07-03-2019, 07:40 | #1 (permalink) |
No Life Poster Join Date: Oct 2015 Location: Pakistan
Member: 2478233 Status: Offline Thanks Meter: 596 | Oppo a37f invalid nv data partition need solution Loading firmware ... Created by Infinity-Box (c) Chinese Miracle II (c) 2017 Device Brand : OPPO Device Manufact.: OPPO Device Model : A37f Device CPU : MSM8916 Device IntName : A37f Device Version : 5.1.1 SWVersion : A37fEX_11.A.22_INT_022_201705221641 CU_SWVer : OPPO Device Compile : 5/22/2017 10:56:07 AM Device ExtInfo : A37f Load Ok! Operation : Flash [ v1.16 ] ForceFlashing : Enabled Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 410 [MSM8916] ID_BLOCK_S : 0BAAB840 ID_BLOCK_L : 45BFD5218C1A0702FD52A2A36C37BF8F ID_BLOCK_L : 611CA20D0E91394A4FAEE3D82AC5D3F8 Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8916 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x00000003AB800000 [ eMMC 16 GiB ] ExtInfo : 0x00004000/00004000/00001000/00001000/00000200 Boot Ok! Flash Chain : 43 Flashing now Flashing : gpt_main0.bin Flashing : NON-HLOS.bin Flashing : sec.dat Flashing : sbl1.mbn Flashing : sbl1.mbn Flashing : emmc_appsboot.mbn Flashing : emmc_appsboot.mbn Flashing : rpm.mbn Flashing : rpm.mbn Flashing : tz.mbn Flashing : tz.mbn Flashing : hyp.mbn Flashing : hyp.mbn Flashing : pnvbak.img Flashing : lsplash.img Flashing : boot.img Flashing : recovery.img Flashing : system.img Flashing : cache.img Flashing : persist.img Flashing : misc.img Flashing : driver.iso Flashing : reserve4.bin Flashing : userdata.img Flashing : gpt_backup0.bin Flashing : gpt_main2.bin Flashing : cdt.mbn Flashing : gpt_backup2.bin Wipe data ... BootConfig set to 0x00 Flashing done! Done! Elapsed: 00:05:50 Operation : Write QCN (NVM) [ v1.16 ] 1. Enable DiagInterface on device [ by Code, Root or other way ] 2. Make sure DiagDrivers installed and work correct Wait for phone... Device Found! Initialize ... DiagMode initialized! MSMHW : 00007050 MODHW : 00000FFE BUILD : MPSS.DPM.2.0.2.c1.10-00065-M8936FAAAANUZM-1.98235.2.100042.1_VENDOR RTIME : May 22 201718:10:54 BTIME : May 21 201713:00:00 DEVST : EAAAANUZ xQCN details : IMEI [1] : 8xxxxxxxxxxxxxxx IMEI [2] : 8xxxxxxxxxxxxxxx BTID : D7A7D8EE01EC WiFi : D7A7D8EE01EC Writing NVRAM data from XQCN image ... Writing NV Items... Writing SIM1 NV Items... Writing SIM2 NV Items... Writing RFNV... Writing Provisioning Item Files... Write done! Reboot device, if it not restart! Hint : Factory Reset is required to finish process completely! Done! Elapsed: 00:00:12 |
