Old 02-26-2017, 10:11   #1 (permalink)
khanzada606's Avatar
Member: 2455344
Sonork: Ask me
Thanks Meter: 420
Opp F1s pattran Locked
Card found : S/N : 29BC6477 , v0135
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Device boot not done
Check Drivers
Try again
Boot Error!
Operation Failed
Elapsed: 00:00:16
Reconnect Power/Cable!
Operation : Read Flash [ v1.58 ]
Wait for phone...
Phone found! [ 15 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6755
BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x01000000
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
BootLdrSS : SIGNED with SPRELOADER
Processing DA stage
Sending and initialize DA ...
DAgent configured successfully
Connection agent : BROM
[DA_ERROR] : DRAM Configure failed!
ErroCode : 0x2122
EMICFG_NOT_ACCEPTED_CONFIG
Boot Error!
Operation Failed
Elapsed: 00:00:28
The Following User Says Thank You to khanzada606 For This Useful Post:
Old 02-26-2017, 10:34   #2 (permalink)
appsworlmardan's Avatar
Member: 2046498
Sonork: 100.1676751
Thanks Meter: 162
Try with custom ROM may work for you
Other wise mmc problem
The Following User Says Thank You to appsworlmardan For This Useful Post:
Old 02-26-2017, 10:47   #3 (permalink)
Member: 2455344
Sonork: Ask me
Thanks Meter: 420
EMMC Problem Huh?
Phone Is Okay , only pattran on Screen
Old 02-26-2017, 10:49   #4 (permalink)
Member: 2046498
Sonork: 100.1676751
Thanks Meter: 162
Try to hard reset
Or TWRP
Sent from my XT1058 using Tapatalk
Old 02-26-2017, 10:54   #5 (permalink)
farsi_007's Avatar
Member: 472592
Sonork: 100.1664052
Thanks Meter: 180
Wait for phone...
Check Drivers
Try again
Boot Error!
Operation Failed
Elapsed: 00:00:16
Wait for phone...
Phone found! [ 15 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6755
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
ErroCode : 0x2122
Boot Error!
Operation Failed
Elapsed: 00:00:28
Bro try alternately with:
vol- key and insert cable
vol+ key and insert cable
and without battery also
WBR
Old 02-26-2017, 11:53   #6 (permalink)
Member: 804466
Thanks Meter: 27
WHY NO ONE USES SEARCH BUTTON!!!
hi , this model is already FULLY SUPPORTED
1.download firmware ( any version)
2.select it in flasher tab .
3.do any needed operations
Old 02-27-2017, 10:43   #7 (permalink)
Member: 2455344
Sonork: Ask me
Thanks Meter: 420
there are 3 Different Versions OPPo F1s
Not Compatible With Each Other.
Only one of Them Supported By CM2 So Far Which has 2 GB of RAM
3 GB & 4 GB RAM Versions Not Supported BY CM2 Or Any Third Party Tool
Glad To See Team is Busy On Samsung & LG module & No update For MTK
The Following 2 Users Say Thank You to khanzada606 For This Useful Post:
Old 02-27-2017, 11:21   #8 (permalink)
lahdache's Avatar
Member: 820444
Sonork: 100.1680641
Thanks Meter: 466
boot not supported .
try whith edl cable.
using qualcomm tool ( full factory reset )
Old 02-27-2017, 12:34   #9 (permalink)
Member: 2136362
Thanks Meter: 31
fro mtk, you are saying to use the edl cable..
Plese do explain more.
Old 02-27-2017, 21:22   #10 (permalink)
Member: 2455344
Sonork: Ask me
Thanks Meter: 420
Its aint Qcom phone EDL cable
Its MT6755
Sent from my SM-G570F using Tapatalk
Old 02-28-2017, 07:28   #11 (permalink)
Member: 1565288
Thanks Meter: 5
after flash oppo 1601 f1s just on vibrate any solution plzzzz help me
Old 02-28-2017, 08:29   #12 (permalink)
Shubhanshu~'s Avatar
Member: 65074
Sonork: 100.1611263
Thanks Meter: 214
3GB Ram Version Tested to be Supported
In Logs It Shows 2 Gb in Phone it shows 3GB.
Operation : Read Pattern/DP Lock [ v1.58 ]
Wait for phone...
Phone found! [ 10 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6755
BromVer   : 0x0005
BLVersion : 0x00FE
Processing DA stage
DRAM configured from IDB!
Link with DAgent established
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , 2a4GB
[eMMC] : FLASH_CID : 90014A484247346132A423D4B81C638F
[eMMC] : FLASH_LEN : 0x0000000747C00000
[eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB]
DEV RID    : 0x600921FC2983C22709D061DAACB9EFC4
INT RAM    : 0x00000000
EXT RAM    : 0x80000000 [2 GiB]
[NAND] : FLASH : NOT INSTALLED
[UFSM] : FLASH : NOT INSTALLED
[HSUSB] : MODE : FULL-SPEED
Boot Ok!
USBDL : Init HSUSB Ok
Reading data ...
Get Locks ...
PatternLock Sequnce : 12587
Done!
Elapsed: 00:00:30
Read Flash Supported
Wait for phone...
Phone found! [ 10 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6755
BromVer   : 0x0005
BLVersion : 0x00FE
Processing DA stage
Boot Ok!
Reading Flash Content now ...
USBDL : Init HSUSB Ok!
xGPT : Normalize settings Ok!
Brand     : OPPO
ProdName  : A1601
ProdModel : A1601
Device    : A1601
AndroidVer: 5.1
MTKxCPU   : MT6755
MTKxPRJ   : A1601EX_11_A.27_170111
[Read Ok] : preloader_oppo6750_15131.bin
[Read Ok] : recovery.img
[Read Ok] : md1img.img
[Read Ok] : md1dsp.img
[Read Ok] : md1arm7.img
[Read Ok] : lk.bin
[Read Ok] : lk2.bin
[Read Ok] : boot.img
[Read Ok] : logo.bin
[Read Ok] : tz1.img
[Read Ok] : tz2.img
[Read Ok] : secro.img
[Read Ok] : system.img
[Read Ok] : cache.img
[Read Ok] : userdata.img
[ScatCFG] : MT6755 / V1.1.2 / oppo6750_15131 / EMMC
Android Info saved
HWConfig Info saved
FW Size : 3259 MiB
Scatter saved to : E:\Oppo\A1601 F1S\MT6755__OPPO__A1601__A1601__5.1__A1601EX_11_A.27_170111\
All done!
Done!
Elapsed: 00:05:57
Old 03-01-2017, 08:35   #13 (permalink)
alex_030385's Avatar
Member: 875541
Sonork: 100.1604468
Thanks Meter: 327
for me error
Card found : S/N : , v0135
Wait for phone...
Phone found! [ 311 ]
Sync...
Brom Init not done
Boot Error!
Operation Failed
Elapsed: 00:00:05
Wait for phone...
Sync...
Inital Boot Ok!
BB_CPU_PID : 6755
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
ErroCode : 0x2122
Boot Error!
Operation Failed
Elapsed: 00:00:13
Wait for phone...
Sync...
Inital Boot Ok!
BB_CPU_PID : 6755
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
ErroCode : 0x2122
Boot Error!
Operation Failed
Elapsed: 00:00:13
Old 03-01-2017, 08:48   #14 (permalink)
Member: 702572
Sonork: 9837200009
Thanks Meter: 74
OPPO F1S A1601 MTK6755 V5.1 Flash File - GsmSociety
Oppo 1601 F1s Dead & Only Vibrate Recovery File - GsmSociety
10000000000000000000000000000000% working file i m chq this file
Old 03-01-2017, 08:49   #15 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 1,790
change cable or try without battery
Page generated in 0.27705 seconds with 8 queries
