01-09-2017, 12:35 | #16 (permalink) | |
No Life Poster Join Date: Dec 2013 Location: India
Member: 2082450 Status: Offline Thanks Meter: 1,454 | Quote:
If Mr. JayDi would have been slept, you won't get a single update for CM2. In every update there is something being added. You should wait for the response f from team. If other tool supports it unlocking use it and be happy... | |
01-09-2017, 12:56 | #18 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: Inside Infinity
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | Quote:
Ru neighbour of jaydi as ur saying he is sleeping dont talk Rubbish as alrdy answer V2 is coming so wait for it | |
01-09-2017, 13:05 | #19 (permalink) |
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | Hello, Sir here u can find all update http://forum.gsmhosting.com/vbb/f296/updates-207203/ |
01-10-2017, 03:13 | #21 (permalink) |
Member: 2082450 Status: Offline Thanks Meter: 1,454 | This line is better than your previous line 'Jaydi is sleeping', funny moments etc. It's should be user is level to use software professionally. If something is not supported, then try playing with that definitely will lead you into trouble. And that's why, Infinity team shears adviced they're users to read the update logs carefully.... And Mr. Try to learn - how to behave inside the forum... |
01-14-2017, 14:40 | #22 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Z <> A Age: 49
Member: 413160 Status: Offline Sonork: 100.1657278 Thanks Meter: 96 | Wait for phone... Phone found! [ 103 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : BROM DRAM configured from IDB! Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , 2a4GB [eMMC] : FLASH_CID : 90014A484247346132A4329A095EA34D [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000747C00000 [eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB] DEV RID : 0x76E8C6725FA49844DC88CC07D8908DB3 INT RAM : 0x00000000 EXT RAM : 0x80000000 [2 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : FULL-SPEED Boot Ok! [AP] : Initial info read Ok! Done! Elapsed: 00:00:17 Reconnect Power/Cable! still no solution for this mobile |
