Old 01-06-2016, 09:58   #1 (permalink)
DUNIYA JAMAL's Avatar
Member: 192810
Sonork: Some people NEED change
Thanks Meter: 860
Huwaei Y541-U02 Unlocking?
@JayDi
Is it Possible to Unlock Huwaei Y541-U02 with CM2?
Best Regards,
Old 01-06-2016, 12:13   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Hello. Upload NVM from this phone.
The Following 3 Users Say Thank You to JayDi For This Useful Post:
Old 01-06-2016, 18:45   #3 (permalink)
Member: 192810
Thanks Meter: 860
I have Uploaded Plz check it.
CX_SPDNV - Download - 4shared
Operation : Check/Read Info [ v1.11 ]
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
3. Insert cable
 ====  Wait for phone...
Phone found! [ 9 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : Spreadtrum Boot Block version 1.1
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FLASH : eMMC Flash , Structure : Ok!
Reading extended info ...
Model Name  : Y541-U02
Model Brand : HUAWEI
Model Device: HWY541-U
AndrVersion : 4.4.2
BaseBand CPU: Y541-U02
CompileDate : 1435575104
Project Ver : Y541-U02V100R001C567B109
Model Ext   : HUAWEI Y541-U02
ExtraInfo : HWInfo not exists, normal phone
ExtraInfo : GSM Phone
Elapsed: 00:00:51
Reconnect Power/Cable!
Operation : Read FullFlash [ v1.11 ]
3. Insert cable
Phone found! [ 9 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Detected eMMC Flash , Structure detect Ok!
[FW_READER] : Step #1 Passed!
[FW_READER] : Step #2 Passed!
[FW_READER] : Step #3 Failed!
Error_Info : DVL Failed , If it Android 5.x - Root Required :(
Operation : Read NV [ v1.11 ]
3. Insert cable
Phone found! [ 9 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Read NVM Part #1
Part Ok
Read NVM Part #2
Part Ok
Saved to : C:\Users\DUNIYA JAMAL\Desktop\Huawei Y541-U02\CX_SPDNV.spdnv
Elapsed: 00:01:00
Old 01-08-2016, 21:15   #4 (permalink)
Member: 778271
Thanks Meter: 4
any sulution please for unlock
Old 01-09-2016, 08:33   #5 (permalink)
Registered User
Member: 702331
Thanks Meter: 61
what is the processor of this phone
Old 01-09-2016, 08:36   #6 (permalink)
JayDi's Avatar
Member: 462970
SC7731S , need select correct SLDR for enable it.
Old 01-09-2016, 09:09   #7 (permalink)
Registered User
Member: 702331
Thanks Meter: 61
i flashed this phone with sd update but after flash no signal and i try to boot with all possible cpus in cm2 but not booting
here is the log
Phone found! [ 20 ]
Port Opened
Sync...
Sync...
Sending FDL
========================= Start =========================
1/8/2016 / 6:15:52 PM
Chinese Miracle II [SPD module] v 1.09
Start at : [1/8/2016 / 6:16:12 PM]
Operation : Read FullFlash [ v1.09 ]
3. Insert cable
Phone found! [ 20 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Loader start failed! Wrong Model selection!
Boot failed!
Finish at : [1/8/2016 / 6:16:37 PM]
Start at : [1/8/2016 / 6:16:47 PM]
3. Insert cable
Phone found! [ 20 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
Old 01-09-2016, 09:15   #8 (permalink)
JayDi's Avatar
Member: 462970
Again - read update logs.
On PAC selection choose Huawei SLDR.
In Manuals all explained.
Old 02-10-2016, 11:52   #9 (permalink)
Sudan-Mobiles's Avatar
Member: 281857
Thanks Meter: 214
waitting for Unlock Huwaei Y541-U02
Old 11-08-2016, 02:16   #10 (permalink)
Member: 220595
Thanks Meter: 355
cm2 wont unlock such phone
it says phone is aready unlocked, nothing to do.
but phone is locked, it is locked by firmware.
fimware needs to be patched on this phone.
Page generated in 0.20947 seconds with 8 queries
