02-27-2023, 12:34 | #1 (permalink) |
No Life Poster Join Date: May 2003 Location: Romania Age: 48
Member: 29006 Status: Offline Thanks Meter: 28 | Oppo A53 CPH2127 Code: Operation : Identify [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : FFB9E8A5 ID_BLOCK_S : 1701F57D ID_BLOCK_E : 00510000 ID_BLOCK_L : 8F8F9DD2A9D5C30946728F5C23A5587D ID_BLOCK_L : 5C3B9A992451914731230AF0C4970898 Use CM2 Internal Loader ERROR : Prepare target failed! Unsupported yet CPU! INFO : Send log and report.log to support! Include device info also! Reconnect Power/Cable! https://forum.gsmhosting.com/vbb/f29...l#post14447274 Do I need some loaders? I tested few oppo mbn in QC_Custom_Loader But also no result Code: Operation : Identify [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : FFB9E8A5 ID_BLOCK_S : 1701F57D ID_BLOCK_E : 00510000 ID_BLOCK_L : 8F8F9DD2A9D5C30946728F5C23A5587D ID_BLOCK_L : 5C3B9A992451914731230AF0C4970898 Pickup loader from firmware package FH_LOAD_CODE : 15 ERROR : Loader send failed! HINT : Check cable, connection and drivers! Reconnect Power/Cable! |
02-27-2023, 13:54 | #2 (permalink) |
Freak Poster Join Date: Oct 2014 Location: Pakistan
Member: 2276949 Status: Offline Thanks Meter: 160 | The Above Success Story You Mentioned is Oppo A53 (2015) and you are trying On New Oppo A53 that is not supported By CM2 QLM BR |
The Following User Says Thank You to Khan Bhaie For This Useful Post: |
03-08-2023, 23:45 | #8 (permalink) |
Junior Member Join Date: Jan 2023 Location: Boston, USA Age: 24
Member: 3029772 Status: Offline Thanks Meter: 0 | Hi guys, I would like to ask you what you think about the Oppo find X5 pro. I'm thinking of getting one of these. Would love to hear what you think about it. |
03-10-2023, 14:55 | #10 (permalink) | |
