11-15-2018, 15:00 | #1 (permalink) |
No Life Poster Join Date: Feb 2008 Location: budaun Age: 38
Member: 702572 Status: Offline Sonork: 9837200009 Thanks Meter: 74 | oppo a37 unlock erro plz help Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.12 Operation : Reset Settings [ v1.12 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device not found! Check cable, connection and drivers! Reconnect Power/Cable! Operation : Reset Settings [ v1.12 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 1F6FAA80 ID_BLOCK_I : 007050E1 ID_BLOCK_L : 05FF9561CC5A47423D12E2E32C77FFCF ID_BLOCK_L : 2A59E7464BDA048104F3A41D179E88B3 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Format USER ... Format CACHE ... Format failed! Remove FRP Additional data remove failed! Done! Elapsed: 00:01:21 Reconnect Power/Cable! Operation : Read PatternLock [ v1.12 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 410 [MSM8916] ID_BLOCK_S : 1F6FAA80 ID_BLOCK_I : 007050E1 ID_BLOCK_L : 05FF9561CC5A47423D12E2E32C77FFCF ID_BLOCK_L : 2A59E7464BDA048104F3A41D179E88B3 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Read Ok! Trying decrypt ... Patternlock NOT set! Done! Elapsed: 00:00:22 Reconnect Power/Cable! |
11-15-2018, 15:31 | #4 (permalink) |
Member: 702572 Status: Offline Sonork: 9837200009 Thanks Meter: 74 | Card found : 085E70FF , v0137 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16 Operation : Reset UserLocks [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 410 [MSM8916] ID_BLOCK_S : 1F6FAA80 ID_BLOCK_L : 05FF9561CC5A47423D12E2E32C77FFCF ID_BLOCK_L : 2A59E7464BDA048104F3A41D179E88B3 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB400000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Direct access : Ok! Processing step #1 Processing step #2 Processing step #3 Minor Error! Skip! Processing step #4 Minor Error! Skip! Processing step #5 Minor Error! Skip! Processing step #6 Minor Error! Skip! Processing step #7 Minor Error! Skip! UserLocks reset passed! 1. Power On phone, wait 30-50 second, press and hold PowerOn button until device restart! 2. To disable/remove fingerprints enter in Settings -> FingerPrint, set any password, remove fingerprints 3. In some cases require reboot phone twice or wait up to 5 minutes! Done! Elapsed: 00:04:23 Reconnect Power/Cable! |
11-16-2018, 07:19 | #7 (permalink) |
No Life Poster Join Date: Feb 2017 Location: Quelimane Mz Age: 26
Member: 2680008 Status: Offline Thanks Meter: 1,640 | [QUOTE=shahjadios;13418811]use umt ..tested many times[/QUOTE Look where you are my friend, if u cant help its most easy Stay quite P.S.... tested many times |
