03-07-2020, 17:06 | #1 (permalink) |
No Life Poster Join Date: Aug 2011 Location: caribbean island
Member: 1643797 Status: Offline Thanks Meter: 183 | oppo a79k reset fail Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.08 Load IDBase v124106 Ok! Operation : Reset Settings/Format FS [ v2.08 ] Mode : FULL FACTORY ( FORCED + FRP ) 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MTK USB Port (COM30) MODE : BOOTROM PORT : 30 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6763 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+ARB BROM : BOOTROM MODE : 0_base : BASE_v1712 | Manual : Disabled BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 1006 0037 F3: 4000 00E0 F7: 102D 0000 00: 1005 0000 F3: 4000 00E0 F7: 102D 0000 01: 102A 0001 BROM : SOCID : 46D3D8D8B8901326AE9A2C9C78C289B24E04A948CE95E00178 5F01B913C477DE AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6763 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00007017 : DA SEND ERROR! ERROR : SECURE BOOT : SLA REQUIRED IN BROM MODE! INFO : BROM Level : CERT/AUTH required! Try boot device in PRELOADER mode with select PL/PL_CRYPTO/SWSEC type! Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! |
03-07-2020, 20:06 | #4 (permalink) |
Member: 1643797 Status: Offline Thanks Meter: 183 | Card found : D32E22AC , v0140 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.09 Load IDBase v36128 Ok! Operation : Reset Settings/Format FS [ v2.09 ] Mode : META 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MTK USB Port (COM30) MODE : BOOTROM PORT : 30 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6763 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+ARB BROM : BOOTROM BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 1006 0037 F3: 4000 00E0 F7: 102D 0000 00: 1005 0000 F3: 4000 00E0 F7: 102D 0000 01: 102A 0001 BROM : SOCID : 46D3D8D8B8901326AE9A2C9C78C289B24E04A948CE95E00178 5F01B913C477DE BROM : SLA BROM : Selected Auth/Cert not accepted by device! >>> Check previous message for more info! Reconnect Power/Cable! |
03-07-2020, 20:26 | #5 (permalink) | |
No Life Poster Join Date: Sep 2015 Location: SINDH, PAKISTAN.
Member: 2452939 Status: Offline Thanks Meter: 256 | Quote:
Drivers_MTK-SP_v5.1632_x86_x64.7z And try again in meta mode. Download link Index of pub/software/drivers/ | |
03-07-2020, 21:15 | #6 (permalink) |
No Life Poster Join Date: Feb 2006 Location: In my LAB
Member: 231728 Status: Offline Thanks Meter: 2,104 | *In case of secure fuse, auth can be used ( setup in model selection, or manual select as AUTH file ) In model list select oppo F7 and try reset in meta mode |
03-07-2020, 22:05 | #7 (permalink) |
Member: 1643797 Status: Offline Thanks Meter: 183 | Card found : D32E22AC , v0140 Infinity-Box [ Chinese Miracle ] MediaTek Service Module [ MTK ] v2.09 Load IDBase v36128 Ok! Operation : Reset Settings/Format FS [ v2.09 ] Mode : FULL FACTORY ( FORCED + FRP ) 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM11) MODE : BOOTROM PORT : 11 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6763 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+ARB BROM : BOOTROM MODE : 0_base : BASE_v1952 | Manual : Disabled BROM : SOCID : 46D3D8D8B8901326AE9A2C9C78C289B24E04A948CE95E00178 5F01B913C477DE BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 1006 0037 F3: 4000 00E0 F7: 102D 0000 00: 1005 0000 F3: 4000 00E0 F7: 102D 0000 01: 102A 0001 AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6763 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : 0x00007017 : DA SEND ERROR! ERROR : SECURE BOOT : SLA REQUIRED IN BROM MODE! INFO : BROM Level : CERT/AUTH required! Try boot device in PRELOADER mode with select PL/PL_CRYPTO/SWSEC type! Error : Fail to init protocol! >>> Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! |
03-07-2020, 22:07 | #8 (permalink) | |
Member: 1643797 Status: Offline Thanks Meter: 183 | Quote:
Operation : Reset Settings/Format FS [ v2.09 ] Mode : FULL FACTORY ( FORCED + FRP ) 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM11) MODE : BOOTROM PORT : 11 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6763 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+ARB BROM : BOOTROM MODE : Oppo : F7 | Manual : Disabled BROM : SOCID : 46D3D8D8B8901326AE9A2C9C78C289B24E04A948CE95E00178 5F01B913C477DE BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 1006 0037 F3: 4000 00E0 F7: 102D 0000 00: 1005 0000 F3: 4000 00E0 F7: 102D 0000 01: 102A 0001 BROM : SLA BROM : Selected Auth/Cert not accepted by device! >>> Check previous message for more info! Reconnect Power/Cable! Operation : Reset Settings/Format FS [ v2.09 ] Mode : FULL FACTORY ( FORCED + FRP ) 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM11) MODE : BOOTROM PORT : 11 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6763 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x000000E5 BROM : SecMode : SBC+SDA+ARB BROM : BOOTROM MODE : Oppo : F7 | Manual : Disabled BROM : SOCID : 46D3D8D8B8901326AE9A2C9C78C289B24E04A948CE95E00178 5F01B913C477DE BROM : ARB : ACTIVE : LOG : F0: 102B 0000 F3: 1006 0037 F3: 4000 00E0 F7: 102D 0000 00: 1005 0000 F3: 4000 00E0 F7: 102D 0000 01: 102A 0001 BROM : SLA BROM : Selected Auth/Cert not accepted by device! >>> Check previous message for more info! Reconnect Power/Cable! | |
