11-04-2017, 10:02 | #1 (permalink) |
No Life Poster Join Date: Feb 2005 Location: GSM WORLD
Member: 118520 Status: Offline Thanks Meter: 3,551 | OPPO F1S A1601 (32GB) SIGNED SPRELOADER MT6755 PATTERN LOCK READ Done Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 39 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : BROM DRAM configured from ScatFW! Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMB1X [eMMC] : FLASH_CID : 150100525831424D4207BFA4CE0F83F3 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000747C00000 [eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB] DEV RID : 0xFD096D454B4C3E08BDAA5773FADF326E INT RAM : 0x00000000 EXT RAM : 0x80000000 [2 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : FULL-SPEED Boot Ok! [AP] : Initial info read Ok! Brand : OPPO ProdName : A1601 ProdModel : A1601 Device : A1601 AndroidVer: 5.1 MTKxCPU : MT6755 MTKxPRJ : A1601EX_11_A.33_170814 SECURITY : IMEI_SW [1] : XXXXXXXXXXXXXX IMEI_SW [2] : XXXXXXXXXXXXXX BTMAC Addr : XXXXXXXX WiFi MAC : XXXXXXX EXTRA : LCD : Not info available LCD Res : M_HEIGHT=1280xM_WIDTH=720 TOUCH [0] : STOM_KERNEL_TOUCHPANEL=GT1XX CAM [0] : STOM_HAL_IMGSENSOR=s5k3l8_mipi_raw CAM [1] : imx258_mipi_raw CAM [2] : ov8865_mipi_raw CAM [3] : s5k3p3sp_mipi_raw MODEM : oppo6750_15331_lwg Done! Elapsed: 00:00:17 Reconnect Power/Cable! ---------------------------------------------------------------------------------------------------------------------------------------------------- Operation : Read Pattern/DP Lock [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 39 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : BROM DRAM configured from ScatFW! Link with DAgent established eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMB1X [eMMC] : FLASH_CID : 150100525831424D4207BFA4CE0F83F3 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000747C00000 [eMMC] : FLASH_UCP : 29820 MiB [eMMC 32 GiB] DEV RID : 0xFD096D454B4C3E08BDAA5773FADF326E INT RAM : 0x00000000 EXT RAM : 0x80000000 [2 GiB] [NAND] : FLASH : NOT INSTALLED [UFSM] : FLASH : NOT INSTALLED [HSUSB] : MODE : FULL-SPEED Boot Ok! USBDL : Init HSUSB Ok Reading data ... Get Locks ... PatternLock Sequnce : 5214789 Done! Elapsed: 00:00:21 Reconnect Power/Cable! THANKS INFINITY-BOX TEAM |
The Following 4 Users Say Thank You to gracy_elec For This Useful Post: |
11-04-2017, 16:37 | #3 (permalink) |
Member: 118520 Status: Offline Thanks Meter: 3,551 | .::Successful Story For MTK Secure Boot Starts::. |
The Following 3 Users Say Thank You to gracy_elec For This Useful Post: |
