Old 04-18-2019, 10:58   #1 (permalink)
niaz muhammad's Avatar
Member: 1519396
Sonork: 100.1612702
Thanks Meter: 1,951
Nokia 3 after formating only vebrate
NOKIA 3 PATTREN LOCK I REED BEKUP AND THEN FORMAT NOW PHONE ONLY VEBRATE NOT ON
MT6737M__Unknown__Heart__Unknown__8.1.0__alps-mp-o1.mp1-V1.132.2_k37mv1.64.bsp_P6
======= Flash
Card found : S/N : CE90936C , v0137
Chinese Miracle II  [MTK module] v 1.58
Start  at : [17/04/2019 / 14:54:36]
Operation : Read Flash [ v1.58 ]
Wait for phone...
Phone found! [ 22 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6737
BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x05000000
BromVer   : 0x00FF
BLVersion : 0x0002
BootLdrSS : LOCKED with CERT
Processing DA stage
DA Select done, will use SecMode DA
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x9B
NAND Flash : NOT INSTALLED
eMMC Flash : 514E011336394A32B205105241638C25
[WARNING] : MEMORY_eMMC_VALIDATE_FAILED
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x13 , OEM : 014E
[eMMC] : FLASH_INF : [NOT_IN_BASE] , R69J2
[eMMC] : FLASH_CID : 13014E51324A3936521005B2258C4441
[eMMC] : FLASH_LEN : 0x00000003AB400000
[eMMC] : FLASH_UCP : 15028 MiB [eMMC 16 GiB]
DEV RID    : 0xB6C6A77E263762507086F0345DC49E33
INT RAM    : 0x00020000
EXT RAM    : 0x80000000 [2 GiB]
BOOT TYPE  : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Reading Flash Content now ...
xGPT : Normalize settings Ok!
Brand     : Unknown
ProdName  : Unknown
ProdModel : Heart
Device    : Unknown
AndroidVer: 8.1.0
MTKxCPU   : MT6737M
MTKxPRJ   : alps-mp-o1.mp1-V1.132.2_k37mv1.64.bsp_P6
[Read Ok] : preloader_ne1.bin
[Read Ok] : lk.bin
[Read Ok] : boot.img
[Read Ok] : recovery.img
[Read Ok] : logo.bin
[Read Ok] : secro.img
[Read Ok] : tz1.img
[Read Ok] : tz2.img
[Read Ok] : box.img
[Read Ok] : sys_info.img
[Read Ok] : hidden.img
[Read Ok] : cda.img
[Read Ok] : system.img
[Read Ok] : cache.img
[Read Ok] : userdata.img
[ScatCFG] : MT6737M / V1.1.2 / ne1 / EMMC
Android Info saved
HWConfig Info saved
FW Size : 4276 MiB
Scatter saved to : C:\Users\Niaz muhammad\Desktop\MT6737M__Unknown__Heart__Unknown__8.1.0__alps-mp-o1.mp1-V1.132.2_k37mv1.64.bsp_P6\
All done!
Done!
Elapsed: 00:08:39
Reconnect Power/Cable!
Wait for phone...
Phone found! [ 22 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6737
BromVer   : 0x00FF
BLVersion : 0x0002
Processing DA stage
SOC VERIFY : C1
Boot Ok!
ISPFF  ID : 6737 , TARGET ID : 6737
FlashFile is differs from eMMC settings, continue by user request
Flash pre-erase enabled
Erase Flash now ...
Flash pre-erase done
Write Flash now ...
[ MCU ] : MT6737M__UNKNOWN__Heart__alps-mp-n1.mp1-V1.11_fih6737m.65.nj.n1_P13__Android_7.1.1.ispff
Init Ok , Sending blocks ...
Write failed :(
Flash Error!
Check Cable, Battery , try again
Operation Failed
Elapsed: 00:11:46
Finish at : [18/04/2019 / 10:13:26]
The Following User Says Thank You to niaz muhammad For This Useful Post:
Old 04-18-2019, 11:07   #2 (permalink)
shahinbangla's Avatar
Member: 2318480
Sonork: 100.1669259
Thanks Meter: 198
InfinityBox BEST2 Format support
The Following 2 Users Say Thank You to shahinbangla For This Useful Post:
Old 04-18-2019, 11:46   #3 (permalink)
Member: 2812901
Thanks Meter: 493
You need factory signed firmware to revive your phone and try to use infinity-best2 v1.14 to flash.
The Following 2 Users Say Thank You to Oyetunde Semiu For This Useful Post:
Old 04-18-2019, 11:49   #4 (permalink)
Member: 2812901
Thanks Meter: 493
Anything pertaining to Nokia hmd always use infinity-best2 to format or flash. 100% capable and successful.
Old 04-18-2019, 12:10   #5 (permalink)
Registered User
Member: 767472
Sonork: 100.1609877
Thanks Meter: 599
read nv
full format
write again damage backup
The Following 2 Users Say Thank You to .....::::GsmAdeel:::::..... For This Useful Post:
Old 04-18-2019, 12:24   #6 (permalink)
shahzadqadri's Avatar
Member: 2620420
Sonork: 100.1678393
Thanks Meter: 1,295
NEVER MAKE FLASH ERASE!!!! You will kill device!!!
NOT update PRELOADER ( tick SKIP Preloader ) and NOT erase device ( untick Flash Pre-erase )
The Following User Says Thank You to shahzadqadri For This Useful Post:
Old 04-18-2019, 13:02   #7 (permalink)
Member: 1519396
Sonork: 100.1612702
Thanks Meter: 1,951
wich tray to flash I tray
this all
MT6737M__Unknown__Heart__Unknown__7.1.1__alps-mp-n1.mp1-V1.11_fih6737m.65.nj.n1_P13.rar
Nokia3_MT6737M_Heart_FIH_7.1.1.7z
Old 04-18-2019, 13:08   #8 (permalink)
Member: 2620420
Sonork: 100.1678393
Thanks Meter: 1,295
This One Also Recover 4 Mobile
Use CM2 V1.58
Old 04-18-2019, 13:18   #9 (permalink)
Member: 1519396
Sonork: 100.1612702
Thanks Meter: 1,951
Use CM2 V1.58
ye I recover tow phone but this one have latest secorty 8.1 ver this phone v1.32
Old 04-18-2019, 15:12   #10 (permalink)
Member: 1519396
Sonork: 100.1612702
Thanks Meter: 1,951
now my problime slove this file best2 NE1-443E-0-00WW-B01_2
phone but logo restarting
Card found : 8C73AEBC , v0122
Infinity-Box BEST Nokia [HMD] Module [NK2] v1.14
Load : D:\Nokia flash file\Nokia 3\NE1-443E-0-00WW-B01_2\NE1-443E-0-00WW-B01.nb0
Bad file selected! Select correct NB0 file!
Load Ok!
Operation : Write FW [ v1.14 ]
Setting   : UserData preserve : False
Setting   : Flash Pre-Erase   : True
Setting   : Bootloader update : True
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
2. Insert USB cable in phone
 - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage!
Waiting for device connection ...
PTFN : MediaTek USB Port (COM23)
MODE : BOOTROM
PORT : 23
Waiting BOOT ack ...
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
     CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000
     TYPE : LEGACY MTK
BROM : DSLevel  : DEV_KEY+DEV_CRT
BROM : BOOTROM
AGENT : Look for suitable BootChain in DA ...
AGENT : DEFAULT AUTO
AGENT : Found MT6735
AGENT : Nokia_All_InOne_DA_v03.2019.1303
Fail to disable Dog!
     BROM : Sending 1st DA ...
  BROM  : 0x00007017 : DA SEND ERROR!
  ERROR : SECURE BOOT : SLA REQUIRED IN BROM MODE!
Error : Fail to init protocol!
Remove battery, cable. Check cable and connection. Repeat operation!
PTFN : MediaTek PreLoader USB VCOM (Android) (COM22)
MODE : PRELOADER PORT
PORT : 22
PRELOADER : ACK confirmed!
BROM : Init BROM
BROM init passed!
     TYPE : LEGACY MTK
BROM : PRELOADER PORT
BROM : DA sent
BROM :Transfer control to DA ...
     DA : AGENT started!
NAND : DEVICE NOT FOUND
eMMC : OK
eMMC : 13014E51324A3936521005B2258C6341
DAInf: 4 : 2 : 155
     DA : DRAM ready!
DA : BOOT to 2nd DA ...
DA : Receiving HW info
        EMMC: 13014E51324A3936521005B2258C4441
        EMMC: VEN : MICRON | OEM : 4E01 | DEV : Q2J96R
        EMMC:
              BOOT1  : 0x00400000 [ 4.00 MB ]
              BOOT2  : 0x00400000 [ 4.00 MB ]
              RPMB   : 0x00400000 [ 4.00 MB ]
              USER   : 0x3AB400000 [ 14.68 GB ]
        SRAM: 0x00020000 [ 128.00 KB ]
        DRAM: 0x80000000 [ 2.00 GB ]
        CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000
        RNID : 5062372634F08670339EC45DBF431E7E
 STATUS : BLANK FLASH
 BSTYLE : EMMC FLASH BOOT
DA : USB : HIGH-SPEED
Boot done!
SEC_DL : False (CUST)
SEC_ID : 0x67887C7972766E6888787678777B796E
[FL] : HW verification passed!
Erase : 0x0000000001C80000 : 0x0000000005680000
Erase : 0x0000000007320000 : 0x0000000002000000
Erase : 0x0000000009B20000 : 0x000000017D4E0000
PMT Update : Skip
Flashing now ...
PROCESS : PRELOADER
Unpack  : NE1-0-443E-preloader_NE1.bin
Flash   : NE1-0-443E-preloader_NE1.bin
Update bootloader code ...
Update bootloader Ok!
PROCESS : LK
Unpack  : NE1-0-443E-00WW-lk.img
Flash   : NE1-0-443E-00WW-lk.img
PROCESS : BOOT
Unpack  : NE1-0-443E-00WW-boot.img
Flash   : NE1-0-443E-00WW-boot.img
PROCESS : RECOVERY
Unpack  : NE1-0-443E-00WW-recovery.img
Flash   : NE1-0-443E-00WW-recovery.img
PROCESS : LOGO
Unpack  : NE1-0-443E-00WW-logo.bin
Flash   : NE1-0-443E-00WW-logo.bin
PROCESS : SECRO
Unpack  : NE1-0-443E-secro.img
Flash   : NE1-0-443E-secro.img
PROCESS : TEE1
Unpack  : NE1-0-443E-tee.img
Flash   : NE1-0-443E-tee.img
PROCESS : TEE2
PROCESS : SYS_INFO
Unpack  : fver
Flash   : fver
PROCESS : SUTINFO
Unpack  : NE1-00WW-001-sutinfo.img
Flash   : NE1-00WW-001-sutinfo.img
PROCESS : CDA
Unpack  : NE1-00WW-010-cda.img
Flash   : NE1-00WW-010-cda.img
PROCESS : SYSTEM
Unpack  : NE1-0-443E-00WW-system.img
Flash   : NE1-0-443E-00WW-system.img
PROCESS : CACHE
Unpack  : cache.img
Flash   : cache.img
PROCESS : USERDATA
Unpack  : userdata.img
Flash   : userdata.img
PMT Update : Skip
Flashing finished!
Done!
Elapsed: 00:06:38
Old 04-18-2019, 15:15   #11 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Flash SW 3380, make sure about battery charged.
Update device after over OTA.
The Following 5 Users Say Thank You to JayDi For This Useful Post:
Old 04-18-2019, 17:42   #12 (permalink)
Member: 1519396
Sonork: 100.1612702
Thanks Meter: 1,951
Thanks to replay my device on but restart
https://www.youtube.com/watch?v=zd3u...&feature=share &fs=1&hd=1" width="858" height="508">https://www.youtube.com/watch?v=zd3u...&feature=share &fs=1&hd=1" />https://www.youtube.com/watch?v=zd3u...&feature=share ">http://www.youtube.com/watch?v=https://www.youtube.com/watch?v=zd3u...&feature=share
Old 04-19-2019, 05:07   #13 (permalink)
Member: 1519396
Sonork: 100.1612702
Thanks Meter: 1,951
Load : D:\Nokia flash file\Nokia 3\OST_Tool_Driver\Nokia-3-Essential_NE1-3380-0-00WW-B01\NE1-3380-0-00WW-B01.nb0
Load Ok!
PTFN : MediaTek PreLoader USB VCOM (Android) (COM36)
PORT : 36
BROM : Init BROM
BROM init passed!
     TYPE : LEGACY MTK
BROM : DA sent
     DA : AGENT started!
eMMC : OK
DAInf: 4 : 2 : 155
     DA : DRAM ready!
        EMMC:
Boot done!
PMT Update : Skip
Flashing now ...
PROCESS : PRELOADER
Unpack  : NE1-0-3380-preloader_NE1.bin
Flash   : NE1-0-3380-preloader_NE1.bin
PROCESS : LK
Unpack  : NE1-0-3380-lk.img
Flash   : NE1-0-3380-lk.img
PROCESS : BOOT
Unpack  : NE1-0-3380-00WW-boot.img
Flash   : NE1-0-3380-00WW-boot.img
PROCESS : RECOVERY
Unpack  : NE1-0-3380-00WW-recovery.img
Flash   : NE1-0-3380-00WW-recovery.img
PROCESS : LOGO
Unpack  : NE1-0-3380-logo.bin
Flash   : NE1-0-3380-logo.bin
PROCESS : SECRO
Unpack  : NE1-0-3380-secro.img
Flash   : NE1-0-3380-secro.img
PROCESS : TEE1
Unpack  : NE1-0-3380-tee.img
Flash   : NE1-0-3380-tee.img
PROCESS : TEE2
PROCESS : SYS_INFO
Unpack  : fver
Flash   : fver
PROCESS : SUTINFO
PROCESS : CDA
PROCESS : SYSTEM
Unpack  : NE1-0-3380-00WW-system.img
Flash   : NE1-0-3380-00WW-system.img
PROCESS : CACHE
Unpack  : cache.img
Flash   : cache.img
PROCESS : USERDATA
PMT Update : Skip
Flashing finished!
Done!
Elapsed: 00:05:18
sam logo restaarting
Page generated in 0.31831 seconds with 8 queries
