10-20-2017, 10:08 | #1 (permalink) |
No Life Poster Join Date: Nov 2009 Location: BaNgLaDeSh Age: 41
Member: 1150957 Status: Offline Thanks Meter: 60 | Nokia 6 TA-1000 Dead Flash With CM2 Tool, Now Phone Dead And Ask Hs-Usb Diagnostic Port, Can Not Connect To Flash Mode All Time Show Hs-Usb Diagnostic Port, I Think Its Boot Damage, Can Possible Boot Repair? |
The Following User Says Thank You to brokendreem For This Useful Post: |
10-20-2017, 11:19 | #2 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 45
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | Post software logs here Did you used firmware read by CM2 |
The Following 2 Users Say Thank You to Kirumira For This Useful Post: |
10-20-2017, 11:49 | #4 (permalink) |
Member: 1150957 Status: Offline Thanks Meter: 60 | Card found : A8A8234A , v0136 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.15 Loading firmware ... Created by Infinity-Box (c) Chinese Miracle II (c) 2017 Device Brand : Nokia Device Manufact.: FIH Device Model : D1C Device CPU : MSM8937 Device IntName : TA-1000_00CN Device Version : 7.1.1 CU_SWVer : FIH Device Compile : 8/17/2017 9:35:47 AM Device ExtInfo : TA-1000 Load Ok! Operation : Flash [ v1.15 ] ForceFlashing : Disabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 430 [MSM8937] ID_BLOCK_S : D9C09DEE ID_BLOCK_I : 0004F0E1 ID_BLOCK_L : C2C82D1D0F85C14E6F843D57D9985DB7 ID_BLOCK_L : C0F097191FF03C7BB128E215B044AD9A Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8937 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000E8F800000 [ eMMC 64 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : RC14MB Boot Ok! Flash Chain : 65 Flashing now Flashing : gpt_main0.bin Flashing : NON-HLOS.bin Flashing : sbl1.mbn Flashing : sbl1.mbn Flashing : rpm.mbn Flashing : rpm.mbn Flashing : tz.mbn Flashing : tz.mbn Flashing : devcfg.mbn Flashing : devcfg.mbn Flashing : adspso.bin Flashing : sec.dat Flashing : splash.img Flashing : emmc_appsboot.mbn Flashing : emmc_appsboot.mbn Flashing : boot.img Flashing : recovery.img Flashing : hwconf.cfg Flashing : sysinfo.cfg Flashing : splashm.img Flashing : hidden.img Flashing : cda.img Flashing : persist.img Flashing : misc.img Flashing : mdtp.img Flashing : cmnlib.mbn Flashing : cmnlib.mbn Flashing : cmnlib64.mbn Flashing : cmnlib64.mbn Flashing : keymaster.mbn Flashing : keymaster.mbn Flashing : system.img Flashing : cache.img Flashing : userdata.img Flashing : gpt_backup0.bin Wipe data ... BootConfig set to 0x00 Flashing done! Done! Elapsed: 00:09:46 Reconnect Power/Cable! |
10-20-2017, 13:28 | #5 (permalink) |
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | Hello, Read firmware from working phone,WRITE TO FAULTY PHONE with this http://forum.gsmhosting.com/vbb/12715360-post1.html Post Results after. |
10-20-2017, 16:32 | #6 (permalink) | |
Member: 1150957 Status: Offline Thanks Meter: 60 | Quote:
Phone Can Not Connect To Pc With Correct Driver, All Time Ask Hs-Usb Diagnostic Port How Can I Flash This Phone With Infinity-Box BEST NK2 v1.01 | |
10-20-2017, 19:58 | #7 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Force phone to EDL mode , install emergency driver and flash it with correct TA-xxxx version. |
10-21-2017, 08:10 | #8 (permalink) | |
first remove qualcomm driver then install emergency driver EmergencyDownloadDriver.msi WinUsbCoInstallers.msi WinUsbCompatIdInstaller.msi WinUsbDriversExt.msi how can i put phone to force edl mode? 1st time when flash phone with correct TA-1000, flash done then phone enter qualcomm hs-usb diagonostics 900E port and can not connect to edl mode so how can i flash it | |
10-21-2017, 12:02 | #11 (permalink) | |
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | Quote:
check here http://forum.gsmhosting.com/vbb/12603024-post1.html Spoonfeeding is allowed here !! | |
11-01-2017, 06:20 | #12 (permalink) |
Member: 1150957 Status: Offline Thanks Meter: 60 | brother try with foil, edl cable, use Keys combinations all r same only qualcomm hs-usb diagonostics 900E port i think its brick, any unbrick solution |
