTALLED eMMC Flash : 514E011336394A32B205105241638C25 [WARNING] : MEMORY_eMMC_VALIDATE_FAILED Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x13 , OEM : 014E [eMMC] : FLASH_INF : [NOT_IN_BASE] , R69J2 [eMMC] : FLASH_CID : 13014E51324A3936521005B2258C4441 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB400000 [eMMC] : FLASH_UCP : 15028 MiB [eMMC 16 GiB] DEV RID : 0xB6C6A77E263762507086F0345DC49E33 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ISPFF ID : 6737 , TARGET ID : 6737 FlashFile is differs from eMMC settings, continue by user request Flash pre-erase enabled Erase Flash now ... Flash pre-erase done Write Flash now ... [ MCU ] : MT6737M__UNKNOWN__Heart__alps-mp-n1.mp1-V1.11_fih6737m.65.nj.n1_P13__Android_7.1.1.ispff Init Ok , Sending blocks ... Write failed :( Flash Error! Check Cable, Battery , try again Operation Failed Elapsed: 00:11:46 Reconnect Power/Cable! Finish at : [18/04/2019 / 10:13:26] |
The Following User Says Thank You to niaz muhammad For This Useful Post: |
04-18-2019, 11:46 | #3 (permalink) |
No Life Poster Join Date: Feb 2018 Location: Nigeria
Member: 2812901 Status: Offline Thanks Meter: 493 | You need factory signed firmware to revive your phone and try to use infinity-best2 v1.14 to flash. |
The Following 2 Users Say Thank You to Oyetunde Semiu For This Useful Post: |
04-18-2019, 11:49 | #4 (permalink) |
Member: 2812901 Status: Offline Thanks Meter: 493 | Anything pertaining to Nokia hmd always use infinity-best2 to format or flash. 100% capable and successful. |
04-18-2019, 12:10 | #5 (permalink) |
Registered User Join Date: May 2008 Location: ...::IsLam::... Age: 39
Member: 767472 Status: Offline Sonork: 100.1609877 Thanks Meter: 599 | read nv full format write again damage backup |
The Following 2 Users Say Thank You to .....::::GsmAdeel:::::..... For This Useful Post: |
04-18-2019, 12:24 | #6 (permalink) |
Product Supporter Join Date: Sep 2016 Location: Pakistan
Member: 2620420 Status: Offline Sonork: 100.1678393 Thanks Meter: 1,295 | NEVER MAKE FLASH ERASE!!!! You will kill device!!! NOT update PRELOADER ( tick SKIP Preloader ) and NOT erase device ( untick Flash Pre-erase ) |
The Following User Says Thank You to shahzadqadri For This Useful Post: |
04-18-2019, 13:02 | #7 (permalink) |
Member: 1519396 Status: Offline Sonork: 100.1612702 Thanks Meter: 1,951 | wich tray to flash I tray this all MT6737M__Unknown__Heart__Unknown__7.1.1__alps-mp-n1.mp1-V1.11_fih6737m.65.nj.n1_P13.rar MT6737M__Unknown__Heart__Unknown__8.1.0__alps-mp-o1.mp1-V1.132.2_k37mv1.64.bsp_P6 Nokia3_MT6737M_Heart_FIH_7.1.1.7z MT6737M__UNKNOWN__Heart__alps-mp-n1.mp1-V1.11_fih6737m.65.nj.n1_P13__Android_7.1.1 |
04-18-2019, 13:08 | #8 (permalink) |
Member: 2620420 Status: Offline Sonork: 100.1678393 Thanks Meter: 1,295 | Nokia3_MT6737M_Heart_FIH_7.1.1.7z This One Also Recover 4 Mobile Use CM2 V1.58 |
04-18-2019, 15:12 | #10 (permalink) |
Member: 1519396 Status: Offline Sonork: 100.1612702 Thanks Meter: 1,951 | now my problime slove this file best2 NE1-443E-0-00WW-B01_2 phone but logo restarting Code: Card found : 8C73AEBC , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.14 Load : D:\Nokia flash file\Nokia 3\NE1-443E-0-00WW-B01_2\NE1-443E-0-00WW-B01.nb0 Bad file selected! Select correct NB0 file! Load : D:\Nokia flash file\Nokia 3\NE1-443E-0-00WW-B01_2\NE1-443E-0-00WW-B01.nb0 Load Ok! Operation : Write FW [ v1.14 ] Setting : UserData preserve : False Setting : Flash Pre-Erase : True Setting : Bootloader update : True 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek USB Port (COM23) MODE : BOOTROM PORT : 23 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : DSLevel : DEV_KEY+DEV_CRT BROM : BOOTROM AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6735 AGENT : Nokia_All_InOne_DA_v03.2019.1303 Fail to disable Dog! BROM : Sending 1st DA ... BROM : 0x00007017 : DA SEND ERROR! ERROR : SECURE BOOT : SLA REQUIRED IN BROM MODE! Error : Fail to init protocol! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! Operation : Write FW [ v1.14 ] Setting : UserData preserve : False Setting : Flash Pre-Erase : True Setting : Bootloader update : True 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM22) MODE : PRELOADER PORT PORT : 22 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : DSLevel : DEV_KEY+DEV_CRT BROM : PRELOADER PORT AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6735 AGENT : Nokia_All_InOne_DA_v03.2019.1303 BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND eMMC : OK eMMC : 13014E51324A3936521005B2258C6341 DAInf: 4 : 2 : 155 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 13014E51324A3936521005B2258C4441 EMMC: VEN : MICRON | OEM : 4E01 | DEV : Q2J96R EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3AB400000 [ 14.68 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 5062372634F08670339EC45DBF431E7E STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! SEC_DL : False (CUST) SEC_ID : 0x67887C7972766E6888787678777B796E [FL] : HW verification passed! Erase : 0x0000000001C80000 : 0x0000000005680000 Erase : 0x0000000007320000 : 0x0000000002000000 Erase : 0x0000000009B20000 : 0x000000017D4E0000 PMT Update : Skip Flashing now ... PROCESS : PRELOADER Unpack : NE1-0-443E-preloader_NE1.bin Flash : NE1-0-443E-preloader_NE1.bin Update bootloader code ... Update bootloader Ok! PROCESS : LK Unpack : NE1-0-443E-00WW-lk.img Flash : NE1-0-443E-00WW-lk.img PROCESS : BOOT Unpack : NE1-0-443E-00WW-boot.img Flash : NE1-0-443E-00WW-boot.img PROCESS : RECOVERY Unpack : NE1-0-443E-00WW-recovery.img Flash : NE1-0-443E-00WW-recovery.img PROCESS : LOGO Unpack : NE1-0-443E-00WW-logo.bin Flash : NE1-0-443E-00WW-logo.bin PROCESS : SECRO Unpack : NE1-0-443E-secro.img Flash : NE1-0-443E-secro.img PROCESS : TEE1 Unpack : NE1-0-443E-tee.img Flash : NE1-0-443E-tee.img PROCESS : TEE2 Unpack : NE1-0-443E-tee.img Flash : NE1-0-443E-tee.img PROCESS : SYS_INFO Unpack : fver Flash : fver PROCESS : SUTINFO Unpack : NE1-00WW-001-sutinfo.img Flash : NE1-00WW-001-sutinfo.img PROCESS : CDA Unpack : NE1-00WW-010-cda.img Flash : NE1-00WW-010-cda.img PROCESS : SYSTEM Unpack : NE1-0-443E-00WW-system.img Flash : NE1-0-443E-00WW-system.img PROCESS : CACHE Unpack : cache.img Flash : cache.img PROCESS : USERDATA Unpack : userdata.img Flash : userdata.img PMT Update : Skip SEC_DL : False (CUST) SEC_ID : 0x67887C7972766E6888787678777B796E Flashing finished! Done! Elapsed: 00:06:38 Reconnect Power/Cable! |
04-18-2019, 15:15 | #11 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Flash SW 3380, make sure about battery charged. Update device after over OTA. |
The Following 5 Users Say Thank You to JayDi For This Useful Post: |
04-18-2019, 17:42 | #12 (permalink) | |
Member: 1519396 Status: Offline Sonork: 100.1612702 Thanks Meter: 1,951 | Quote:
https://www.youtube.com/watch?v=zd3u...&feature=share | |
04-19-2019, 05:07 | #13 (permalink) | |
Code: Card found : 8C73AEBC , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.14 Load : D:\Nokia flash file\Nokia 3\OST_Tool_Driver\Nokia-3-Essential_NE1-3380-0-00WW-B01\NE1-3380-0-00WW-B01.nb0 Load Ok! Operation : Write FW [ v1.14 ] Setting : UserData preserve : False Setting : Flash Pre-Erase : True Setting : Bootloader update : True 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM36) MODE : PRELOADER PORT PORT : 36 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : DSLevel : DEV_KEY+DEV_CRT BROM : PRELOADER PORT AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6735 AGENT : Nokia_All_InOne_DA_v03.2019.1303 BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND eMMC : OK eMMC : 13014E51324A3936521005B2258C6341 DAInf: 4 : 2 : 155 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 13014E51324A3936521005B2258C4441 EMMC: VEN : MICRON | OEM : 4E01 | DEV : Q2J96R EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3AB400000 [ 14.68 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 5062372634F08670339EC45DBF431E7E STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! SEC_DL : False (CUST) SEC_ID : 0x67887C7972766E6888787678777B796E [FL] : HW verification passed! Erase : 0x0000000001C80000 : 0x0000000005680000 Erase : 0x0000000007320000 : 0x0000000002000000 Erase : 0x0000000009B20000 : 0x000000017D4E0000 PMT Update : Skip Flashing now ... PROCESS : PRELOADER Unpack : NE1-0-3380-preloader_NE1.bin Flash : NE1-0-3380-preloader_NE1.bin Update bootloader code ... Update bootloader Ok! PROCESS : LK Unpack : NE1-0-3380-lk.img Flash : NE1-0-3380-lk.img PROCESS : BOOT Unpack : NE1-0-3380-00WW-boot.img Flash : NE1-0-3380-00WW-boot.img PROCESS : RECOVERY Unpack : NE1-0-3380-00WW-recovery.img Flash : NE1-0-3380-00WW-recovery.img PROCESS : LOGO Unpack : NE1-0-3380-logo.bin Flash : NE1-0-3380-logo.bin PROCESS : SECRO Unpack : NE1-0-3380-secro.img Flash : NE1-0-3380-secro.img PROCESS : TEE1 Unpack : NE1-0-3380-tee.img Flash : NE1-0-3380-tee.img PROCESS : TEE2 Unpack : NE1-0-3380-tee.img Flash : NE1-0-3380-tee.img PROCESS : SYS_INFO Unpack : fver Flash : fver PROCESS : SUTINFO Unpack : NE1-00WW-001-sutinfo.img Flash : NE1-00WW-001-sutinfo.img PROCESS : CDA Unpack : NE1-00WW-010-cda.img Flash : NE1-00WW-010-cda.img PROCESS : SYSTEM Unpack : NE1-0-3380-00WW-system.img Flash : NE1-0-3380-00WW-system.img PROCESS : CACHE Unpack : cache.img Flash : cache.img PROCESS : USERDATA Unpack : userdata.img Flash : userdata.img PMT Update : Skip SEC_DL : False (CUST) SEC_ID : 0x67887C7972766E6888787678777B796E Flashing finished! Done! Elapsed: 00:05:18 Reconnect Power/Cable! | |
