11-12-2020, 16:18 | #1 (permalink) |
Freak Poster Join Date: Sep 2005 Location: Mrocco
Member: 184161 Status: Offline Thanks Meter: 22 | Oppo A37F Connection problem Today i received one Oppo A37F to bypass frp and pattern .... but my cm2 software don't found it inspit off the fact that the phone is connected well as you can see in the device manager !!! I tryed many times but without issue !!! But when i used the crack of miracle box i success to factory reset it ??? What was the problem Sir ???? BR |
11-12-2020, 17:50 | #2 (permalink) |
Freak Poster Join Date: Feb 2013
Member: 1877732 Status: Offline Thanks Meter: 119 | hey cm2qcom doesnt work with qcom 9008 port you have to install proper driver that called EmergencyDownloadDriver. WinUsbCoInstallers, WinUsbCompatIdInstaller, WinUsbDriversExt infinty team provided them with tool u can download from infinity download area |
11-12-2020, 17:55 | #3 (permalink) |
Member: 1877732 Status: Offline Thanks Meter: 119 | drivers link https://mega.nz/file/A3xWhCpT#E2t0bk...2RJEW_3vuzL6aY uninstall qcom 9008 driver then install these drivers |
11-12-2020, 19:58 | #4 (permalink) |
Member: 184161 Status: Offline Thanks Meter: 22 | Think you Sir for your interest , but i need to know in my case i must uninstall qcomm 9008 drivers and install cm2 qcomm drivers each time i need to use cm2 dongle ? And after use it i need to reinstall qcomm 9008 drivers to use other softs like miracle ,nck box .... BR |
11-13-2020, 04:11 | #5 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: BHARAT
Member: 327043 Status: Offline Sonork: 100.1587811 Thanks Meter: 1,514 | Quote:
for cm2qlm use 1 port for other dongle 9008 port use 2nd usb port u no need all time install uninstall driver | |
