03-28-2008, 16:20 | #1 (permalink) |
Freak Poster Join Date: Sep 2006 Location: Georgia
Member: 342909 Status: Offline Thanks Meter: 6 | nokia v-98 tv tv v98 .it is ok .working ,but there is no incoming call.messages ok out and in,call out wotks but no incoming call.I tried to format but no succes,unlock the same ...only read flash and eeprom.please help me.it is a log COM4 [VCP0] selected Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6225:8A03:8A00]... CPU: MT6225 high speed boot enabled chip: 0001:E203:0005 Connecting, wait... Release Power button now ! Phone detected, wait... warning: can't read software version, probably unknown firmware detecting structure #2... 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18warning: wrong packet cs 19 20 21 22 23 24 25error: detection failed (26 tries), read flash and send to support connection lost error: operation failed ! Finished, time used: 15 sec Remove/Install battery now ! |
03-28-2008, 20:10 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | We have made in software ifferent methods for format/unlock. Did you checked FAQ therad to see how to use software ? http://www./showthread.php?t=476373 |
03-28-2008, 20:48 | #4 (permalink) |
Member: 342909 Status: Offline Thanks Meter: 6 | thanks,as I understand need to flash phone,I found the same cpu flash file in support area it is named CM_Nokia-V98-2sim-TV_STD25_06B_PCB01_GPRS_MT6225_S00.TL_UT818ZIB_P1F 01L31_00_07_16m_En_Ru_Fr_Es_It_De_Th_Vn_Pt_Ar_w_ee prom.B0M and I make buckap it ias named so backup_flash[STD25_06B_PCB01_GPRS_MT6225_S00.TL_UT818ZIA_P1F01_ 00_03.BIN]_20080328-121137.B0M should I add eeprom file? or to flash with these one? I never flashed chinese phone,only formatted before? in these case phone will be fine ? |
03-28-2008, 20:53 | #5 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! this is correect file for your phone flashing: flashfiles/ChineseMiracle/_MT6225/CM_Nokia-V96-2sim_STD25_06B_PCB01_GPRS_MT6225_S00.TL_UT818ZIA_P 1F01_00_03_16m_En_Fr_Farsi_Ar_w_eep.B0M.bin try it and post result |
03-28-2008, 22:00 | #6 (permalink) |
Member: 342909 Status: Offline Thanks Meter: 6 | NO sir,your file is not correct,I flashed with it and phone become dead sir......so I flashed with second file I choosed and showed you ...phone has russian language and incoming call and it is working perfectly now.....thanks anyway |
please help pinout nokia n99i bluetooth tv | ahmed00 | Infinity-Box | 11 | 06-16-2011 13:13 |
How To Have My Nokia 3660 a TV Cahnnel? Plzzz help me from philippines | jaysupreme | Nokia Multimedia | 1 | 12-17-2007 15:55 |
+ Nokia N77: Live TV when you want it | apocalypso | Nokia Base Band 5 ( BB-5 ) | 5 | 08-15-2007 16:30 |
1.98.10 --1.98.11--1.98.12......1.98.14 for JAF fast ,About UB??????????????? | lihua | Universalbox | 3 | 04-04-2007 16:22 |
