04-10-2017, 15:44 | #1 (permalink) |
Junior Member Join Date: Jun 2008 Location: pakistan
Member: 785022 Status: Offline Thanks Meter: 1 | oppo f1s petren not read any solution ? Chinese Miracle II [MTK module] v 1.58 Operation : Read Pattern/DP Lock [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 24 ] Sync... Inital Boot Ok! BB_CPU_PID : 6755 BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... DAgent configured successfully Connection agent : BROM [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2122 EMICFG_NOT_ACCEPTED_CONFIG Boot Error! Operation Failed Elapsed: 00:00:10 Reconnect Power/Cable! |
04-10-2017, 17:23 | #4 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Inside Infinity
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | Hello, This Mobile have 2varaint i think urs is 3gb for tht Search Scatter select scatter file and do Read pattern for now this is the solution |
