04-29-2008, 14:08 | #1 (permalink) |
No Life Poster Join Date: Feb 2004 Age: 49
Member: 53198 Status: Offline Sonork: 100.1589499 Thanks Meter: 819 | Nokia 5310 Display "Bad Sofware" please help infinity please help : Nokia 5310: CPU : MT6225 Flash :SAMSUNG K5L2731CAM Soft : SINGLE25_06B_PCB01_GPRS_MT6225_S00.A90V1_6_1.BIN I do it with Infinity Box but the same -Format -Ease whole flash chip and write flash and e2p (read full from a other good phone working) but the same phone display "bad software" when press power on here the log Code: COM8 [Serial2] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active write: Firmware skip: Customization/Language Pack skip: Customization write: Eeprom/ffs Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:5303:0008 boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 460800 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... detect device identification#1... detection phase #1... . detection phase #2... ................................................................................................................................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... detect device identification#1... detection phase #1... . detection phase #2... ................................................................................................................................ warning: identification#1 information not found, possible reasons: .old firmware type w/o identification#1 data .damaged firmware .damaged hardware if phone works fine just ignore this warning detect device identification#1 finished detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Area: Firmware flash: EC257E25082501:FFFFFF00000000 Write: Firmware Area: Eeprom/ffs flash: EC257E25082501:18E59F00000000 Write: Eeprom/ffs detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Write Done Finalization... Finalization Done Finished, time used: 521 sec Remove/Install battery now ! |
04-30-2008, 08:31 | #7 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,536 | hello! some chinese phones have 2 MCU each one control own sim card. if your phone is double MCU- i can advice to make complete format for both parts in a row and only after that power On phone |
05-02-2008, 07:54 | #11 (permalink) | |
No Life Poster Join Date: Dec 2005 Location: PAKISTAN Age: 35
Member: 210880 Status: Offline Sonork: 100.1577765 Thanks Meter: 151 | Quote:
05-02-2008, 14:57 | #14 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,536 | hello guys! MCU is same as CPU. my saying "format both phone parts" i mean format first MCU memory and without powering On mobile connect cable to second MCU pinout and format second phone part |
06-26-2008, 04:22 | #15 (permalink) |
No Life Poster Join Date: Dec 2005 Location: Gujjar AJK
Member: 207308 Status: Offline Thanks Meter: 471 | 5310 bad soft ok in this model 100% Dear all, here is readed files for bad soft and tested 100% work for this model of chines 5310 X225B_PCB01_GPRS_MT6225_S00.BIN ok read 5310 for bad soft remember all chines 5310 have different files plz post results also in rar logs for help what you have and what you write? link is here http://www.4shared.com/file/52753659..._bad_soft.html |
nokia 5310 display prob | theonly1 | Nokia Hardware & Hardware Repair | 4 | 12-21-2009 08:57 |
5310 conser because Hardwere please help...... | bireun | Nokia Base Band 5 ( BB-5 ) | 2 | 10-11-2009 16:00 |
5310 problem after flash.Please help for this problem. | caremobiles | Nokia Base Band 5 ( BB-5 ) | 9 | 04-30-2009 15:39 |
STILL nokia 5310 prob unlock pls pls help | GSM PAVIA | Universalbox | 0 | 04-22-2008 12:03 |
How to remove display from 3210 ??? Please help ! | Teracite | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 09-19-2000 07:18 |
