05-13-2009, 15:50 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: Sambrial (Sialkot)
Member: 282066 Status: Offline Sonork: 100.1590696 Thanks Meter: 569 | Panasonic x400 "Emergency call only" error i received Panasonic (vodafone) x400 with white screen problem......i flashed it with all the three files ..........after flash set begain to give display ..........but when it reaches at insert sim ...... it gives "Emergency call only" then screen turns white and set goes power off here is flashing logs COM4 [VCP0] selected module v1.65 Device: Panasonic-X400 Checking data, wait... Action: flash write done: 10 Boot ... Press and HOLD Power button now ! e-gold: A0 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0010:221C Connecting Done Check hardware ... flash chip supported Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: E:\InfinityBox\Pana01\Panasonic-X400_eeprom-static_20090513-202455.08E.bin loading data... wrong database file: E:\InfinityBox\Pana01\x60_eep65535.cfg error: can't load database v.133 reading eeprom-security... file saved: E:\InfinityBox\Pana01\Panasonic-X400_eeprom-security_20090513-202455.08E.bin reading eeprom-complete... file saved: E:\InfinityBox\Pana01\Panasonic-X400_eeprom-complete_20090513-202500.08E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: Firmware Writing: Firmware Erasing: Firmware Writing: Firmware Erasing: FFS-1/Customization Writing: FFS-1/Customization Erasing: Language PackCOM4 [VCP0] selected module v1.65 Device: Panasonic-X400 Checking data, wait... Action: flash write done: 10 Boot ... Press and HOLD Power button now ! e-gold: A0 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0010:221C Connecting Done Check hardware ... flash chip supported Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: E:\InfinityBox\Pana01\Panasonic-X400_eeprom-static_20090513-202455.08E.bin loading data... wrong database file: E:\InfinityBox\Pana01\x60_eep65535.cfg error: can't load database v.133 reading eeprom-security... file saved: E:\InfinityBox\Pana01\Panasonic-X400_eeprom-security_20090513-202455.08E.bin reading eeprom-complete... file saved: E:\InfinityBox\Pana01\Panasonic-X400_eeprom-complete_20090513-202500.08E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: Firmware Writing: Firmware Erasing: Firmware Writing: Firmware Erasing: FFS-1/Customization Writing: FFS-1/Customization Erasing: Language Pack Writing: Language Pack Write Done Finished, time used: 482 sec Remove/Install battery now ! Writing: Language Pack Write Done Finished, time used: 482 sec Remove/Install battery n |
05-13-2009, 16:32 | #2 (permalink) |
Member: 282066 Status: Offline Sonork: 100.1590696 Thanks Meter: 569 | problem solved ................my 1st post flashing log is 100% ok........only flashed the set again with full charged battery (1st time i used p/s)....now set is working well |
The Following User Says Thank You to zeerik For This Useful Post: |
U700 - shows full signal, but says "Emergency Calls Only" | Jazz | NSPRO | 11 | 11-20-2009 15:28 |
D600 "Emergency call not possible" | crusher | Samsung Hardware Repair | 1 | 07-17-2007 14:51 |
V3i "emergency call only" | FMC_GSM | Smart-Clip | 5 | 03-16-2007 01:53 |
Sharp GX20 - Unlocked - "Emergency Calls Only" | moonklash | Sharp | 5 | 06-15-2005 05:54 |
Alcatel BE1 - "SOS Call Only" Solution needed ????? | Svetli | Alcatel & TCL Old Models | 8 | 01-25-2003 22:31 |
